Question about Freeplay Energy BayGen AM/FM/SW Radio
Spring broken? When i wind it up it unwinds real fast,and does not play,out of warranty.Is there a repair part for this?It's the early model,am,fm and short wave but no batteries.
  • Anonymous Jul 05, 2008
    spring unwinds real fast radio not working
Solution #2 is correct. My Baygen Freeplay radio was running fast and mine had a broken belt. I could not find a belt on eBay. After hours of searching the internet, I fond a replacement belt at http://www.kenselectronics.com/lists/belts.htm I have the older large Baygen Freeplay radio without solar power and this is the belt that fit my radio... AV-SBS9.5 Replaces SBX9.5 & 1407-36 & SCX9.5 square 9.5 x .047" belt, Baygen Freeplay. Just search the website above... they also have a second size Baygen belt that might fit the newer Baygen Freeplay radios???
Posted on Mar 14, 2010
After you take the two halves of the case apart there is a blue wire that comes from the 3v input jack on the back half of the case and goes to the radio circuit board near the top corner. The solder joint where the wire is soldered breaks easily. With this wire broken the generator will run to fast because there is very little load. The radio will still play if you slow the generator with your hand as it is playing back. If you resolder this wire the radio will work and the generator will run at the proper speed. This takes only a moment or two.
Please don't take the generator assembly apart, there is nothing wrong with it and the spring could come loose and hurt someone.
Posted on Nov 13, 2008
One of 2 things has happened: the drive belt has snapped or, a wire has come loose from the radio and now the generator has no load on it which will make it run fast and not play.
You will have to open the case and check. the belt can be bought on ebay (search for 'baygen belt') or re solder the loose wire.
Posted on Jul 29, 2008
Can you tell me where I can get my radio fixed at
Posted on Aug 10, 2009
Im having truble puting the starter cord and springs back in my husqvarna weed eater 128ld
You have to take it apart, get the spring back in, then wind the cord around around it. Not an easy task if you've never done it. A small engine repair or lawn mower repair shop will fix it pretty cheap and fast.
Apr 22, 2016 | Husqvarna 128 LD Weedeater
HOW CAN I REPLACE THE PULL CORD?
remove the three or 4 bolts holding the starter on the motor wind the spring loaded starter backward until you feel real good tension stick a screwdriver through the starter to keep it from unwinding thread the rope through the opening in the starter tie a knot in the end of the rope release the spring that should fix it.
Oct 20, 2015 | Yard Machines Cultivator 21A-121R900
I acquired a Craftsman Gas Blower model 358.794765 with the Sim-Pul starting system. The pulley was jammed with about 6 inches of rope hanging out. I took it apart and did not find anything broken. The...
Look at the housing where the spring should lay. There is a small shaped bend on the housing. This is where the bend of the spring should sit. Remove any tape on the spring before placing in unit. DANGER: Be careful not to move spring too much after removing and tape. It might unwind and fly into your face.
Sep 04, 2013 | Craftsman 25cc 2-Cycle Gas Blower/Vac
Cruise control doesn,t work
The clock spring is also broken inside of the steering column. A peice of metal that winds and unwinds as you turn the steering wheel. Not real common but they do occasionally break. This will also cause the airbag to not work.
Feb 10, 2011 | 2001 Dodge Dakota
My pull start cord won't retract. How do I fix it
Remove the starter assembly from the engine and pull the cord out--it should have spring resistance to pulling. If nothing, the rewind spring may be broken, or it may have pulled loose from one of the attachment points. Remove the cord from the pull handle and unwind it from the spool if it isn't already pulled out. Remove the spool from the frame to expose the spring--check the ends for breakage and the attachment points for damage (one will be on the under side of the spool). Repair or replace any damaged components and assemble the spring into the attachments. Wind the spool/spring about 2-turns CW, then wedge it to prevent unwinding. Fit the cord back into the spool and wind it CW until the cord has about 8" or so to feed out through the cord port. Fit the cord end back into the handle, tie an overhand knot, and push the knot into the handle bore. Remove the spool wedge and try pulling the cord several times to make sure it goes out and back smoothly. Return the starter to the engine and attempt starting. Hope this helps!
Nov 08, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have an early 1900 clock that I have to wind. I have noticed my clock stops frequently. I go to wind it and it is tight to wind so instead of over winding I tip the clock to start the ticking and the...
You can not unwind the clock yourself, because this requires proper clock makers tools and skills as well. Clock is stopping because it has not been serviced for a long time and the oil in clock has collected dust particles and getting sticky. This does not let the spring unwind freely and is a problem for all cogs and moving parts. Find your nearest clock repair shgop and ask for cleaning, oiling and adjusting. BE AWARE: If you are gonna try to unwind it yourself, you will damage the clock's movement, but most important - you can even brake or loose your fingers, as the clock spring is under unbelievable tension and once released, it uncoils lightning fast and is sharp as a razor.
Oct 28, 2010 | Seth Thomas Watches
The cable unwind on the roller,does it means the s...
You should be able to tell if the spring is broken by looking at them.
May 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
How to repair broken pull-cord
This usually happens at the most inopportune time. You go out mow the lawn, pull the rope and it comes out in your hand. Here's how to fix it yourself.
First, we'll talk about a simple rope replacement. In most cases you will have to remove the blower housing from the engine to get to the underside of the rewind starter where the rope is. We'll assume at this point that the spring is ok and you can just wind it back up again. You can check the spring by turning on the hub in a counter-clockwise direction and see if the spring gains tension. Do not try to remove the spring from its holder or you may end up having to take the mower in for service.
1. Remove the rope from around the hub. Since there is no tension, it should come right out. If you are lucky and it broke near one end, you can probably just re-use it. If it is badly frayed or too short, you will need to find a replacement at a local hardware store.
2. Attach the handle or tie a knot in one end of the rope so it will not wind all the way into the hub. You also may want to burn the rope ends to keep them from fraying and causing a problem in the future. Set the rope aside where you can grab it once you wind up the spring.
3. Wind the hub in a counter-clockwise direction using your thumb to keep it from unwinding, until the spring is tight. Then let it come back slightly so the rope hole in the starter housing lines up with the rope hole in the hub.
4. Stick the rope through both holes while holding the hub from unwinding. This is tricky because you don't want the hub to unwind on you before you have the rope secured in it. A pair of needle nose pliers or a small screwdriver or pick may help get the rope through.
5. Tie a half hitch knot in the rope after you have it through both holes. While holding the rope, release your hold on the hub and let the rope slowly pull itself back into the starter.
6. Put the blower housing back on and your ready to start the engine & mow.
Kurt
Mar 31, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Original Freeplay windup radio.
Tony,
Can't help you with the aerial. Mine made the same noise when winding down and I fixed that by pouring talcum powder around the windup section. Let it unwind and allow the talcum to go in,,,, and presto.......no more grinding noises.
Carlo
Jul 07, 2008 | Freeplay Energy BayGen AM/FM/SW Radio
Freeplay Energy BayGen AM/FM/SW Radio Logo
1,904 people viewed this question
Top Freeplay Energy Audio Players & Recorders Experts
RudeRude
John In Milford
John In Milford
Are you a Freeplay Energy Audio Player and Recorder Expert? Answer questions, earn points and help others
