Question about Mintek MDP-1770 Portable DVD Player
Mintek 1770 dvd
Put in a dvd and it shows loading. Then it shows "no disc" Any solution to problem??
  • 1 more comment
  • dochallada Mar 01, 2008
    Tks for the info. Will try to clean the sensor and hopefully that is the problem. Apprec rapid comeback./doc
  • ssdrums Apr 29, 2008
    put in dvd and it sounds like its trying to load but no picture ever comes up and it sounds like it bogging down
    what does TFT stand for and what does it do
I agree w/headthtreads.
Usually the kids have had a hand in this.
No offense, but it happens.
Dest deffense is to replace the head, then make sure the kids don't get a chance to do it again.
Regards,
Posted on Oct 26, 2008
    Problem Solver:
  • 11 Answers
This usually can only be be three things. First, it could be the DVD. If thats not it, the sensor on the DVD can be dirty. You can use one of those computer air cans to clean the insides out(usually). If not, you have a bad sensor. Most of the time, when i have issues with DVD players, thats usually the culprit. In which case, I hope you saved the receipt because you probably have to return for an exchange or refund.
Posted on Feb 27, 2008
My Mintek 1770 dvd player will not load the disc because when the lid goes down the little plastic pointer does not properly engage the button that starts the DVD spinning when the lid is closed. If I try...
if you look on the top cover inside you should see a round plate that sit on the DVD when you close the cover if this plate press hard or loss it will not have the correct speed in this plate there is a clutch see if its not to lose
hope it will help
Aug 24, 2010 | Mintek MDP-1770 Portable DVD Player
Tip
Mintek factory solution for the forever loading disc problem.
With the power turned off, open the DVD Player, and then open the top where you load the DVD into the player. Locate the laser lens and notice that the laser is attached to a transport assembly that moves the laser diagonally outward in a slot. 1. Slide this assembly outward to the end of its track. 2. Slide the assembly back inward to the closest inward position. 3. Repeat the process of sliding the assembly outward and then back inward.4. Put in a music CD and let it play all the way through. This helps to calibrate the laser head assembly movement. When the music CD is finished playing. 5. Put in a DVD, and you should have a working unit again This is a factory solution from Mintek that was given to a customer who ask for help with the forever loading disc problems. This solution may work on other models of portable DVD players. Most portable DVD players use this type of transport mechanism. Try this solution it might work for you.
on May 29, 2009 | Mintek MDP-1770 Portable DVD Player
When I put in a disc it says it's loading; however, it keeps showing "no disc".
when I put in a disc it says it's loading, however it keeps showing "no disc"
Oct 27, 2009 | Mintek MDP-1760 Portable DVD Player
I was given a mintek dvd player model mdp-1770 it is say no disc when there a dvd in it i have tryed recalbreting it by sliding back forth four time then loading a cd but it still reads no disc
If the unit plays CDs but not DVDs, then the LED for DVDs is burned out. There are separate LEDs for CD and DVD operation.
If neither plays, there is a more fundamental problem. In any case, only factory service will correct the problem with your "white elephant".
I have exactly this model.
Oct 07, 2009 | Mintek MDP-1770 Portable DVD Player
WILL NOT PLAY A DISC
Apr 03, 2009 | Mintek MDP-1770 Portable DVD Player
Dvd player not reading disk
Feb 21, 2009 | Mintek MDP-1770 Portable DVD Player
Mintek mdp-1720
http://www1.epinions.com/content_209566011012
Try this link from someone with the same problem, and a possible solution. It is simple & got my player working albeit temperamentally.
Jun 07, 2008 | Mintek MDP-1770 Portable DVD Player
Mintek MDP-1770 Portable DVD Player Logo
101 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
