Question about Dryers
I am looking for instructions on how to change the V-belt (a.k.a. Multi rib belt - I think?) for a Maytag Dryer Model # MDG9520BWW. It is the belt that turns the tumbler.
    Problem Solver:
  • 12 Answers
There are 2 screws at the bottom in front of your machine. remove them.pull out on the bottom of the front .it should fall off,the support for the tub is there.screws on right and left must be removed .front support should come off.careful with the wires.the belt must be released from the idler pully .pay close attention how the belt runs on the pully before you remove it.hope this helps.also on most matag dryers `the smooth side of the belt goes to the tub.
Posted on Feb 28, 2008
How to change the dryer belt
The Videos below will cover all you need to know: Unplug Dryer and turn off gas supply before dis-assembly.
Video 1-Covers full dis-assembly and reassembly:
https://youtu.be/1eeJvqhHEYY
Video 2 is a bit more helpful in the details of proper belt mounting and alignment:
https://youtu.be/4bHOjysr5nU
Good Luck. This should make it very easy for you. Belt ribs MUST be down onto drum.
Nov 23, 2015 | Maytag Neptune MDG5500AW Gas Dryer
Tip
Dryer Belt Replacement Replace Dryer Belt Admiral Amana Asko Crosley ...
If you need to replace your dryer belt and need a diagram to see how it goes, check out these diagrams.
For Admiral all models will look like this
154ceff.gif Style: Flat with ribs
Installation Tips: Ribs against drum
For Amana all models will look like this
Installation Tips: Ribs face toward drum
For Asko all models will look like this
For Crosley all models will look like this
Fridgidaire
1970 – 1985
1985 – 1995
1995 – present
Style: Flat belt
Installation Tips: Side of belt with words faces away from drum
on Mar 02, 2010 | Dryers
What type of dryer belt does Roper REX4634KQ take?
The part number is 341241 it could be purchased from your local appliance parts store on online at;
searspartsdirect.com
repairclinic.com
apdepot.com
partselect.com
apwagner.com
Sep 08, 2011 | Roper REX4634KQ Electric Dryer
How do I replace the belt on my Asko T761 dryer? Do I go in thru the front, the back? Are there instructions on-line for belt replacement?
How to install a belt on ASKO dryer
Belt Type: Flat belt with ribs
Installation Notes: Ribs go against drum
You could Refer to :-
http://fixitnow.com/wp/2006/05/08/asko-t700-dryer-wheel-drum-and-belt-replacement-instructions/
It would be a Generic one but would help you.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 11, 2010 | Asko T761 Electric Dryer
How to install a multi rib dryer belt on my
remove the back!! top lid take 2 bolts out of the inside top of the front panel and two screws on the lower outside front panel remove the belt if its still on the drum ! slide drum outwards about 6 inches then from the back of unit slide the belt around the motor shaft and then the drum and hook around the idler tensioner slide drum back and reassemble
Jan 17, 2010 | Whirlpool LER4634J Electric Dryer
Need belt diagram for Performa PDET920AYW dryer
Flat side of the belt goes agaist the drum. The diagram is on the new belt
Aug 08, 2009 | Maytag PYE2300AY Electric Dryer
Need help replacing dryer belt on Maytag MDE9306AYW
Hi, Remove the screws in the door opening. Two screws hold the door hinge but, the door will stay in place. Once you get the screws removed, the front panel will lift off. Once you get the front off, you will see the drum and what it will take to thread the belt around it. Make sure the rib side of the belt is touching the drum and the ribs need to set into the ribbed pulley on the motor. The idler puley is spring loaded and will need to be moved with one hand while you thread the belt with the other hand.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 27, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Do you have a digram to show you how to change belt on inglis dry
amana.gif Diagram A
transparent1.gif frank.gif Diagram B
transparent1.gif frig.gif Diagram C
transparent1.gif ge.gif Diagram D
transparent1.gif maytag.gif Diagram E
Installation Tips: Flat side of belt against drum
transparent1.gif admiral.gif Diagram F
transparent1.gif westing.gif Diagram G
Style: Flat belt
transparent1.gif whirlpool.gif Diagram H
belt1.gif Diagram J
belt2.gif Diagram K
belt3.gif Diagram L
belt4.gif Diagram M
Jun 25, 2009 | Whirlpool Inglis IP8200 Dryer
Dryer belt
If your dryer belt has ribs on one side you would think the ribs would go face down on the drum. try it with the ribs up and the smooth side down on the drum. If you can figure out the belt route and it doesn't look right due to the ribs then the cure for that is flip the belt over. Good Luck
Mar 19, 2009 | GE Dryers
Maytag dryer belt replacement
Jan 03, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
80 people viewed this question
Top Dryers Experts
