Question about Lexmark T630 Laser Printer
Lexmark T630 Printing labels when the labels got stuck and tried to pull them out and now when I print the paper is getting stuck in the rollers
  • tbarfield May 11, 2010
    We have the Lexmark T630 Printer
    I keep getting the Error Code: 202 Paper Jam Rear Door
    When I open the rear door, there is no paper jam.
    I then go the front & press the green GO button & it will print for a little while & then say its jammed again & again no paper is jammed.
    Help!!!
I would suggest pulling the toner out and paper tray and using compressed air to blow out all ereas of the printer. If that does not work then you will have to remove the 2 screws at the back of the printer and with the two tabs at the top remove the backa nd look for paper jammed inside.
Posted on Jun 11, 2008
Fix repeated paper jams on Lexmark 901 Pro
If you are getting a jam and there is no paper visible then a likely cause is a false jam that is caused when the paper is not picked up from the tray at the start of printing. Send a print job and listen closely. If you can hear the pickup rollers turning but no paper is being pulled into the printer then either the rollers are dirty or are worn and need to be replaced. Trying printing from a different tray or the manual feed tray to eliminate a fault with a different component on the printer.
Oct 14, 2014 | Lexmark X Office Equipment & Supplies
241 paper jam message
Lexmark T630 241 paper jam message - Indicates a paper jam from the pull down manual feed tray.
If you check to make sure and small fragments of paper are not hindering the operation of the switch. The switch is located on the left side of the tray and will be spring loaded. The switch should move freely without binding. Make sure no toner or dust is on the optical sensor assembly. See Diagram for location.
If the switch seems OK and the printer still reports an error, the printer will require professional care.
Jan 15, 2011 | Lexmark T630 Laser Printer
I have a Lexmark T630 printer and every time I go to print it beeps and says change tray 1. How to I get it to not beep while printing?
You will need to change your paper handling.
From the machine, go into the Menu-> then Paper Menu -> Change your paper size and type to your machine settings. Example if tray 1 is letter make sure it's set to letter and plain, then confirm each tray setting for each tray attached to the machine.
Also pull the tray(s) out completely and make sure the guides are set correctly. (The guides move so you can put legal, A4 etc.)
I've come across a lot of machines that the guides are off by a fraction which will prompt your machine to display the message you stated.
Nov 16, 2010 | Lexmark T630 Laser Printer
Lexmark T630 printer pulls paper from wrong tray
Verify your settings under the Paper Menu are correct as far as size and type. All trays with same size and type settings are automatically linked as per the User Guide.
Dec 31, 2008 | Lexmark T630 Laser Printer
Paper stuck while printing on lexmark X5470
You might have a little paper stuck inside your printer or just clean the pick-up roller with alcool and try it again.
Mar 25, 2008 | Lexmark X5470 All-In-One InkJet Printer
Lexmark printer problem on HP-UX
You should check your drivers to be sure the Lexamrk ones are being used and that the HP ones have been deleted.
Dec 06, 2007 | Lexmark C510 Laser Printer
Labels jamming
Check the entire paper processing path as it sound like either the roller gear is not engaging properly to push the paper out of the top, or the output paper path is somehow blocked, like from a label or something else stuck at the top, the roller gear is damaged, or other obstruction.
Nov 16, 2007 | Konica Minolta magicolor 2300DL Laser...
Lexmark T630 Laser Printer Logo
126 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
