Disconnect power to dryer.
Take screws out above door, allowing dryer top to swing up and back.
Remove screw near top from side panel into front panel, allowing front panel to be removed and set to the side.
Some models have a very small access panel at the very center of the drum on back, which may hide an " E " clip on the drum shaft, which would have to be removed, all other dryers no longer use them. Lift dryer drum up slightly and pull it forward a couple inches. (you do not need to remove the belt) Remove all the loose washers / sleaves on the back shaft of the drum and install a new WE3X75 rear drum bearing, then re-install drum. (no need to put the E clip back on.)
Check the drum slides on the bottom front side of the drum. Most times, if the rear bearing is in need of replacement, so are the front drum slides, especially the one on the left (blower / motor) side.
Just trying to lubricate it will not solve your problem.
