HP HP Pavilion dv6000z 15.4" Notebook Laptop PC  PC Notebook
Problem for HP HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD...
HP PAVILLION DV6000 REPORTS BATTERY NOT CHARGING
By deolinx on Feb 27, 2008
I noticed that my laptop power stayed at 6% even though I was on power for over two hours. I checked and noticed this...plugged in, not charging. Please help
Same Problem
May 21, 2009
-   my laptop is pluged on byt the battery meter keeps telling me that it's not charging.-   acez
May 04, 2009
-   battery gauge says "6% available (plugged in, not charging)"
I followed these steps:
(1) have AC power adaptor connected and Vista running
(2) remove battery
(3) reconnect battery
now says "6% available (plugged in, charging)"
a few minutes later, it says
"100% available (plugged in, charging)"
then a minute later it says
-   sjones16575
Apr 24, 2009
-   my laptop was not getting charged even after connecting to the power
-   Guest
Apr 21, 2009
-   Only charges up to 36%...-   Guest
Apr 18, 2009
-   + 1-   Guest
Best Solution
posted on May 14, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Reinstalling the power management software has just fixed it for me, i have a dv6552. Go to device manager and under batteries, unistall the Microsoft ACPI Compliant Control Method Battery. Go to Actions on the menu bar and select 'scan for hardware changes'. It will reinstall it and hopefully start charging immediately (mine did anyway).
Solution #2
posted on Mar 28, 2008
Helpful)
DKGB
Rank: Apprentice
Rating: 89%, 61 votes
The correct solution is not buy an HP notebook computer.  I have been traveling for work with a computer for almost 20 years now.  I have carried a lot of different brands of computers.  I have never had a battery last just 1 year UNTIL now.  And to add to the insult this computer is one used almost exclusively by my wife who only takes it to her business and home, not in an airplane.  So it has been well taken care of.  I just called HP - no go on any help from them.
My solution - no more HP computers for my family and I can no longer recommend their brand of laptop.  This one will be replaced within the next 12 months.
Was this helpful?
Yes
No
15 people thought this was helpful
Solution #3
posted on Mar 01, 2008
Helpful)
Kegtapper
Rank: Guru
Rating: 87%, 117 votes
Two possible problems for this -
DC JACK Issue
1: one side of the DC ground is not conntected to the rest of the system, so no circuit is complete to the charging section.
CHARGING Circuit issue
2: bad power controller chip (MAXIM IC) or zener diode in that circuit, maybe bad
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #4
posted on May 07, 2008
Helpful)
LMG Miami
Rank: Apprentice
Rating: 85%, 15 votes
Any one with a HP Pavillion 6000 series, who is having certain tech difficulties should go to HP page and search for extended service warranties to see if your system qualifies. I had an issue with my wireless driver and all I had do was to first turn your system completly OFF, then remove the battery, then remove the middle cover (underneath Lap Top) and then remove the wireless card. (You will see it connected to two small cables) remove the cables and the small screws and remove the card and then reinserted the card and close the cover -do remember where the two cables go- . Then turn on your system, -do not put the battery yet- and go to control panel/ device manager/ look for network adaptor, and see if you see your lan card, once this is done reconnect your battery. If you don't then contact HP they will fix it for free, even if your warranty expire. They will even pick up your postage!.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #5
posted on Jul 24, 2008
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
If your HP Pavillion dv6000 has a battery that won't charge yet still turns on when plugged in, turn off the laptop and remove the battery then wait for around 30 seconds, re-insert it and turn it back on, the charging update should say, plugged in, charging.
Solution #6
posted on Apr 03, 2008
Helpful)
Nagre
Rank: Apprentice
Rating: 86%, 7 votes
I made the bios update, and works for me. My battery problems were fixed. The battery led always blinking every time and the battery didn't charge. Now it's ok !
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&lang=en&dlc=en&product=3245619
Was this helpful?
Yes
No
Solution #7
posted on Jul 29, 2008
Helpful)
tiggerass
Rank: Apprentice
Rating: 85%, 11 votes
I had the same problem and last night it would not conect to the internet then a friend to it home and found a website stating that is is not anything we have done it is an internal fault with the laptop if it is the same serial number and model number and all you could do was contact hp. Will post the website address later. Hope this helps. Because i done the same took it back to the seller and said it was not working and all the did was gave me a new battery but it not looks like it is the laptop its self.
