Question about Philips Televison & Video
PHILIPS 32W9763/05 EXT RGB PROBLEM
I HAVE A PHILIPS 32PW9763/05 TV, EXT RGB IS ALWAYS IN THE RIGHT HAND CORNER OF MY SCREEN. I WATCH SKY TV ON THIS CHANNEL AND EVER SINCE I CONFIGERED MY SKY REMOTE TO WORK THE TV I HAVE HAD THIS PROBLEM. TODAY I CONTACTED SKY AND THEY CANCELLED THE SKY REMOTE FROM WORKING THE TV, ONLY PROBLEM IS THE EXT RGB IS STILL ON THE RIGHT HAND CORNER OF MY SCREEN. CAN YOU HELP? PLEASE
  • 41 Answers
SOURCE: rca p61939
You will have to remove the small control panel printed circuit board from the front of your unit & inspect it for cracks on the board or bad tact switch/s.
Posted on Jul 05, 2007
HDTV GURU
  • 261 Answers
SOURCE: Samsung LCD Question
possibly take a picture with cell phone then send it. That may work better. Jay
Posted on Feb 18, 2008
Slinteriors
  • 8617 Answers
SOURCE: I have a philips tv
here is a link to the phillips universal remote page that has all the codes for any brand tv including phillips and it will explain how to program the remote try the codes for phillips one of the codes should work.
http://www.universal-remote.net/philipsmagnavox.html
Posted on Apr 08, 2008
SOURCE: Maxdorf tv
Press and hold the music button until the normal picture appears.
Posted on Aug 18, 2008
mistersony
  • 320 Answers
SOURCE: yellow spot in lower right hand corner
You have pretty much narrowed it down to being a bad optical block. This isn;t good news, since the optical block is probably the most expensive part in the set. Your best bet is to contact Sony customer support to see if the will allow some kind of accommodation for the repairs. Sorry for the bad new; hope it doesn't effect the rating you give me for the solution. Thanks!
Posted on Nov 12, 2008
My philips flat screen shows no signal and #3 in right hand upper corner just happened when cat knocked over remote no sound
To which model television are you referring? It sounds like you either need to change the input method for the TV or just change to a different channel (2 or 4).
Dec 10, 2012 | Philips Televison & Video
Having problems gettin sky channels through archos i get to setting infrared settings and can not get code.dont know wether to connect dvr t the tv or the sky box
Remove the DVR station from the box, and attach the DVR adapter plate (found in the
DEVICE box); it is correctly attached when it clicks on.
-Take the Black Audio/video Marked "output" cable, and insert the connections into the corresponding coloured sockets, yellow>yellow, green> green etc. Make sure they are
inserted into the TOP row on the back of the DVR Station "Marked Out". The remaining
black connector should be plugged into the SW socket, which can be found underneath
the orange socket on the back of the DVR station. (If after setting up your ARCHOS the
picture is very green remove the black cable from the SW socket)
-Plug the SCART connector into the SCART socket on your TV set. These are usually
marked AV1, AV2, or Ext 1, Ext 2, L1, L2, Line in 1, Line in 2, Aux 1, Aux 2, make sure you
select the corresponding channel above (ie AV1 AV2 etc) on your TV set when you turn on
the TV.
-Attach the UK plug adapter to the Mains charger, and plug the charger into the DC-In
socket on the back right of the DVR station. Turn the mains on at the socket.
-Insert the powered off ARCHOS unit onto the DVR station, the unit will now power on,
and ask if you want to 'Switch to TV out', select 'Okay'. The 'TV output configuration' set
up will load up. Select 'Okay'.
-TV connection: When your DEVICE is connected to the optional DVR Station you need to
select the type of video output (Composite, S-video, component, RGB, HDMI etc), based
on how you have connected the DVR Station to your TV and what possibilities your TV will
allow. For the cables supplied and the instructions aboce you will need to select either
RGB or Composite. Use the arrows to go through the options and select either RGB or
Composite.
-TV Standard: this should be set to PAL (Europe). Select 'Next'.
-Now you need to test the settings, select 'Okay', the ARCHOS home screen should now
be visible on your TV set. If you have nothing showing on your TV, scroll through the
AV/Ext channels, the channel will correspond to the AV/Ext socket you connected the
cable to on your TV set. Use the ARCHOS remote to select 'Okay'; you have now set up
the output connection settings for your DVR station.
-You may need to adjust your output from the ARCHOS to match your TV, from the "TV
Format" options. Use the arrows on the ARCHOS remote to select the format of your TV
screen, so the ARCHOS unit outputs the correct picture size (ie 4:3 / 16:9 etc). Use the
arrows on the remote to select 'Next'.
Dec 24, 2010 | Archos 605 WiFi Digital Media Player
I have a Philips flat screen HD ready TV for my xbox. I don't know what type though as my parents have upgraded to an LG and we now have this Philips TV. I have Sky connected to one of the EXT ports and...
Perhaps the Phillips TV isnt compatible with some of the Xbox Settings.
Or mabye when you adjusted your settings it may have affected any graphics.
Apr 07, 2010 | Microsoft Xbox 360 Console
No sky no happy
Unplug from the main power and that should reset your sky box. If still no signal get the dish looked at by a tv aerial company.
Apr 07, 2017 | Philips Televison & Video
Had Sky installed. Displays EC1/RGB on left hand
Double clicked the i button on the TV remote - simples!
Jan 11, 2010 | Panasonic TX-32LX60 32 in. LCD Television
When switiching on the TV and selecting channel 6 (s/b Sky) all I get is a blue screen to get to the sky channel the ext button has to be pressed to take it to ext2. How can I get the TV to remember the...
You must have channel 6 programed to first ext when you turn TV on it seems that it is programed on ext2 instead of ext Go to Menu then do Auto Program when you have it on ext and make sure your inputs are on first ext and not ext2
Nov 22, 2009 | Toshiba Televison & Video
Screen going blank with ext.2 in top corner
as you say that u purchased new tv so it must be in warrenty period u hav eno need to do any experiment on it because shopkeepar can say done a mistake . so just make a call to the shopkeepar it will defenetaly solve your problem.
Mar 02, 2009 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Philips LCD TV wont change aspect ratio
In your philips menu there is an option to turn of your auto aspec ratio to OFF then using your sky remote go to services, 4 then picture and ensure that this is set to 16:9
Job done
Cheers
Little Dish Fitter
Dec 24, 2008 | Philips 32PF7321 32 in. HDTV-Ready LCD...
Screnn going blank
sounds like sky tv issue, try different cabling
Jun 02, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Televison & Video Logo
160 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
