Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
I'm trying to hook up your Western Digital 500GB to my Mac and I can't get the icon on my screen. I'm connecting with a firewire cable that was provided. I also tried the USB cable to no avail.
  • dapayne Mar 01, 2008
    I don't have a mac but HP with windows xp. On the box is said it was compatible. But I'm getting no response It's not showing up in the computer window with my other drives?
I am able to communicate between my iMac and myworldbook.
The procedure is as follows (see screen shots below):
1.  Determine the ip address of MyWorldBook
2.  On Safari address line enter the command:      "smb://10.0.1.199"                  {10.0.1.199 being the IP address of myworldbook}
3.  Select "Public" when ask which volume to mount
The hard drive will show up in Finder under SHARED below DEVICES.
You can automate this task and have it execute at startup.
To determine the IP address, access the HD through your web browser (see Western Digital web site for information on shared storage manager.   http://www.wdc.com/en/library/usb/2779-701026.pdf  see appendix a of user's manual
Posted on Feb 28, 2008
My WD External hard drive is no longer recognized by my Mac. It was fine when I went to bed. Showed no warning symptoms that I am aware of.
I would like to know the way the Drive is connected to MAC.
Have you connected it using USB or Firewire ?
If you have connected it using Firewire, Try connecting it using USB 2.0 Cable.
Let me know.
Regards,
Ron
Dec 10, 2010 | Western Digital 4TB My Book Studio II Hard...
Western Digital MyBook suddenly no more responding. It worked perfectly over years, but one morning I entered the office, and the blue rings were on. But iTunes didn't play any songs, the library is...
You may be able to remove the hard drive manually and try another USB adapter to access it on your computer.
Might be pootched though.
Rule of thumb is to never save your files to only 1 source. Its not a question of if a hard drive is going to fail but WHEN.
Sep 26, 2009 | Western Digital 500GB MyBook Office...
Western digital wd 500gb external hard drive not showing the icon
Doewnload Testdisk and run it to see if it can find a boot sector.
Oct 04, 2017 | Western Digital 500GB My Book World...
Recognise my hard drive but is blank!!!
1. You might reformate it ore it whos an error will trying.
Jan 09, 2009 | Western Digital External USB 2.0 80 GB...
Western Digital Hard Drive will no longer mount
HI. So I had this problem twice with the same hard drive. I didn't have the money to replace the hard drive the first time, but this time I did, so my ultimate solution to offer is to purchase a different HD and migrate the data from the current one.
How did I get the drive to turn back on so I could get the data migrated to the new HD? Persistence! I kept disconnecting and reconnecting the drive, making sure to shut the drive down by pressing the blue button on the front until the drive powered down. I disconnected, waited for some time (between ten and 20 minutes) Then I reconnected the FireWire cable first, and the power cable second, waited for it to mount - and eventually...
IT DID!!
Wow am I happy. I'm going to run a series of diagnostics on this one but I'm probably going to retire it. Too bad because 500 gigs is a lot of space to loose, but this being the second occurrence makes parting all the easier. I mean, my entire iTunes library is on this thing!
So, just keep trying - plug the drive into the computer, then connect the power cable and wait for it to come on.
I'm running Mac OS 10.6.4 and an older machine 10.4.11, both of which were able to read this drive before, the 10.6.4 had the problem initially, then both machines had issues. Ultimately the 10.6 machine was successful with a FireWire 400 connection.
I hope this helps!!
Nov 20, 2008 | Western Digital 500GB My Book Pro-External...
Won't mount
Western digital drives ****! I'm having the same problem repeatedly. Seagate drives work fine though.
May 30, 2008 | Acomdata 500GB External Firewire HD 500 GB...
Can't accept Quadra 500 on my owerMac G5 Quad
Scrap LAcie!! Sounds like in this case, it may have been jostled around during shipping. None the less, Lacie drives are nothing more than bricks waiting to fail. Go Western Digital, but if oyu can, zip straight for Seagates!!!! Professional grade!! ALways check the cables, the ones that come with them are bottom bin cables, made by little singapore children with no fingers..... Invest in a good cables...a drive is only as good as the weakest datalink.
Cash on the warranty!!!
Keep me posted.
Dec 13, 2007 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Installing Firewire 400 on a Western Digital 500gb external My Book Pro
Don't connect the USB and firewire at the same time, use one or the other. In general for USB, for the very first connection, it is better to have the computer fully booted, and the MyBook spun up, before connecting the USB cable. After that, you can boot the computer with or without the MyBook connected or turned on. For the firewire connection, check your manual for the correct order of connection and power on.
USB and firewire 400 are roughly comparable. USB is theoretically a little faster, but you will see little difference. There are other factors that can affect your actual performance, so your best answer is to try a test yourself. Time a copy of a very large file, and a copy of a folder with a very large number of files.
Dec 03, 2007 | Western Digital MyBook Pro WDG1T5000 500...
Download digital video to Mac
the os x , 10 . 3 . 6 update may help ;
Jul 31, 2007 | Panasonic PV-GS19 Mini DV Digital...
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
316 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
