Wont print says its ready
I am trying to print a document from a laptop with vista.
When i go into the actually settings on the laptop it says its ready but when i look at the little box that shows whats printing and the status it says its deleteing one of the documents but its taking ages. how do i print as its very important as its for coursework.
Remove the USB cable from laptop, reboot the laptop. Turn off the printer and turn it back on. Once you are in windows, plug the USB cable back in. Sometimes the machine will lose it's connection. By doing the above steps will renew the connection. ope that helps.
Posted on Feb 27, 2008
What is wrong with my HP Deskjet D2330, and why is it printing only blank pages?
well it has got to be the ink cartridge. wipe of the bottom of it and make sure black ink shows up
Dec 10, 2014 | HP Deskjet D2360 InkJet Printer
Will only print maybe one page of a 4 page document and sometimes wont print at all
Below are 3 possible solutions.
Unexpected page breaks occur
Cause Solution
Job has timed out.
Set the Print Timeout to a higher value:
Blank pages
Cause Solution
Toner is low.
Remove the toner cartridge from the printer. Shake the cartridge back and forth several times, and then reinstall it.
Install a new toner cartridge.
Toner cartridge is defective or empty.
Replace the toner cartridge.
Jobs do not print
Cause Solution
Printer is not ready to receive data.
Make sure Ready or Power Saver appears on the display before sending a job to print. Press to return the printer to the Ready state.
Specified output (exit) bin is full. Remove the stack of paper from the output (exit) bin, and then press .
Specified tray is empty. Load media in the tray.
Wrong printer software is installed.
Verify you are using the correct printer software with your printer.
If you are using a USB port, make sure you are running Windows 2000, Windows XP, Windows Server 2003, or Windows Vista and using Windows ME, Windows 2000, Windows XP, Windows Server 2003, or Windows Vista compatible printer
software.
Cause Solution
Internal print server is not set up properly or is not connected properly.
Verify that you have properly installed the print server and configured the printer for network printing. For more information about installing a network printer, click View User's Guide and Documentation on the Software and
Documentation CD. Copies of the printer software are also available on the Lexmark Web site at www.lexmark.com.
You are using the wrong USB or Ethernet cable, or the cable is not securely connected.
Make sure you are using a recommended cable.
Make sure the connection is secure.
For some reason Lexmark has not posted information for this model. If you need a manual you might try the C534 manual at: http://support.lexmark.com/index?locale=en&page=product&productCode=LEXMARK_C534&segment=SUPPORT&userlocale=EN_CA&frompage=null#2
Dec 10, 2010 | Lexmark C533DN InkJet Printer
I have a big problem with my HP Photosmart C3100. Whenever I try to print, either nothing or very little is actually printed. I've checked the ink, and it's almost full. I've tried printing a...
Connect the printer to a different computer (laptop? desktop?)
and install the HP device-driver software, and try to print.
If it works correctly, then it's your computer that has a problem.
Jul 30, 2010 | Office Equipment & Supplies
Single page printing
OK, well when printing from the internet it quite often only prints the screen you are on, I presume, because you likes what you read, you wish to print it, well as you are on Page 3 the end of the document, thats what get printed. You actually, need to go to the File Menu, select, Print, and actually select, the type of print, there are options, Print ALL, Print Page, Print Selection, you need to set that, it sometimes remembers a setting and perhaps 3 was the last setting.. In any event don't just "Hit Print" you have to do as related, I am not sure if you can set up special "Print Now" parameters, but I expect you can, choose a "Default" setting.
Mar 31, 2010 | Lexmark X5650 All-in-One InkJet Printer
I have a Toshiba Laptop that wont work with any printers
have you checked the paper settings that the printer prints? often the printer has letter format as first print options, and then it doesent work. you need to change it to A4 in printer settings.
What happends when you trying to print ?
Sep 04, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Authorware Printscreen doesnt print actual document fullsize
Try printing document thru your printer rather than Printscreen feature. Or Printscreen feature copies to clip board which you should be able to open and paste to new document then use your printer set up to adjust. Make sure your printer set up is set to scale to fit page.
Aug 24, 2009 | Adobe Macromedia Authorware 7 Full Version...
Printer wont print from computre.
try with test print
change the property of offline (untick)
check for any other printer installed on the computer
Apr 09, 2009 | Computers & Internet
Hp 5610 won't print
If you need Vista drivers for your printer, go to HP.com to get them and see if that works.
Jun 17, 2008 | HP Officejet 5610 All-In-One InkJet...
Panasonic DP 1520P - wont print
Hi, I have solved my problem posted 5/2/08. Download the gdi driver from Panasonic website as I did above.
Install printer via Control panel, "Add printer" and browse to locate driver. If you do it automatic through the USB it will not work. Mine WORKS now!! Do check that the paper size is A4 also.
All the best...
Feb 05, 2008 | Panasonic WORKiO DP-1520P All-In-One Laser...
80 people viewed this question
k24674
jasbo
jasbo
