Question about Samsung SGH-U600
I Phone can't get a wi-fi connection on my i phone. it's acknowledges my wireless conection but when i put in my pass word it won't accept it
    Novelist:
    Scholar:
  • 111 Answers
Here is the area for Samsung U600. I suggest you to look for iphone area where you may get the same solution for your phone. You should need to set your ip address on your phone similar to your primary PC which is running and have a best connection. Your passwork must be similar to the first time you setup your PC. Good Luck
Posted on Feb 28, 2008
My laptop connects to the wireless network but my phones can see the network but won't connect to my wireless network
Hi David, try turning your cell phone off then on.... If still no Wi-Fi Hi, and you're trying to connect to your home Wi-Fi The password is on the back of the modem in the house, Write it down then go into your phone/tablet settings and tap "CONNECTIONS", Then tap on Wi-Fi and make sure it's switched on(should be a button there), Once switched on it should start scanning automatically for networks, but if not then there's a scan button there somewhere. When it finds the modem just tap on it and a small window opens for the password, Type in the pass word tap ok and you're connected... Bellow is a link to a short youtube video explaining pretty much the same thing I said..... I hope this helps..., CHEERS..
How to Connect My Phone to My Internet Using Wi Fi Wireless Keeping Up...
Apr 08, 2016 | Computers & Internet
HOW TO CHANGE THE INTERNET SETTINGS IN THE HTC WILDFIRE A3333
Wi-Fi provides wireless Internet access over distances of up to 100 meters (00 feet).
To use Wi-Fi on your phone, you need access to a wireless access point or "hotspot". The availability
and range of the Wi-Fi signal depends on the number, infrastructure, and other objects
through which the signal passes.
Turning Wi-Fi on and connecting to a wireless network
From the Home screen, press MENU, and then tap Settings > Wireless & networks.
Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless
networks.
Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks
are displayed in the Wi-Fi networks section.
If the wireless network you want to connect to is not in the list of detected networks,
scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network
settings, and then tap Save.
Tap the Wi-Fi network you want to connect to.
If you selected an open network, you will be automatically connected to the network.
If you selected a network that is secured with WEP, enter the key and then tap
Connect.
Depending on the network type and its security settings, you may also need to enter more information
or choose a security certificate.
When your phone is connected to a wireless network, the Wi-Fi icon appears in the
status bar and tells you the approximate signal strength (number of bands that light up).
The next time your phone connects to a previously accessed secured wireless network, you
will not be prompted to enter the key or other security information again, unless you reset
your phone to its factory default settings.
Jan 28, 2015 | HTC Wildfire A3333 Cell Phone
Wi-fi won't turn on
Hi, go into manage connections,
then wifi network,
then search for your wireless,enter pass key if needed,
then save.
Your phone will automatically connect to your Wifi any time you are in range.
My son has a blackberry and thats how I connected his.
Hope this helps.
Mar 08, 2012 | RIM Blackberry Curve 8900
How can i connect wi fi to this phone
go to settings, select " Wireless & Networks "
select "Wi-fi" ( It will turn the Wi-fi on )
after the "Wi-fi" is on, then select "Wi-fi settings"
then you will see some Wi-fi networks.
then select the wi-fi networks you know, and depend on the security of the Wi-fi, you sometime have to enter the pass key to get in to the network.
hope it helps.
Jan 24, 2012 | TvShows Android Apps
I have the GT 15510M samsung phone, howdo i connect to the internet from my wireless at home?
Your mobile has a built it Wireless Fidelity or WI-FI module enabling to catch ata over wireless networks.
By turning ON your wi-fi, it will search wireless network along the nearest location of yours. Once you found a network(s), just open it and wait until established and connected,but some authenticating connection never allows you to connect because it needs a password encryption.so you won't able to patch the network if you do not know the code.
If you have a broadband installed at home, you need a wireless router that can supply internet connection using your mobile phone via wi-fi,just easily series the broadband connection thru a wireless router and also add encryption like WEP key to ensure you are the only one catching the connection.
please state your broadband if any so that i can guide you the procedure in installing your wireless router connection.
If you have some questions, don't hesitate to reply cause i will glad accomodate any comments.
Thank you for visiting FixYa..
Jul 03, 2011 | Samsung Star GT-S5233 Cell Phone
WiFi just scans but does not find any available networks to connect to??;le
Hello Derek,
Connecting Wi-Fi in HTC Desire Cell Phone
From the Home screen, press , and then tap Settings > Wireless & networks.Select the Wi-Fi check box to turn Wi-Fi on. The phone then scans for available wireless networks.Tap Wi-Fi settings. The network names and security settings of detected Wi-Fi networks are displayed in the Wi-Fi networks section.If the wireless network you want to connect to is not in the list of detected networks, scroll down the screen, and then tap Add Wi-Fi network. Enter the wireless network settings, and then tap Save.Tap the Wi-Fi network you want to connect to. If you selected an open network, you will be automatically connected to the network. If you selected a network that is secured with WEP, enter the key and then tap Connect.
Jun 02, 2011 | HTC Desire Cell Phone
How do i get my phone to connect to the internet
You must have internet service, example an anything data plan. Then all you do is tap on the internet ball and it conects.
May 24, 2011 | HTC Desire Cell Phone
How to put wifi in that phone??
Thanks for visiting FixYa!
The Mototola Droid Cell Phone has WLAN from the factory. That is, it has Wi-Fi 802.11b,g. So, you don't need to install it. Wi-Fi is already in the phone.
Here is a link to your owner's manual in case you don't have one handy. http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/DROID-by-Motorola/US-EN/Documents/Static-Files/DROID_UG_Verizon_68000202474a.pdf
To connect to Wi-Fi see page 4 of your user guide for instructions.
Wi-Fi connect
To connect to an available Wi-Fi router, touch Menu Key (bottom of the phone and just left of the center of the phone) > Settings > Wireless & networks > Wi-Fi settings. (And turn Wi-Fi on.)
Feb 19, 2011 | Motorola Mobility Droid (2 GB) Cell Phone
Am having trouble findind my wifi coneection for my osns phone , how can i connect it to my home hub . plz
1st switch on ur Wi-FI from setting menu. then search wireless connection, (pls make sure ur home wi-fi is tuened on) if found any signal, just connect it it will ask for pass key or key. just entered it. (pass key is configured in ur home wi-fi router) u will able to surf internet from ur mobile................
Feb 04, 2011 | Samsung Star GT-S5233 Cell Phone
How conect to internet wireless ? whit a archos 5
you can connect it via wi-fi or via bluetooth..
if you have a router near you archos will get connected with that router through wi-fi and you'll be able to go online.
if you have a 3g and bluetooth enabled phone with you pair that phone with archos via bluetooth so that archos can use phone data plan for browsing the internet.
these are the two ways by which archos will get online
Sep 30, 2010 | Archos Internet Media Tablet MP3 Player
Samsung SGH-U600 Logo
16 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