The problems i had are battery not holding a charge, not contecting to wireless internet, laptop not being able to back up and a few other things. I would recommend to anyone not to buy an hp laptop they are just a waste of time i have had so much problems with my one and it is driving me nuts.
Was this helpful?
Yes
No
Solution #8
Helpful)
Dez1
Rank: Apprentice
Rating: 85%, 1 votes
The BIOS update sorta fixed the issue for me, which was annoying, the battery now charges but doesnt always report the charge correctly in MCE 2005 so I had to set it to shut down while it had a little more juice in it.
Word of warning, avoid sending it to HP if you can, as once serviced the warranty resets in 90 days...basically HP is trying to patch its bad hardware which is prone to overheating with a BIOS fix to make the fans run constantly at a low level... instead of turning on and running noisey when the CPU is real hot.
Ultimately the hardware is faulty, and most of these machines will probably have total failure in 2 years... if your running Vista and not MCE 2005 the failure rate will be higher as Vista is more graphics intensive.
Was this helpful?
Yes
No
Solution #9
posted on Mar 26, 2008
Somewhat Helpful)
hapndnvegas
Rank: Wiz
Rating: 89%, 46 votes
if it is still under warranty you can chat with an online hp tech who will check it out over the internet and send you a replacement for free. the dv 6000 laptops have a recall on a few problems and there is a bios update to fix it before it happens but will not correct it after the fact the recall on specific problems extends the warranty to 24 months http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01087277&lc=en&cc=us&lang=en&dlc=en&product=3245619 should get you to the warranty page
Was this helpful?
Yes
No
Solution #10
posted on Jan 06, 2009
Very Helpful)
grblake
Rank: Apprentice
Rating: 100%, 1 votes
Well...I have had the same problem with my DV6109. When the battery completely discharges due to lack of use and charging, it gets stuck at 0% and the red X appears across the battery.
I just got it to charge again.
While the laptop is powered and in Windows XP, press and hold the POWER button until it dies. Then, remove the battery. Power it back up and enter Windows. Then, re-insert the battery.
Works for me!
Was this helpful?
Yes
No
Solution #11
posted on Nov 22, 2008
Very Helpful)
skulls77
Rank: Apprentice
Rating: 100%, 5 votes
I threw out a battery because it wouldnt charge, but the same problem occurred after a couple months with a new battery.
Basically, power down the laptop and then remove the AC adapter plug. Remove the battery, perhaps wait a minute. Then put the battery back in and then plug in the AC adaptor plug. You then should see the charger light come on showing the battery is charging. Perhaps wait a few minutes before powering on the laptop to confirm that the battery is indeed charging. The problem seems to be in the logic (not sure where, if it is the software driver, etc.) when the laptop is on, it doesn't get a charge. But with the laptop off, plugging in a battery after it has been removed - it works with a simpler charger system that doesn't use the computers's main CPU.
Also second , it is clear with my 6000, that the battery can discharge all the way after some time when powered down even though it had say 50% or more! This is well beyond the normal battery idle loss over time and I suspect the laptop has turned on in some way to drain the battery. So I always remove the battery after I have powered down the laptop, and I have not had any battery problems since then!
Finally, I agree with one posting I saw. The Pavillon HP laptops battery problems are truly the pits and may be enough for people to stop buying HP laptops! Where has all the engineering gone at HP?!
Jim
Comments:
Dec 17, 2008
- Are you sure everyone is:
1) Powering down the laptop.
2) Remove battery and power adaptor
3) Wait a few minutes.
4) Plug power back in and then plug back in battery.
5) See if charger light (blue light in front) comes back on.
If not re-try this.
When charger light comes on, then power up laptop and check for charging.
This had to be done for me with laptop powered off.
Also, if you get it fixed and battery charged, remove battery after powered down
as it seems to discharge after not using, more than it should for being idle!
Jim
Was this helpful?
