Question about SanDisk Sansa Clip MP3 Player
Sansa clip synch problem
Hi,my 2G clip does not seem to be recognised by myWMPv11.
I have vista and have tried changing the usb settings on the clip however the player just doesn't want to know.
I am able to drag and drop ok and the clip plays well but would like to be able to synch it.
Any advice appreciated guys.
Ps,THE CLIP DEFINTELY HAS LATEST FIRMWARE INSTALLED.
Thanks,Sean
  • 8,596 Answers
Make sure the songs you are trying to sync do not have DRM-encryption on them. Converting to mp3 format is the best way to make them sync-able. Otherwise, you can find DRM removal software.
Also, reformat the player in Windows Media Player 11 - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything. Your player should be sync-able in WMP-11 now.
-Tha Mp3 Doctor
Posted on Mar 17, 2008
It wont read in windows media player but i unplug it does but every time i plug it in it just makes it slow
If you recently updated the software online it may have changed the USB setting on your sansa. Go into settings - USB mode and select MPT. Windows media player should then recognise your sansa. Hope this helps.
Jun 02, 2011 | SanDisk Sansa Clip MP3 Player
HOW DO I CHANGE MY SANDISK SANSA CLIP+ 2G LANGUAGE TO ENGLISH?
Welcome to Fixya. In order for you to changed the Language on your Sansa clip mp3 player, just follow the steps below.
1. Press the "Menu" button (located on the right part of your mp3 player)
2. Move to "Settings" and then press the center button to select it.
3. Select "Language".
4. Then select the deisred language.
Please let me know if you have any questions.
Thank you for using Fixya,
seancarlisle
Apr 29, 2011 | SanDisk Sansa Clip MP3 Player
Won't load audiobook because clock is not set
Had the same problem - used this solution from ehow.com at this web address: http://www.ehow.com/how_5180421_troubleshoot-sansa-clip-mp.html Worked and now I'm transferring my book from overdrive - hope it helps. Reset the Clip by holding the On/Off switch in the On position for approximately 20 seconds. Release the switch, then attach it to the USB adapter to charge it. This process can help when the Clip does not appear to be working at all.
Dec 16, 2009 | SanDisk Sansa Clip MP3 Player
Mp3 player malfunction
1. Try updating the drivers-
- Right click "My Computer", choose properties
- Click the hardware tab and choose Device Manager
- See if you find the name of the device there - if yes, Right click on it and choose "Update Driver"
2. Try changing the mode to MTP
3. If nothing works, unplug the USB cable, Lock the device, Push the round button in the middile of the Sansa player, continue holding it and plug in the USB cable.
4. One more option you could try -
  • turn off your mp3
  • press the hold(lock)button down to activate it.
  • press the center button and keep it pressed ..
  • connect the USB cable supplied with the device always pressing the center button,
  • connect the other end of the cable to a USB jack on your PC.
  • From there it should work properly.
Dec 14, 2009 | SanDisk Sansa Clip MP3 Player
My sansa clip ipod is not recognised by any computer
On your sansa, go to "Settings" then System Settings" then "USB Mode," then change it to MSC, if that does not work, try the other modes, just n case.
Hope this helps!
Jul 22, 2009 | SanDisk Sansa Clip MP3 Player
Connecting Problem
Unplug your Sansa. Uninstall all the Sansa software from your computer, and reinstall the clean version from the Sandisk website. Then, replug the Sansa.
-Tha Mp3 Doctor
Nov 15, 2008 | SanDisk Sansa Clip MP3 Player
Sansa synch problem
Change the Rip settings in Windows Media Player to convert the CD to mp3 format and then re-synch it - it will work. WMP probably synched it as a raw CDA, which the Sansa cannot recognize.
-Tha Mp3 Doctor
Oct 18, 2008 | SanDisk Sansa Clip MP3 Player
To help you with that, I need to know what operating system your using (XP, Vista, ect...) and what other devices you have plugged into the computer. There are a few things you can try. When you plug it in, does it say it's connected? Does the "Found new hardware" wizard come up? Let me know, I'll see what I can do to help
Dec 31, 2007 | SanDisk Sansa Clip MP3 Player
PC won't detect sansa e280 please help me
I had the same prob with my e280 yesterday and i bought it 4 days ago. I'm using a vista o.s. and i found a way to transfer files this morning. if you are using a vista os you should first set your sansa to MTP mode so that your windows media player can detect your e280 then you can start synching. If you are using XP o.s. there shouldn't be any prob with that but you have to switch to MSC mode. you can find these settings on the setting menu of your e280 then USB mode.you can also open the E280 player if you see it on "my computer" there you can transfer the files.don't use your wmp player when you are doing this on vista cuz the wmp player will also synch at the same time and it will synch the same file.
Jun 12, 2007 | SanDisk Sansa e200 MP3 Player
Recognise my sansa
to old for vista to recognize
Apr 29, 2007 | SanDisk Sansa m240 MP3 Player
SanDisk Sansa Clip MP3 Player Logo
137 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
