CANON IR2870 OFFICE COPIER, FAX CONFIRMATION REPORT QUESTION
Canon ImageRunner 2870 Copier, "Send Report" / "Confirmation Report"
After faxing a document, we want the report sheet to only have confirmation data. We DO NOT want a picture of the document sent after the data on the confirmation sheet. This is because sometimes office workers send faxes with social security #s in the document and then walk away from the machine before the confirmation report is printed. Once printed, anyone who stumbles by (we work for a college with roaming students in our hallways) can see the social security number. We'd like to avoid this. Is it possible? Thanks in advance for your help.
User interface =>report settings => fax=>report on tx=>image of tx =>off
Posted on Mar 13, 2008
Canon ir4570 ir3570 ir2870 ir2270 service manual
Hello friend, you can find the canon ir4570 ir3570 ir2870 ir2270 service manual in below link:
Canon service manual:
http://goo.gl/GDAzQQ
Thanks
Apr 12, 2014 | Canon imageRUNNER 2870 Copier
How to I turn off the automatic printing of the fax logs.
To change fax confirmation
1. Press Setup.
2. Press Print Report, and then Fax Confirmation.
3. Press the right arrow button to select one of the following, and then press OK.
Off - Does not print a fax confirmation report when you send and receive
faxes successfully. This is the default setting.
On Fax Send - Prints a fax confirmation report for every fax you send.
On Fax Receive - Prints a fax confirmation report for every fax you receive.
Send & Receive - Prints a fax confirmation report for every fax you send and receive.
May 03, 2011 | HP Officejet Pro L7780 All-In-One InkJet...
HP 6310 All-in-One. How do I get a fax confirmation?
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 3.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
Fax
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and
receive.
Oct 27, 2010 | HP Officejet 6310 All-In-One InkJet...
Not getting confirmations when I scan documents
do you mean that your copier doesnt print fax report after sending one?
On add.functions (*) under FAX sett., you must under REPORT select TX ( transmission )report ON.
Aug 03, 2010 | Canon imageRUNNER 1023iF Black and White...
How do i clear the fax address book?
If not used as network printer you can use Initialize All Data to remove all settings.Initialize=ERASE>>> WARNING>>> this will remove all settings for header,number,user boxes,network settings. Unless you print all of these other settings for fax - network(Additional Funtions Report) and remember how to re-input DO NOT USE THIS.
You can have a fax tied to a one-touch button and that will prevent you from deleting from the fax screen.
1st>Send tab>reg.tab>Register One-Touch Button>Highlight Name>Erase tab will activate touch Erase>Yes to confirm
2nd>Send tab>Address Book>Register>RegisterAddress>Highlight Name>Erase>Yes to confirm
Apr 27, 2010 | Canon imageRUNNER 4570 Copier
Describe your canon imagerunner 1023 how to
1) on copier you have a button add. functions-something like *
2) with + or - trough the menu press OK at FAX sett. or under report sett.- If I recall its under Fax sett.
3) try to find report sett. then OK
4) you must enable the RX REPORT than OK
For transmision report you must enable TX REPORT
Jan 13, 2010 | Canon imageRUNNER 1023iF Black and White...
Canon Image Runner 2870
just go into reports and print it out there
May 22, 2009 | Canon imageRUNNER 2870 Copier
Canon mx700 fax report problems
after emailing canon support, the answer is this: 1) the fax paper size must be "letter" - 8.5-11". 2) reset all settings through settings menu. the fax will then print reports (and also every report that was not printed before).
Mar 05, 2009 | Canon MX700 Office All-In-One InkJet...
I do not know how to set the fax to send a fax confirmation
Press your user mode button(the one with the star)-press the arrow(the plus button) untill you get 8-report settings,press ok.Settings will apear on the screen,press ok.tx report will show on the screen press ok,use the arrow key to set it to"on"
Then you will receive the reports
Nov 25, 2008 | Canon imageRUNNER 1023iF Black and White...
ImageClass 2220 Fax Function
Press Aditional funcktion button(The one with the star)
Select Report settings,
Under Custom settings,select "fax"
Switch TX report to "ON"
Nov 06, 2008 | Canon imageRUNNER 2200
Computers & Internet Logo
242 people viewed this question
David Payne
David Payne
