Frigidare FWS6973EW1 I am trying to change the drain hose on the frigidare fws6973ew1. I need to know what I need to remove to get to the hose without taking the whole washing machine apart. Thank you
  • 156 Answers
You can most time just remove the front lower panel remove hose from oump remove 4 6 screws on the back were it comes out pull out put the new one in the same way
Posted on Feb 28, 2008
My frigidare gas oven wont turn on...
try changing the igniter it may have burned out or is weak
Aug 26, 2012 | Frigidare FGB24S5DC Gas Single Oven
My frigidare crown series washer won't drain the
Remove the back cover and later the drum drain pipe. If a filter is present, dismantle and clean out. Most often the cause is a object that that is hindering the operation of the spinning pump. Dismantle and clean the pump.
Feb 29, 2012 | Frigidaire Washing Machines
My frigidare 25000 but unit isn't draining out of
Tip it a little downward on the outside. If you look at the back (outside), there may be a drain hole. Make sure it's not blocked.
Aug 12, 2011 | Frigidaire Heating & Cooling
Frigidare 1812 frig-water under crisper drawers
clogged drain line somewhere in fridge plumbing
Feb 21, 2010 | Refrigerators
My frigidare diswasher is leaking from a left side black hose
Check the hose first - it could be split or damaged esprcially if it's old. Check all the clamps to be sure they are tight. Chack all connections to the dishwasher and drain spur under the sink. Check the drain trap fro any leaks.
Mar 27, 2009 | Frigidaire Dishwashers
Water doesn't pump out on a series 950 frigidare dishwasher.
Before you start removing pumps first ensure the drien pipe is not blocked simply blow from the end of the pipe back into the machine,if the pipe is clear then move to the pump this is usually located under the machine above the base plate first remove the base plate and locate the pump there will be two pipes attached to it the drain hose wich leads away from the machine and a hose from the tub to the pump remove these and then you will see a screw or hose clamp holding the pump in place,remove this and then the pump shuld come away pretty easily,check in the housing fisrt and make sure there are no obstuctions in the pump if it is clear ask a person with electrical knowledge if ou are not electrically minded to test the pump on that note if it is not working buy a new one sometimes spending a little time on these checks and proceedures can save you money,but yes sometimes the unit will be fualty but you will know there is nothing there that can cuase your new pump to break within a few months.
Feb 06, 2009 | Frigidaire Dishwashers
Water leaking from bottom of frigidare washer
You really don't have to take a panel off, depending on your washer model. All you would have to do, is flip the washer over on its side and check underneath.
Jan 19, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
How to install a frigidare ice maker IM115.
the wires should be behind a cap that covers the hole for the water tube on the pack panel in the freezer.
Nov 19, 2007 | Refrigerators
Frigidare Front Load Washer dispenser drawer wont drain.
I think you have something stuck in the fill hose.. Remove the top two or three screws in the back.. then pull out the hose that goes to the tub. I bet you will have something in there.. most common is the inside liner to a bleach cap..let me knowif this it it... krazytech
Sep 08, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
81 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