Yes
No
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #13
posted on May 16, 2009
Helpful)
tharxide
Rank: Apprentice
Rating: 88%, 2 votes
I was really starting panicing, but here's what I did:
unplugged AC so battery could run out
held power button for few seconds
plugged in AC & turned on computer
"plugged in, charging"
Was this helpful?
Yes
No
Solution #14
posted on Apr 30, 2009
Helpful)
seruk
Rank: Master
Hi Friends,
HP Pavilion DV6000 Notebook main problem's are Power Problem, Vista Error etc..
For these problems you can visit a link by just Click Here .
For any other problems with this Notebook you can Click Here
Was this helpful?
Yes
No
Solution #15
posted on Feb 28, 2008
Helpful)
fabcst
Rank: Guide
Rating: 71%, 11 votes
your laptop is possible broken from where u instert the power cord
Was this helpful?
Yes
No
Solution #16
posted on Jul 27, 2009
Helpful)
cavinx
Rank: Apprentice
Rating: 83%, 3 votes
Laptop battery for HP PAVILION DV6000 - 8800mAh This HP PAVILION DV6000 Battery is made from the highest quality parts and are 100% compatible with the HP PAVILION dv2000, dv6000; Compaq Presario V3000, V6000 series batteries. Maximize your battery life for more games, videos, music, and photo viewing without having to plug in your AC adapter. An additional 12-cell battery doubles your notebook's capacity compared with the power you get from a standard 6-cell battery. All the batteries are 1 year warranty and money back in 30 days.
hp pavilion dv6000 laptop battery
View more hp laptop batteries here ...
Was this helpful?
Yes
No
Solution #17
posted on Jun 17, 2009
Helpful)
yuen999
Rank: Apprentice
Rating: 79%, 6 votes
Maybe the battery is a bad one. Ask the supplier. I suggest you should buy a replace battery. May be this can help you,
http://www.hunt360.net/hp-pavilion-dv6000-battery.htm
This is a place where can puchase laptop batteries online. Hope this can help you.
Was this helpful?
Yes
No
Solution #18
posted on May 08, 2009
Helpful)
holy2050
Rank: Guide
Rating: 83%, 8 votes
Was this helpful?
Yes
No
Solution #19
posted on Feb 12, 2009
Helpful)
superbattery
Rank: Guide
Rating: 80%, 5 votes
how long have you got your HP PAVILLION DV6000 Battery? as i know , most laptop batteries can be normal used in 400-500 charge and discharge cycles, in another word, a laptop battery should be normal in 2 year. my suggestion is that you should 100% discharge the battery power and overcharge it for 4-5 hours, to eliminate the memery effect, if it can not recover, you'd better to get a new one
Was this helpful?
Yes
No
Solution #20
posted on Aug 15, 2009
Somewhat Helpful)
alwinsuyambu
Rank: Apprentice
Rating: 75%, 1 votes
i have hp pavilion dv 5 1104tu notebook pc.....my battery is charging very fast upto 90% and after that it is goin on very slow......and it ll stand still for more time in the same level and after reaching 100% also it indicates that the battery is still charging...........
Was this helpful?
Yes
No
Solution #21
posted on Aug 07, 2009
Somewhat Helpful)
elsebn
Rank: Master
Rating: 75%, 14 votes
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
5
Was this helpful?
Yes
No
Solution #22
posted on Jul 15, 2009
Somewhat Helpful)
asd3169
Rank: Apprentice
Take the battery and send it to HP simple.... They will test it and send you a refurbished or new on back if it's bad. Very simple. Then if you want ask the tech guy if you should flash your BIOS.... If thats something that sounds major to you, then you might just have to send them the laptop for a few days for them to do it... Or call your local computer tech to flash the bios. It's very simple. so A) send them the battery, B) Flash the bios. Stop reading all these posts to have you buy a new battery...
Was this helpful?
Yes
No
Solution #23
posted on Jul 01, 2009
Somewhat Helpful)
sillyfox
Rank: Guide
HP Pavilion dv6000 Battery
4400 mAh $72.3 8800 mAh $86.68
One year warranty and 30 days money back! Shipping all over the world.
Comments:
Jul 01, 2009
- HP Pavilion dv6000 Battery http://www.hunt360.net/hp-pavilion-dv6000-battery.htm
One year warranty and 30 days money back! Shipping all over the world. Shipping fee: USD:10100% OEM replacement
Was this helpful?
