Back to:
Tags:
Filter Queen Majestic Canister Vacuum
On/Off switch won't work.....I had taken the top... (by 2 users)
posted by egram49 on Feb 27, 2008
When I removed the top section of the vacuum (in order to clean it), the on/off flip switch dropped out. I tried to reinsert it (with great difficulty), but now I can't position it so that it actually makes contact with the button that is on the inside of the vacuum. Any suggestions??? Thanks
Marge
Comment by egram49, posted on Feb 27, 2008
Problem solved. I discovered an inner metal rod that I needed to put back into the proper position. After I did this, everything was fine. Thanks
Marge
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Guest, posted on Apr 16, 2008
My filter queen won't turn on. The red light is not on. Any suggestions?
Can you Help with these Vacuums problems?
I am looking for a distributor of Filter Queen products in...
Suction is about half the capacity it should be.
My filter queen just stopped working. The one off switch...
I can't find my manual for the filter queen and wondering...
i have a filter queen majestic model and i need to know...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
