Question about HP DeskJet 812c InkJet Printer
Hp deskjet 812c ink light blinks w new cartridges
  • roncroc52 Mar 09, 2008
    The print heads keep cycling back and forth and the lights flash. Does not print.
  • Anonymous Jun 17, 2008
    I replaced the cartridges and the light keeps blinking. I tried the soft cloth on the back idea. That didn't work.
  • 152 Answers
Here write 4 step you do it step by step
1. remove safaty strip from the cartridge
2. clean carridge block contact with soft cloth
3. replace cartridge for short
4. replace carridge block
Posted on Feb 28, 2008
I just changed ink in canon DeskJet 812c and can not get yellow ink to work. I have run service of aligning the print cartridges and cleaning the cartridges. Any suggestions?
hi, it maybe your ink problem, becouse after do the cleaning for many time but still cannot, try to use other or new cartridge and see what result, TQ
Aug 05, 2011 | HP DeskJet 812c InkJet Printer
`HP Deskjet F380 All-in-One Printer-Scanner-Copier E light is on seeming to refer to an ink cartridge issue. I installed new black and color ink cartridges. Light is still on and printer won't make...
Issue: Print Cartridge light is blinking
NOTE: In addition to the blinking light, an "E" might appear in the Copies area.
Solution
Close the print cartridge door.
Cause
The print cartridge door is open.
Oct 28, 2010 | HP DeskJet F380 All-In-One Printer
The ink cartridges on my HP 812c won't move. What can I do?
You can probably throw it away, it's an old printer and the belt is probably broken that moves the print head back and forth. There are some good cheap printers out there even at Walmart.
May 18, 2010 | HP DeskJet 812c InkJet Printer
HP DeskJet 812C Hardware Problem! with Printer cartridge carriage. Printer Cartridge retracted into right side of case will not come out. There is No paper jam in machine to prevent it from doing so. ...
Disconnect the "data" cable (parallel or USB).
Disconnect the "power" cable.
Reconnect the "power" cable.
Turn the printer on.
Lift the printer's lid -- the print-carriage should slide the printer-heads to the "middle" position.
If all else fails, take the printer to a qualified technician, for more trouble-shooting.
Feb 02, 2010 | HP DeskJet 812c InkJet Printer
What indicates that the ink cartridges on the printer are out of ink?
Your print out will be very light and sometime it will print the blank pages.
Jan 28, 2010 | HP DeskJet 812c InkJet Printer
Printer is only printing pinks. Just changed ink
Try cleaning the print head. Do this under the tools for the 812c (do not physically clean). You may have to run the clean utility as much as 5 times.
Aug 17, 2009 | HP DeskJet 812c InkJet Printer
Hp deskjet 812c changed both ink cartridges but it will not print
It's Not possible to solve urself, contact service center
Jun 25, 2009 | HP DeskJet 812c InkJet Printer
My printer wont print in color & its a new color ink cartridge
have the printer preferences been changed accidentally to print in greyscale? Is the cartridge installed correctly? Now and again if the cartridges are opened and not installed straight away the ink dries up in the nossel and clogs the printer head, easily rectified with some cleaning solution. Cartridges also go out of date. hope this helped
daveywhite
Nov 11, 2008 | HP DeskJet 812c InkJet Printer
New color cartridge won't print in correct color
Was this a new factory ink cartridge or a refilled one?
I have seen some reconditioned/refilled with the color inks refilled in the
wrong section.
Sep 25, 2008 | HP DeskJet 812c InkJet Printer
HP DeskJet 812c InkJet Printer Logo
251 people viewed this question
Ben Johnson