Yes
No
Solution #24
posted on Jun 18, 2009
Somewhat Helpful)
lincoln2tg
Rank: Apprentice
I suggest you halt you notebook by press you power button last 4 seconds. Or updata your notebook BIOS if this problem haven't fixed. If this can't work buy a new HP dv6000 battery for replace.
Comments:
Jun 18, 2009
- I suggest you halt you notebook by press you power button last 4 seconds. Or updata your notebook BIOS if this problem haven't fixed. If this can't work buy a new HP dv6000 battery for replace.
Was this helpful?
Yes
No
Solution #25
posted on Nov 09, 2009
Not Rated)
yokio0909
Rank: Apprentice
Rating: 40%, 1 votes
good hp dv6000 battery ,you must choose a good place to buy ,see this http://www.goodlaptopbattery.co.uk
Was this helpful?
Yes
No
Solution #26
posted on Oct 22, 2009
Not Rated)
camerauk
Rank: Apprentice
Rating: 0%, 0 votes
Why can't the battery be charged?
  1. The battery has no voltage.
  2. The charger has no output electric current.
  3. Low charging efficiency due to external cause
Solutions to the problem:
  1. Test whether the charger has voltage and output electric current or not.
  2. Check if the charger is well contacted with battery.
  3. Activate the battery with voltage and current 1.5 times higher than those of the battery. (Use this method only when the battery can't be charged.)
Solutions url:
http://www.laptop-batteries.net.au/hp/pavilion-dv6000-series.htm
Was this helpful?
Yes
No
Solution #27
posted on Oct 13, 2009
Not Rated)
markboy123
Rank: Apprentice
Rating: 0%, 0 votes
This Hp pavilion dv6000 battery replacement maked with Hi-Quality battery cells, which is guaranteed to meet or exceed OEM specifications, Li-ion 10.8V and 8800mAh capacity and is 100% compatible with the original equipment. All pavilion dv6000 Hp laptop batteries on sale have passed the stringent quality control tests that ensure they will work well with your model. We offer 30-day money-back refund on every battery we sell.
Battery features:
  • Uses the highest quality battery cells.
  • Provides excellent discharge characteristics.
  • Utilizes state of the art printed circuit board (PCB) design to provide stable and safe performance.
  • Undergone comprehensive quality testing throughout the manufacturing and assembly process.
  • Includes a 12-month free replacement warranty for manufacturer's defects.
Was this helpful?
Yes
No
Solution #28
posted on Sep 14, 2009
Not Rated)
alura
Rank: Apprentice
Rating: 0%, 0 votes
I suggest you halt you notebook by press you power button last 4 seconds. Or updata your notebook BIOS if this problem haven't fixed. If this can't work buy a new hp dv6000 battery for replace.
Best replacement battery you can find it on http://laptopsbattery.us/hp-pavilion-dv6000.htm
Was this helpful?
Yes
No
Solution #29
posted on Sep 04, 2009
Not Rated)
mihawk09
Rank: Apprentice
Was this helpful?
Yes
No
Solution #30
posted on Jun 05, 2009
Not Rated)
jeffgreat
Rank: Apprentice
Rating: 0%, 0 votes
Features - Hp Pavilion dv6000 Series
  • Cell Type:Li-ion Battery
  • Capacity: 8800mAh
  • Volts: 10.8V
  • Color: Black
  • Size (mm): 206.90*58.52*42.18mm
  • Warranty: 12 months
Online Shop:http://www.laptop-batteries.net.au/hp/pavilion-dv6000-series.htm
Was this helpful?
Yes
No
Solution #31
posted on May 21, 2009
Not Rated)
tiffany221
Rank: Apprentice
Rating: 0%, 0 votes
hi,
As i know, after 2 years of being plugged in constantly, the battery could be near end of life. Better to unplug the computer and let the battery run down every couple of weeks. Or better yet, remove the battery if computer is plugged in for extended periods.
