Need a free service manual for a HP Pavilion ZT3349cl laptop so I can replace internal power connector
  • 47 Answers
You can check this site, where you can find information on how to disassemble laptops.
http://repair4laptop.org/notebook_howto_faq.html
http://www.irisvista.com/tech/laptops/first/first.htm
Posted on Mar 01, 2008
What type of cmos battery
Most of computers (laptops and desktops) use a CR2032 battery. The bargain battery can be purchased at 99 Cents store. I like Panasonic brand name.
Feb 16, 2014 | HP Pavilion zt3349cl PC Notebook
How do I remove the case on my HP pavilion dv6745 laptop
Download a copy of the Maintenance & Service Guide for your HP Pavilion DV6745 laptop and follow the Removal & replacement procedures chapter for instructions on opening the laptop case and replacing internal components.
Jan 02, 2012 | HP Pavilion DV6745US Notebook
Need a replacment or new motherbord for tx1410us
1) http://www.sparepartswarehouse.com/HP,Pavilion,tx1400,KC469UA,Laptop,System-Boards.aspx
2) http://www.pelltechnology.com/HP-Parts/HP-Pavilion-Laptop-Parts/HP-Pavilion-TX1000-Series/HP-Pavilion-tx1400-series/HP-Pavilion-tx1410us/Motherboards-%26-LCD-Screens/
The Pavilion tx1410us Notebook PC is one of the Pavilion tx1000 series of Notebook PC's.
Here is the download page for a free Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-compaqhp
Go to the 18th line down. The line that starts with HP Pavilion dm1.
Go to the second line and across to tx1000.
Left-click on tx1000.
This is a PDF file. You may not see anything happening for up to 30 seconds after you click.
The file is downloading in the background.
After you see the first page it may take additional time for the file to fully download.
Suggest you let the file download all the way before looking through it.
Nov 25, 2010 | HP Pavilion tx1410us Tablet PC
Repair manual for HP Pavilion dv6 1245 dx
Go to hp.com. Click on support and drivers tab. Select "See Support & Troubleshooting Information." Enter your laptop model number. dv6-1245dx. Click on "GO". See: "What Type Of Support Do You Need?" Choose MANUALS. Scroll down the page and select "HP PAVILION DV6 ENTERTAINMENT PC - MAINTENANCE AND SERVICE GUIDE". Download that PDF format. It is relatively easy to get to the ribbon cable that connects the touchpad to the motherboard. It is connected via a ZIF connector. I had a dv1331se and the touchpad stopped working. I just reseated the cable in the connector and all was well. Hope your solution is as easy as mine was. You'll have to remove the trimplate just in front of the keyboard. Be careful with the connectors there. The manual is well laid out and the diagrams easy to follow. Good luck. HP Pavilion dv6 Entertainment PC - Maintenance and Service Guide
Mar 16, 2010 | HP Pavilion dv6000z Notebook
How to fix HP Pavilion DV6405US internal power connector broke won t charge
It pays to determine if the fault is the laptop's power socket first.
Please read the following and carry out the tests to determine the fault.
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, until they won't charge up at all.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Nov 29, 2009 | HP Pavilion DV6405US 15.4" Notebook PC PC...
User manual wanted
Sir, you can get the service manual at http://online.manualspace.com/notebook-computers-free-ebooks/hp-notebook-service-manuals/4427/hp-pavilion-ze5400-notebook-pc-service-manual-230.html
Sir, you can get the Startup User guide at http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/bph08615/bph08615.pdf
Sir, The service manual is just an additional information as I thought you can need it, Thank you Sir.
Sep 24, 2009 | HP Pavilion Notebook
Power source connection to my HP Pavilion dv 8000 disconnects often and connector must be reinsertd and jiggled to establish ac power supply
YOU SHOULD CHANGE THE CONNECTOR BEFORE IT BLOWS UP THE POWER IC'S THAT LINK TO THE CONNECTOR
IT'S A BIT LOOSE
Sep 12, 2009 | Computers & Internet
Where can i find a reference for removing the motherboard in my ZV5330US laptop? I need to replace the power jack. Have parts, just want to get at it with minimal heartache!
I replaced the same part in my HP dv2113 laptop. I found the service manual on hp’s web site. It appears from my research that this is a common failure. I can tell you that even with the detailed instructions it is a big job. The entire laptop is disassembled before you can reach the small board with the connector on it. Poke around HP and you will find the book I am sure. Good Luck
Jul 22, 2009 | HP (350827-001) for Pavilion ZV5000,...
Power cord failure to make a good connection
contact the company that makes your computer/laptop.... you need to get a new power cord
Sorry to inform you of this, but i have had this happen before and a replacement power cord was necessary. If you are lucky, like i was, they might send you a replacement for free
May 01, 2009 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
77 people viewed this question
Alun Cox
David Payne
David Payne
