Question about Conair TAD2018CG Digital Answering Machine
Allow more rings
Need more than 4 rings before I answer, how do I do it. Thank you
I don't think you can - looking at the instructions, it appears to have a 2 ings, 4 rings or toll save option (I think TS means the machine picks up immediately).
Posted on Oct 17, 2008
  • 552 Answers
Click here for more info.
Posted on Apr 15, 2008
Picksup after two rings
You may need to go into settings and change the answering machine to answer on whatever ring you want it to. Some answering machines have an external switch that allow you to select 2, 4 or 6 rings etc.... Others need to be programmed in what is called a menu option. Your user manual can help guide you to change this setting
Sep 17, 2012 | Lands Phones
I cannot find my manual for AT&T 1710 answering machine. I want to change my answer response rings from 3or 4 rings to more. Can you help me?
The 1710 only has three options: two rings, four rings, and toll saver. There's a switch on the back that controls this.
The toll saver answers on the second ring if there are new messages, on the fourth when there aren't. This allows you to call in from a remote phone. If there are messages waiting, it'll answer on the second ring. If it rings at least three times, there are no new messages and you can hang up before you get charged for the call.
Unfortunately there are no settings for more than four rings. Sorry if that wasn't the answer you wanted to see, but there it is.
Feb 15, 2011 | AT&T 1717 Digital Answering Machine
I lost the manual, how do I set the day and time, and rings to answer. It picks up after 4 rings, can I set it for more rings? Thank you
I have this answering machine...
To set the day and time press the "REPEAT" button and hold it in. It will say something like "Time not set." and if you keep holding it it will say, "Monday." Now release the "REPEAT" button and use the "ON/OFF" button to cycle through the days. When it says the correct day, press and releasethe "REPEAT" button. Then it will go on to set the clock and you're done.
To adjust the rings, there is a slide switch on the top where the cords plug in. You can switch it to 2, 4 or TS (Toll Saver). Toll Saver generally lets it ring for about 5 rings before answering.
Nov 24, 2010 | Conair TAD2018CG Digital Answering Machine
I want to change the nombers of the rings to get start the answering machin
These are the instructions from the manual, which I found here:
http://safemanuals.com/user-guide-instructions-owner-manual/GE/21028GE3-A-_E
RING SELECT (FOR ANSWERING MACHINE)
This feature lets you select the number of times you want to phone to ring
before the answering system answers a call.
1. Make sure your phone is OFF (not in talk mode).
2. Press the MUTE/PROG button to go to the main menu.
3. Press CID/VOL (up or down) button to scroll to HANDSET SETUP.
4. Press MUTE/PROG button to confirm.
5. Press the CID/VOL (up or down) button to scroll to the RING SELECT menu.
6. Press MUTE/PROG button to enter the menu. RING SELECT 3 4 5 6 TS shows in the display.
7. Use the CID/VOL (up or down) button to scroll to the your selection. The default setting is 5.
8. Press the MUTE/PROG button to confirm. You will hear a confirmation tone and the new setting shows in the display.
NOTE: If you select Toll Saver (TS) the unit answers after the 3rd ring if there
are NEW messages, OR the unit answers after the 5th ring if there are NO new
messages. This allows user to access their answerer from another location and
then hang up after 4 rings to save long distance charges.
Oct 13, 2010 | GE 21028GE3 Cordless Phone
Night ring change the number of rings
Auto Attendant
Answer Lines
1 – Feature 983
2 – Log: Dial 1020000 (3-digit DNs) or 120000 (2-digit DNs)
3 – Press AA
4 – Press LINES
5 – Line number: Dial line number (001-xxx).
6 – Line:xxx Ans:No Press CHNG to AA if auto attendant will always answer theline. If a Night Service key will be used to activate auto attendant answering, leave Ans: at No.
7 – If line has been changed to Ans:AA, press * then press TABLE.
8 – If Table:1 is OK press RINGS. (Table 1 is the default greeting table. Change to a different table (1-4) if alternate answering is required on the line being programmed.)
9 – Rings:0 – Press CHNG, dial number of rings before auto attendant answers the line, or leave at 0 for immediate answering. Allow at least 2 rings if CLID is in use.
10 – Repeat for each line to be programmed.
Notes For Night Service Mode Auto Attendant Answering
If the auto attendant will only answer lines in night service mode, line answering should be set to No as per step 6 above. Using night service will cause the AA to answer lines immediately.
Feb 11, 2009 | NorStar M7324 Telephone
Change # of ringer on an AT&T 1717 digital answering machine
I am also trying to change the number of rings before the answering machines toll saver activates.
Jul 14, 2008 | AT&T 1717 Digital Answering Machine
ANSWERING MACHINE SET UP
To connect a standard answering machine to this phone, it needs to be wired to a DHLC port and XDP Mode has to be set to "Off." In addition, the Parallel Ringer feature needs to be set to "On" or your ringing phone won't ever ring the answering machine!
We have a support package that allows us to make all the changes you need over the Internet for a flat annual fee. If you want your whole system to work properly and all changes to be made for you at a flat budget, call us at 877-236-8376.
May 26, 2008 | Panasonic KX-T7633 Corded Phone
Number of rings
Looks like 6 is the Max, according to the Manual.
Setting the Ring Time
Ring Time allows you to set the number of rings the caller hears before your
answering system plays the outgoing message. You can set the ring time to answer
after two, four, or six rings. If you enable the Toll Saver (TS), the answering system
picks up after two rings if you have new messages and after four rings if there are
none.
1) Enter the Answ. Setup menu, and then the Ring Time
submenu (see "Entering the Menu Option" on
page 16).
2) Press volume up/down to select a Ring Time (Toll
Saver, 2 Times, 4 Times, or 6 Times).
3) Press the OK soft key. You will hear a confirmation tone.
Toll saver is a feature where you can call the phone yourself, if there are messages it wil answer in 2 rings, if not it'll answer in 4 rings. The idea is to hang up on the 3rd ring and save the LD changes.
Hope that fixed Ya...
Geno
Mar 27, 2008 | Uniden TRU8885 Digital Answering Machine
Panasonic 816 phone system
What you need to do is set the number of rings before answer on the phone to a number greater than the number of rings it takes before AT&T answers (for example, set AT&T to answer after 4 rings and the phone to answer after 5). Some phones have switches on them that allow you set the number of rings. Some make you set the number through their software. Look on the body of the phone, particularly the sides, for that switch and set it to the biggest number it offers.
Nov 16, 2007 | Toshiba DKT-2020 Corded Phone
Conair TAD2018CG Digital Answering Machine Logo
94 people viewed this question
Top Conair Lands Phones Experts
k24674
Hjalmer Lamminen
Hjalmer Lamminen
Are you a Conair Lands Phone Expert? Answer questions, earn points and help others
