StarLogic Monitor Problems
I have a 22 month old StarLogic 19" Flat Panel TFT/LCD Monitor. I leave both the processor & monitor on 24/7; however, they are set to go into System Standby mode after two hours. That turns the montior screen to black but leaves the power button lit. This A.M. as I sat down at my desk, I noticed the monitor was white & but the power button was unlit. After moving the mouse to wake up the processor, a few lines & alpha letters flashed across the upper half of the screen for about 1/2 second. The screen then returned to white & power button remained unlit. Pushing the power button had no effect, i.e., did not turn the monitor on or off. I unplugged the monitor from the power source & processor, let it stand for 10 minutes & hooked it back up. The screen returned to white & power button remained unlit. I hooked up another monitor to the processor & everything worked. I hooked up the StarLogic to another processor & got the same results, i.e., white screen & power button unlit.
Thanks for shedding any light on this problem.
Dave D.
Nowuser
  • 56 Answers
SOURCE: My Toshiba laotp's screen goes half blank help!!
Well try to boot into the safe mode.hit F8 on the startup and see if you get the same acreen.If its working fine in safe mode than you need to reinstall the video driver and that should resolve the issue.If it is still not working try connecting a external moniter.If you get the same display on the external moniter than its an issue with the video card and if you get a normal display on that than its an issue with the Laptop screen and you would ahve to get either of thses replaced by contacting the manufacturer.
Hope this helps!
Posted on Dec 26, 2007
SOURCE: Dell SE198WFP 19" LCD won't come out of standby
I went into the BIOS (with F2 during restart) and changed a value -- IIRC it was called something like "power management scheme" -- from the default S3 to the other choice, S1. Now the old Dell XP Dimension 2350 will go into and out of Standby correctly and the new SE198WFP 19" LCD will too.
Posted on Oct 08, 2009
AldRezaine
  • 995 Answers
SOURCE: Turn on the computer, botton half starts out white
There is a problem with your display monitor, bring it to the computer repair center in your place to get it fix.
Posted on Nov 01, 2009
damnor01
  • 1179 Answers
SOURCE: Product: LaCie 2big quadra ((Professional 2-Disk
If the failed hard disk drive is replaced with the exact same capacity, RPM and make of hard drive, then the array can be rebuilt. Raid 0 cannot be rebuilt as each drive contains half of the data, If RAID 1 then can be rebuilt as data on each drive is an exact copy. However if combination of RAID 0 and RAID 1 then can be rebuilt. It's best really to handel this hands on, I recommend taking it to a computer technician especially if the information on it is important.
Thanking you
damnor01
Posted on Nov 13, 2010
mmessner1
  • 269 Answers
SOURCE: I have a TERASTATION PRO
no i would concentrate on the date time issue than see if you have any more problems i wish you the best of luck and if it works out OK please give me a good vote
Posted on Nov 29, 2010
Monitor displays out of range
reduce the screen resolution and then connect the monitor
Aug 12, 2014 | Star Logic Starlogic 17" Tft Lcd Monitor...
My gateway 24-inch lcd monitor will not power on, have unplugged, switched connections, power plugs etc. and it will not power on. computer powers up just fine, but nothing with the monitor. its approx. 3...
The monitor power supply has probably failed. Replace it or replace the monitor (3 years is the longest warranty on most monitors). One way to check this is to put a different monitor on the computer and make sure that the video signal is available.
I wish that I could be of more help.
Jul 23, 2010 | Gateway 24" Widescreen Flat Panel TFT LCD...
Over Range Signal
OK, you need to boot up in safe Mode, then change your screen resolution, to say 800x600, or 1024x768, this will then allow your monitor to operate, IF this doesn't work, then you will have to swap out, the Monitor and VGA card to find out which one is faulty.
May 22, 2010 | Star Logic 17" LCD Monitor
I have a E machines 19" widescreen flat panel computer monitor that is only 6 months old. For the last few days when I power up my computer, the monitor comes on for 1 or 2 seconds then flickers and goes...
Open the monitor, examine the circuit boards. Look for small components that look like small cans, these are capacitors. If you see any that look bulged on top, then your problem can probably be solved by replacing these. Check out the following sites;
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Follow the directions and good luck!
Jan 04, 2010 | E-Machines 19" Widescreen Flat Panel TFT...
Starlogic 19" flat panel screen won't show anything.
Have you made sure that all the cable connections are screwed in tight?
You could also remove the cable to make sure that none of the pins have become bent out of place.
Sep 11, 2009 | Computers & Internet
Monitor boots ok, then "Analog" appears/monitor shuts off
Does it have a digital port being used? If you are using the DVI port, it is probably digital. Try using the menu to selct the port. If it doesn't work, not sure from here. What is the model number?
Aug 01, 2009 | E-Machines 19" Widescreen Flat Panel TFT...
Hi My name is denise, I have the invision 22" Moniter can you tell me are there build in speakers on the moniter.
http://www.testfreaks.com/blog/review/22-envision-g22lwk-dvi-widescreen-lcd-monitor-wspeakers-black/
Here is a review of the monitor, it says it does have speakers, but not very good review, but most if not all speakers that are built in are not great. I hope this helped, Gym
Dec 21, 2008 | Envision 19" Widescreen Flat Panel TFT LCD...
Black flickering line vertickally through monitor screen
It could be either of these:
You're monitor is dying and you need a replacement (Starlogic brand is notorious for dying early and giving poor performance)
You're graphics card is going out. If you have an extra monitor laying around, take out the Starlogic one and plug in the other to see if the same results occur, if not, it's the Starlogic monitor, if the problem still persists, you need a new graphics card or need to update your current drivers.
Dec 15, 2008 | Star Logic (11004998) (Black) 15 inch LCD...
MAG Innovision 19" TFT LCD Flat Panel Monitor
the monitor has bad backlights or circuitry. Call the company, their number should be in the owners manual. Or, look on the web for their website. Or, call the store where you bought it. The monitor must be taken to a service centre for repair.
Mar 26, 2008 | Mag Innovision LT976S 19" Flat Panel LCD...
Computers & Internet Logo
222 people viewed this question
David Payne
David Payne
