Question about Samsung HL-S6186W 61" HDTV
TV turns off by itselft
I own a Samsung DLP tv model HL-S6186W a about twice a day my tv turns off by itself. What's wrong with it??
  • 3 more comments
  • mickysm Feb 29, 2008
    I have a Samsung HLN4365W which appears to be exhibiting the same problem.. will turn on fine and then at random times turn itself off..
    I have wondered if it is a heat related issue and cooling the lamp system?
  • Anonymous May 06, 2008
    My TV turns off by itself several times a day
  • droppingmad Aug 24, 2008
    We had that problem, and then read somewhere that the door to the lamp in the back may not be secure - causing it to shut off. We cleaned the lamp area and dusted everything and made sure the door was secure and didn't have problems for a year or so. Now, it's started happening again... so I guess we'll try the same solution again.
  • stifelm Oct 07, 2008
    It would be great if someone from Samsung could speak up and let us know what is wrong with our TVs, wouldn't it?!?!?
    And specially ... how to fix it.
  • bralio Nov 30, 2008
    Yep - same here with a HL-S6186W; already changed the bulb, that satisfied it for exactly one week, and now it's getting so chronic that it's doing it every 10 minutes or so....
  • 1,197 Answers
Ensure that the TV is off. It may be advisable to unplug the TV as well.
2 Using a Phillips screwdriver, remove the single screw affixing the lamp cover (the small, grill panel on the back of the set) to the chasis. There is also a grill that is held in place by tension. Just "pinch" the thumb clamp on the bottom of the grill and slide it out. This is the same procedure you would perform to change the lamp, except in this case you will not need to remove the lamp itself.
3 Inspect the spring-loaded blue safety switch to ensure it is making good contact when the panel is secured. The switch should deflect downward when the panel is replaced. If the contact with the panel is suspect, very gently bend the metal bracket on which the switch is mounted.
4 Replace the grill cover and the lamp door, and continue to enjoy your TV.
5.Check some basics first. Make sure the sleep timer on your TV hasn't been turned on, telling your set to turn off at a certain time. If your DLP TV is acting erratically, Samsung recommends turning the set off and unplugging it for 30 minutes. After 30 minutes plug it back in and turn it back on. Unplugging the set resets it, and that may fix the problem.
6 Check your power supply. Make sure your Samsung DLP is securely plugged into a working outlet. Plug the TV into a different outlet to see if the problem still exists. Make sure that a fuse hasn't blown in your house or a circuit breaker hasn't flipped.
7 Replace the lamp. If your Samsung DLP is shutting off or won't turn on, a bad lamp is the most likely cause. To replace the lamp, remove the lamp cover from the back of the TV by removing the screws with a Phillips screwdriver and slide it out and away from the TV. Remove the screws on the lamp assembly and slide it out of the TV. Disconnect the old lamp and insert a new lamp into the assembly. Slide the assembly back into place and replace the screws. Do the same for the lamp cover.
8 Check for signs of overheating. Samsung DLP TVs generate a sizable amount of heat. If the components inside the TV get to hot, the TV will shut itself off as a protective measure. Make sure your DLP is out 12 inches or so from the wall. Make sure that all of the vents on the set are clear of any obstructions. Allow the TV to cool down for 30 minutes before turning it back on.
9 Contact Samsung. If none of the above tips help, it's time to contact Samsung, as the problem is likely something that should only be fixed by a qualified service technician. More serious problems may include a bad power supply or a bad ballast. Attempting to repair those yourself will void your warranty and may cause more serious damage to your set.
The safety switch exists so the user does not accidentally remove the lamp door while the TV is on. Doing so could, theoretically, result in burn or electrocution. This spring loaded switch causes the TV to shut down when the door is opened.
Since the TV's chasis is plastic, expansion and contraction can cause the switch to lose firm contact with the lamp door. The TV's behavior could then be such that after being on for a while (getting warm) the plastic expands and the switch loses enough contact to cause the TV to shut down. The frequency with which this phenomenon occurs is not only dependent on the internal temperature of the TV, but also the ambient temperature of the room as well as the relative tension on the switch itself. The user's perception is that the TV starts up fine, but then "randomly" turns itself off after being on for a while.
If you have recently moved your TV, it is very common for random shut-downs to occur. This is because the move has shifted the flimsy plastic chasis of the TV, thereby loosening the contact between the lamp door and the switch.
Make sure your TV is off and cool when performing this procedure.
Posted on Aug 31, 2010
Samsung DLP TV, model HL67A750A1F fan #3 message then turns itself off
Please check the all fan if working properly if all works fine you have defective board inside behind fan # 3 you need to replace it..
Dec 13, 2011 | Samsung DLP HL-P5663W 56" TV
Check fan 2. How do I change the fan in a Samsung DLP S6186W TV
You may just need a $10 can of Dustoff compressed air to blow the clogging dust out of it.
Mar 08, 2011 | Samsung HL-S6187W 61 in. HDTV
Samsung DLP turns on and off - cycle repeats
make sure put the lamp door back before trying to turn it on because they have switches on them that allow the tv to turn on. If that is ok you probably have a bad ballast.
Call a local tv repair shop to further diagnose the problem.
Dec 10, 2009 | Samsung DLP HL-P5663W 56" TV
probably a bad (intermittent) control board.
Nov 14, 2009 | Samsung HL-S5087W DLP TV
I have a HL-T5687S DLP TV. Since yesterday, my tv
right side push button stick ...check and open stick button
Nov 07, 2009 | Samsung HL-T5687S Television
I have a Samsung HL-S6186W 61" DLP HDTV I could get the hd channels over the air with an antenna before but now I can't get any thru cable without going thru my dvd recorder tuner first which degrades the...
Select TV input, Press Menu, Select Channel, in menu Antenna=Cable (for you), (then perhaps, Auto Program with Cable or Air+Cable), tweak Channel List, turn on LNA if needed, shouldn't be.
Somewhere there may be different modulations, some offset the channel a fraction and are important for channels above 13. I'm basing this on my non-cable Samsung HL-T5687.
BTW, I had an HLS until it gave trouble, paid for an upgrade to LED from bulb when I got HLT. Very pleased, until it fails. -Ken
Jul 15, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung HL-P5663W
your tv need to be re solder ,it's the first step your going to do.if nothings happened check the supply vertical IC or the IC itself.
Oct 31, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung hln567w dlp tv
after 3 years it is a good chance that the lamp is going,,however if it plays its melody when it turns off there is a possibility thateither the lamp door switch or the thermostat are failinf
Nov 28, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HL-S6186W 61" HDTV Logo
350 people viewed this question
Jerry Greenberg
Jerry Greenberg