If your battery has presented serious issues, as leak or excessive hot, i advice
to buy a new battery for you dv6000.
i know cheap replacement 12-cell dv6000 battery being sold in UK and USA, if you
have need to buy them, have a look:
UK: http://www.all-batteries.co.uk/notebook-batteries/hp-pavilion-dv6000-series.htm
http://www.hp-laptop-batteries.co.uk/hp-pavilion-dv6000-series-battery.htm
USA: http://www.notebook-battery.org/notebook-batteries/hp-pavilion-dv6000-series.htm
Was this helpful?
Yes
No
Solution #32
Not Rated)
bsonhome
Rank: Master
Rating: 100%, 2 votes
you may just buy a new battery this is only about 50USD here
Was this helpful?
Yes
No
Solution #33
posted on Apr 28, 2009
Not Rated)
lilee221
Rank: Guide
Rating: 75%, 2 votes
your hp pavilion dv6000 battery maybe out of work, you may have to buy a new one!
Was this helpful?
Yes
No
Solution #34
Not Rated)
kikykuang
Rank: Apprentice
Rating: 0%, 0 votes
It seems your hp pavilion dv6000 battery is dead, you can ask hp servicer to check it, if the battery is in warranty day, they will send your a new one.
Was this helpful?
Yes
No
Solution #35
posted on Apr 10, 2009
Not Rated)
TACsonic
Rank: Apprentice
Rating: 0%, 0 votes
I had the same issue my fix was a new cmos battery that was only $10.00 and install updated bios software from HP
Was this helpful?
Yes
No
Solution #36
posted on Nov 21, 2008
Not Rated)
Randyme
Rank: Apprentice
Rating: 0%, 0 votes
I had the problem where it showed my battery NOT CHARGING. I took it apart because my QUICKPLAY would not work either and the QUICKPLAY lights stayed on even after I shut down the laptop. I found that the black ribbon cable on the right (the other looks the same but you can see it is for the power button) was slightly kiltered in the flat socket it goes to underneath the area where the quickplay button is. I straightened it out and made sure it was pushed all the way in and locked and put it all back together and everything worked perfectly after that. About a month before that my POWER and SOUND didn`t work. I did the same thing to fix those problems. MAKE SURE YOU HAVE THOSE CABLES EXACTLY RIGHT in there, IT MAY JUST BE YOUR PROBLEM TOO.
Was this helpful?
Yes
No
Solution #37
posted on Nov 14, 2008
Not Rated)
Obstructicon
Rank: Apprentice
Rating: 0%, 0 votes
I ve had the same garbage problem with my battery as well, first i noticed that my battery performance significantly decreased as in i would unplug the ac when the batt was fully charged and i would only get maybe 8 or 9 minutes to use the damn thing with power settings on power saver!! Plus all i was doin was playing music. then it went to 4 or five minutes, then it stopped charging altogether all this happened within a two month period i tried reinstalling the drivers, plugging it in to different outlets all kinds of crazy sh#t!! unfortunately my warranty ran out so i just took out the damn battery!! Recently i had to do a system restore because of antivirus 2008/09 something told me to try putting back in the battery since all the factory settings/progs had been restored and what do you know battery is just fine for now at this very moment it is charging and device man says the battery is "functioning properly" dont know about performance issues just yet if i have any i will make another post.
Was this helpful?
Yes
No
Solution #38
posted on Aug 03, 2008
Not Rated)
thefaty08
Rank: Apprentice
Rating: 0%, 0 votes
some people dont realise that you should avoid short charges and discharges, if your batery does not go above 40% mabe its charge memory thinks its full. to fix this problem let the batery run fully down, then charge it all the way again. try it a few times if it doesnt work. and you have to go all the way, not let windows go into hibernation. to do that you need to get the batery low, then boot to some boot disk and let it sit till the batery dies.
Was this helpful?
Yes
No
Popular Solutions for HP HP Pavilion dv6000z 15.4"
Questions and Unsolved Problems for HP HP Pavilion dv6000z 15.4"
Do you recommend HP HP Pavilion dv6000z 15.4" Notebook Laptop PC (AMD Turion 64 X2 Duo Core TL-50 1.60GHz, 1GB RAM, 100G... (d6000z) PC Notebook?
