Question about Toshiba Satellite M35X-S3112 (PSA72U2KX00X) PC Notebook
Usb not working
All 3 usb2.0 are not working.
  • a67994 May 11, 2010
    Do you know how to Enter the BIOS?
    Is your Motherboard update to date?
  • Toshiba Master
  • 13,433 Answers
Hey,
the motherboard is most likely faulty, or usb ports are hosed.
Try a multimeter and see if you get 5 volts from pin 1 and 4
pinout: http://pinouts.ru/Slots/USB_pinout.shtml
Thanks and good luck.
Ekse
Posted on May 05, 2009
  • Ekse May 05, 2009
    also check if the drivers are missing, open device manager in windows, right click on my computer select manage, then on the manage window on the left side open device manager and see if the usb ports are installed.
    if they are all fine and no usb devices work. then you have a major problem. you can try installing windows or use recovery discs to recover the laptop and if the problem is still not solved its a hardware problem.
    Good luck.
I have a CanaKit Raspberry Pi 3. My USB mouse works fine until I plug an additional item into the USB above it.
You mouse may be using to much power. Sometimes while using older computers such as laptops and desktops newer technology consumes loads of power. Try using an older mouse and try seeing if you can plug camera in then mouse. If the mouse work and the camera doesn't it almost ensures a power problem.
May 22, 2017 | The Computers & Internet
Hi, I'm facing following problem, can any one help me please? Seagte external hard disk GoFlex Desk 1TB (STAC1000300) with USB 3 adapter STAE 106 is not working. When the USB 3 cable is connected to...
just install seagate free agent using this link
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=goflex-software&vgnextoid=11c1fab114b48210VgnVCM1000001a48090aRCRD
then try again if problem not solved, mail me to tsnp@ymail.com
Apr 19, 2011 | Seagate FreeAgent GoFlex Desk Desktop...
Usb 3.0 driver for ibm t43
the ibm t43 doesnt have usb 3 it can only use usb 2 if you have a usb 3 device then it will still work at the usb 2 level as all usb devices are backwardly compatible
if this info helped you please vote for me
Feb 27, 2011 | Computers & Internet
My toshiba laptop usb input pots does not detect usb flash memory and printer
1. Check whether USB/Chip set driver installed properly or not. 2. Check if a USB mouse or Keyboard working other then flash memory or printer. If working then your USB port is disabled in windows registry. 3. To enter the registry, got to Run, type regedit, Enter. 4. In the registry follow the path, HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\usbstor 5. Check the value of the key START. 6. If the value is 0x00000003 (3) then OK. if the vale is 0x00000004 (4), then change it to 3. 7. for changing double click in Start key, a window will pop up. change the value from 4 to 3 then press enter. 8. Close the registry. And check the printer and Flash drive is working or Not.
Note: be careful while working with registry.
Aug 19, 2010 | Toshiba Satellite A205-S4617 Notebook
The flip mino hd usb won't plug into most of my usb ports (And yes, I know the difference between a firewire and usb). I have tried it on four different computers with a total of 10 usb ports. it worked...
My flip mino hd USB also will not plug into my MacBook Pro.  I've tried it on 3 different machines and it will only fit into one port, and not at all easy into that port.  When I look at the USB connector on the device, there appears to be slight raised plastic ridged on the outside ends of the connector.
Dec 26, 2009 | Pure Digital Flip Mino Digital Camera
All lights on Dualshock 3 blink 5 times, then do nothing.
On the back of you dualshock pad next to the L2 button there is a tiny small hole witch looks like it could be a screw hole ! well this is the reset button once you have pushed this you will be able to conect your pad to your usb cable and it work on your console again
Aug 30, 2009 | Sony Dual Shock 3 Controller for...
PANASONIC MD NV 10000
i do not understand,do you connect all these cables at the same time?If yes is wrong ...Just connect in a well known pc the fire wire cable and power on camcorder.If pc doesn't capture video,THEN look after editing program...
Jul 27, 2009 | Panasonic NV-MD10000 Camcorder
PS3 Controller will only work when plugged into the USB
I picked up the folling troubleshooting tips from the PlayStation Knowledge Center. I know it may seem silly or insulting; This is not my intention. Problems like this are usually just little things you're over-looking. Give thest tips a shot, one by one, and see if your solution is in here. If it isn't, message me back here & we'll try something else to get your controller working, ok? By the way... Is it a sixaxis controller or dualshock?
  • Verify if the SIXAXIS or DUALSHOCK 3 wireless controller works with the USB cable.
  • Verify that the SIXAXIS or DUALSHOCK 3 wireless controller's battery is charged.
  • Attempt to pair the SIXAXIS or DUALSHOCK 3 wireless controller to another PLAYSTATION 3 system. This helps determine whether the problem is with the system or the controller.
  • Attempt to connect another SIXAXIS or DUALSHOCK 3 wireless controller to the PLAYSTATION 3.
  • Move closer to the PLAYSTATION 3 system. The maximum range for Bluetooth is 30 feet.
  • Make sure you have less than seven Bluetooth peripherals paired with the PLAYSTATION 3.
  • Unplug any other USB device plugged into the system when pairing the SIXAXIS or DUALSHOCK 3 wireless controller.
May 19, 2009 | Sony Playstation 3 (PS3) Console
Missing USB controller driver
When posting driver issues, you need to specify what kind of equip you are dealing with, not just the issue. Most liekly you need to go to the manufacturs website of your motherboard or laptop and find vista drivers for it.
Jul 29, 2008 | Acer Aspire 5100 Notebook
USB Ports Stopped Working
Check in MSI.com and see if there is a firmware upgrade for that particular motherboard.
Jul 14, 2008 | MSI RS482M4-ILD Motherboard
Toshiba Satellite M35X-S3112 (PSA72U2KX00X) PC Notebook Logo
67 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
