Question about Mr. Heater MH75KT
Mr heater 75,000 btu kerosene heater
Worked fine 2 days ago. Nothing happens when turned on.
Flashing error code says "HLS open"
nothing in the manual describes this error codes.
    Problem Solver:
  • 19 Answers
HLS should stand for high limit switch(control) this model does show one in the parts diagram.
Posted on Mar 02, 2008
I got this error when I had increased my air pressure to 5.5 lbs. Cut the pressure back to 4.5 and it has been running fine for the last three hours. At 5.5 it got WARM ... solid red hot cone and flames coming around the outside. Had been having problems with it cutting off for no apparent reason in really cold weather. Took the pump apart and cleaned it and checked for clearances and reassembled but it did not help much. Will schedule it for a total pump replacement with new filters asap. Pump parts and filter are not that bad. Should come in under $50.00
Hope this helps
I also turned the thermostat back a little off of full on.
Mike
Posted on Feb 04, 2009
My mr. Heater contractor series 75,000 kerosene heater won't get hot the blower isn't kicking on its getting fire and it's got kerosene in it but it won't get hot the blower won't kick on?
Kerosene Torpedo Heater Repair + Test - YouTube
? 12:08
https://www.youtube.com/watch?v=k1nRieTELnk
May 25, 2013 - Uploaded by InductiveExperiments
I repair my "Reddy Heater" torpedo heater by installing a new ... I replaced spark plug, filters,photo cell, new K, it has fuel spray,spark but it won't ignite now! .... I removed my motor andhot wired it to an outlet and it worked fine. but when hooked up ....Mr. Heater 36,250 views ... Get video URL at current time.
Torpedo Kerosene Heater repair & HOW they work - YouTube
? 9:30
https://www.youtube.com/watch?v=ve0nzByP6SU
Dec 6, 2013 - Uploaded by sixtyfiveford
Could not find my manual and the Mr. Heater (75k),web site let me down for a pdf. Opening the .... Thanks for the video -- helped me get mine working again ... Fan runs also just won't fire Any help would be great Thanks.
Mr Heater Kerosene heater cleaning and maintanence ...
? 9:06
https://www.youtube.com/watch?v=2EzoWdZLExg
Jan 11, 2016 | Mr. Heater Heating & Cooling
Heater code is flashing HLS Open What do I need to do?
The high limit switch either needs to be rest or replaced...the heater got too hot and tripped the high limit open...
heatman101
Jan 06, 2011 | Mr. Heater MH125KT Utility
Heater Code is flashing HLS open What is this?
High Limit Switch, look for a bimetal disc somewhere near the elements and apparently this is a manual reset. Should be red button in between two wires on a flat round disc.
Always turn power off when attempting electrical
Feb 15, 2010 | Mr. Heater MH125KT Utility
We have a 75,000 Natural Gas Mr.Heater
Make sure you are using the R and W terminals both at the heater as well as at the thermostat. Try jumping the wires together without the thermostat and see if the unit starts. If it does, bad thermostat. If you continue to get the error code, you may have a bad board.
Jan 16, 2010 | Mr. Heater Natural Gas Garage Heater -...
Heater used once 3 yrs ago. Now wont start.
When the heater hums is the fan turning. If it is I would add more Kerosene. There is no shut off but the Kerosene is sucked out a tube from the top of the tank. This tube does not reach quite all the way to the bottom of the tank. Your heater should hold about 9 gallons if it is empty. A couple of gallons would give it plenty to run though. Let me know.
Jan 02, 2010 | Reddy HEATER R115 115,000-BTU PORTABLE...
Mr. Heater Natural Gas Garage Heater - 45,000 BTU. Power 120 volt and 24 volt good. Thermostat calling for heat, but nothing happening??
Check for a fuse either in-line or on the circuit board. There should be 24 volts going to the thermostat. If not, you have either a bad transformer or a bad thermostat wire. Jump out the terminals that the thermostat wires are connected to. This should force the unit to fire. If not, bad circuit board.
Dec 23, 2009 | Mr. Heater Natural Gas Garage Heater -...
Dead Reddy heater 170T
When chaning the filters, did you clean out the flame chamber, a lot of carbon and suot will build up inside and cause the unit not lite.
Feb 14, 2008 | Reddy Heater-170,000 BTU Kerosene Deluxe
Heating & Cooling Logo
735 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Mack Baxter
vance jones
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
