Question about HP Pavilion dv6000z Notebook
Hp pavillion dv6000 battery problem
My laptop battery stays at 6% even after 3 hours on power! The message reads plugged but not charging. Aby way out of this?
  • Anonymous Mar 08, 2008
    Did I kill my battery by leaving it plugged in all the time not uses?
Check this site. You may fall into the category of known issues with this model.
If you fall into this category, they pay for fixing your laptop. It doesn't have to be under warranty.
Posted on Mar 04, 2008
I have a Simon XT which I installed about two weeks ago. I keep getting a system low battery message when I press the status button on the console. I had a new battery shipped and I installed it about 24...
Call your Central Station and put your account on test if it is a monitored system.
Power down the system. Disconnect the battery, then the AC adapter. Then plug the battery in first, then the AC adapter. Plugging the AC adapter in first can cause the low battery message.
if that doesn't work, with the battery disconnected, measure the voltage of the battery with a multimeter. If it reads less than 5.4 volts, the battery is bad. Bad out of the box batteries are not too uncommon.
Next, check the charging voltage from the panel. Measure DC voltage from the leads that connect to the battery. They should read around 6 Volts DC. If the charging circuit is bad, it will cause a low battery trouble and the console will need to be repaired or replaced.
Hope this helps.
Feb 19, 2011 | GE Security Simon 3 Wireless Home Security...
Compaq EL81 laptop. Battery will not charge. Laptop powers/boots up with battery installed but shuts down after a few minutes. Removed the battery, power up and unit now stays on. Bad battery?
The battery in my laptops only seem to last 1 or 2 years.
Yes, I would say it's a bad battery.
Try to get a higher capacity one from I upgraded from a 6 cell (1 or 2 hours of battery life) to a 9 cell (3 or 4 hours of battery life) on my Acer Aspire for about $39.
Prices will vary depending on make and model and capacity.
Aug 17, 2010 | Compal EL81 Notebook
My new acer laptop only works if pluggd in
u try one thing just shutdown laptop remove battery and charger from laptop then after push power button for 1 minute after that install battery and charger. but not start laptop and check that charging led of laptop is running if it's runnig then put in same condition for 3 to 4 hours after that start laptop using battery only after proper booting when os load attech the charger and check charging status.
Dec 27, 2009 | Acer Aspire One PC Notebook
Battery does not charge
Will the old battery (that you are replacing) charge up at all? If the old battery charges but the new battery will not, then it's likely a bad replacement battery.
To rule out the possibility of a corrupted battery meter inside of windows, you may wish to leave the laptop on battery power only, until it dies. A 5% charge will usually only grant you about 20 minutes of laptop life maximum. Since you left it charging all night, you should get a few hours of life before it dies. If you get a few hours of life, the battery meter software is corrupted.
Most likely though, the replacement battery is bad.
Sep 02, 2009 | HP Compaq Evo n610c Notebook
If you charged up your battery up for 2hrs but didnt increase the percentage or didn't charge up at all it means that your battery is faulty. I have also a same case with you.
Send it to the service center near you and ask them to rplace your battery. Replacement is free if machine is under warrant.y
Jun 03, 2009 | HP Pavilion dv6000z Notebook
Toshiba satellite m35 power issues
Hi !
While power off, disconnect the power adaptor.
Take off battery.
Plug the power adaptor back and try to start !
Is it running?
If yes, than the power adaptor is OK.
Now shut down and disconnect the power adaptor.
Put back your battery and start!
Leave it untill you 'empty' the battery.
Do not start your laptop.
Plug the power adaptor and do not start your laptop yet.
Is there a led idicator showing that the battery is charging ?
Does it shows when the battery is full charged (e.g. red/yellow=charging, to green/off charged)?
If not, leave it for at least 3 hours. After that, start your laptop (adaptor is plugged) and see if you still have an icon saying charging 99%.
If that is the case, then something is wrong with the battery.
Check your warranty, and replace it.
DO NOT OPEN the battery - nothing interesting you will find inside - nothing you can do !
Mar 28, 2009 | Toshiba Satellite M35-S456 Notebook
Always running on batteries
You can still use your laptop even if you take out the battery and run on ac alone. You can also leave your battery in with the ac plugged in for 4 hours to charge it even if the laptop is off. Hope this helps. Thank you.
Sep 20, 2008 | Toshiba Satellite P35-S611 Notebook
fixed it ( it is bios problem) but besure to down load the fix before formating or use win 98 to fix it
Jul 07, 2008 | HP 530i (Q6750A) DVD±RW Dual Layer...
Lenovo N100 does not switch to battery power
Batteries have a memory,
When the battery was new it most likely would run for 1.5 hours, but, since you didn't want the computer to go off, and you were by a plug-in, you plugged it in before it was completely or maybe sometimes not even halfway discharged. That is where it stated its "memory" - this got shorter and shorter = your battery "THINKS" it is totally discharged and reads as so.
There are programs on the web (can't advertize for pay programs or give you links to them - against the rules) - that will re-vitalize your battery to almost new condition by discharging it more and more till it is truly fully discharged, then will fill it back to like new charge time.
Or you can buy a new battery.
Jul 03, 2008 | Lenovo 3000 N100 CoreDT2080 VB PC Notebook
HP Pavilion dv6000z Notebook Logo
178 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
