TV/DVD combi (not LCD)
Appears to remain on standby. The red light is on but no pictur, menu or dvd functions. Bought in France.
  • 979 Answers
What country are you in?...accordianman
Posted on Feb 29, 2008
Rosen roof dvd player has sound but no picture please help
Hi Gill.
Check, Make sure the cables are connected. Try cleaning the laser and the DVD. Make sure the TV is on the correct input.
try swapping one of the sound cables to see if the yellow cables is in fact damaged.
1) Plug the DVD player in to the TV that it does work on. Make sure there is no disc in the player. Check the DVD players set up menu. Look in the Picture menu and change the output to "RGB" Move the player back to the TV/VHS Combi. Select the input that gives you RGB1.
2) Same as above, but this time change the Picture menu to PAL (or composite or Video....whatever is the other option name that isn't RGB or S-Video). Retest on the Combi, but this time you want AV1.
If these don't work then you might need to have a look in the TV manual about connecting external sources. It could be that because the combi has a recorder that it's trying to stop you from copying DVD to VHS. See if there's an input on the combi that bypases the recorder.
Read more: https://www.diynot.com/diy/threads/dvd-problem-sound-but-no-picture.211588/#ixzz5FYrJiX6o
I found all this on the internet so not sure if it will help you out.
or try this link.
dvd player has sound but no picture Google Search
May 15, 2018 | Rosen Car Audio & Video
Alba portable tv/dvd combi
Main board fault. Contact any service technician.
Mar 26, 2014 | Televison & Video
Recently bought a toshiba tv and dvd combi but wont play any dvds
You need to go in the menu and change the region code. yours is not set for amarican made dvd's
Mar 05, 2013 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Bush 24 inch tv/dvd combi screen went blank as if it's on standby. won't respond to remote control. one week old. is it seroius?
try switching on tv point remote at the tv pressing the menu/exit button and holding for 10/20 seconds hope this works for you
Oct 07, 2012 | Bush Industries IDLCD26TV16HD LCD TV
When the tv is switch on the picture appears momentarily, then disappears leaving a blank black screen, same when dvd player is switched on, unplugging the tv and the cable has not worked
Hello, I need more information to focus on the problem. When a malfunction occurs, whether you get any indication on the screen while pressing the menu button on the remote control. Is the voice remains in issue. What happens with the waiting lights.
Mar 06, 2011 | Philips 32PF7531D 32 in. HD-Ready LCD...
Connecting a DVD/VCR combo to LCD TV
The best suggestion I would advise is to buy a shielded scart connector & connect that from your DVD combi to either AV1 OR AV2. It sounds as if you are picking up RF interference from your current connections, this can sometimes happen if the cables do not have adequate shielding.
May 21, 2009 | LG 42LG30 42 in. LCD HDTV
Unable to properly connect sony dvd to tv to play movie
DVD-3 RCA phono outputs(red & white=audio,yellow=video
I have a DVP-NS700,the same happens on mine.Turn it on,goes green to red(standby),then press eject,it will then power up properly.
Jan 03, 2009 | Sony DVP-NS300 DVD Player
TV ON STANDBY MODE
The blinking light on the front indicates a shorted part in the power supply. The power board will need to be replace or repair to restore the LCD functionality.
Let me know if you required further assistance.
Oct 06, 2008 | Akai LCT3701AD 37 in. LCD Television
Vhs dvd combi panasonic dmr ez47
If you select the HDMI channel to watch a dvd does it do it then, if not disconnect both ends of the scart lead and reconnect or replace. If the scart lead is not in properly this could happen, when you switch on the player and play a disc your tv will automatically switch to the AV/Scart channel, but you are better off manually turning the TV over to the HDMI Hi-Def channel for DVD.
Dec 24, 2007 | Panasonic DMR-EZ47V DVD Recorder/VCR
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