Answer
Answer
how to switch HP notebook dvd player primary display to TV monitor -
Answer
the zoom on my computer is set at 100%, when I change it to 75% it won't stay at 75% and goes back... (More)
55 Other Users Have The Same Problem - Continued
Comment by kenzied90, posted on Apr 12, 2009
Several months after purchasing my HP Pavilion, I also had this same problem. Mine was stuck on "0% power, not charging". After a couple weeks, the problem resolved itself. Now, about a year later, I am having exactly the same issue: "6% power, not charging".
Comment by amanda18, posted on Apr 09, 2009
My battery is at 0% available (plugged in, not charging). This is probably the third time it's happened since I bought my laptop at least a year ago. I had a year warranty to replace the battery / charger. But I think my time is up. I'm not sure why this happens, but it has fixed itself twice before, so I'm hoping it will fix itself again.
Comment by Guest, posted on Apr 08, 2009
batter can not charging
Comment by camerauk, posted on Apr 02, 2009
yes, i have the same problem about this battery for dv6000. but i bought a replacement hp dv6000 battery from below website, and i think it's a best replacement battery,because it can works as well as my original battery. high capacity(8800mAh, 10.8V)
BUY the HP Pavilion DV6000 Battery http://batteriescenter.co.uk/battery-laptop/hp-pavilion-dv6000-series.htm
Comment by janchr, posted on Apr 01, 2009
i leave my pc on overnight with the battery in. when i turn on the next day it shows 75 percent and charging but after being on for awhile even tho plugged in it stops charging and drains the battery and shuts down
Comment by Bwayo, posted on Mar 26, 2009
I just bought my dell laptop but the battery icon indicates (plugged in, not charging)
Comment by Guest, posted on Mar 13, 2009
When i plug in my charger into the DC adapter hole, it does not charge unless i push it REALLY hard. Please Help!
Comment by Guest, posted on Mar 11, 2009
i plugin to chargh the batery and it not chargh
Comment by saurin_patel, posted on Mar 07, 2009
my laptop's battery is not charging when i plug in.
when i remove plug my battery saws its low and after few minutes it automatically shutoff.
if i countinue pluging its work but when i remove plug its shutting down
Comment by victoryhenry, posted on Mar 06, 2009
HP Pavillion DV6000 plugged in but battery is not charging. Please Help!!!!
Comment by derek1066, posted on Mar 02, 2009
I have the same [problem except that my laptop stays at 0% and says plugged not charging.
Comment by countryboyjr, posted on Mar 02, 2009
my battery went dead, i plugged up the charger and nothing, laptops been dead ever since !!
Comment by Guest, posted on Feb 27, 2009
I plugged in my computer, but it's battery is not charging. Why? Please, tell me. Help me!
Comment by Guest, posted on Feb 24, 2009
Same Problem even I connected it to power source still the charging status is constatnt 3%
Comment by Guest, posted on Feb 20, 2009
My battery won't charge at all
Comment by Guest, posted on Feb 05, 2009
Light is blinking, and on mouse over the battery status,"plugged In , Not Charging"
Comment by Guest, posted on Jan 29, 2009
My laptop will not charge, it is 4 weeks old! If I hover over the icon it says
'0% available, plugged in, not charging'
Comment by Guest, posted on Jan 28, 2009
plugged in. stays at thirty eight percent. wtf
Comment by Guest, posted on Jan 26, 2009
dghdgh
Comment by sigrid6, posted on Jan 25, 2009
i went away for three weeks leaving the cord in but not turnes on at the power point, so the battier is at o% and saying that it is plug in but not charging can i fix it? i have only had the computer for one and a half is it still under warrenty?
Comment by melaniel, posted on Jan 19, 2009
I have the exact problem. I woke up and turned on my computer and now for whatever reason my computer is acting as if its not being charged.
Comment by waldo42ii, posted on Jan 18, 2009
acquired new battery, acquired new adapter, "...not charging"
original battery indicates 31%, new battery indicates 0%.
original charger had cord damage but showed 18.5 VDC output.
Comment by aortiz, posted on Jan 16, 2009
HP Pavillion DV9500 Notebook Laptop reports battery not charching. Battery has been changed and cover by the warranty but after 3 months I am having the same issue. I donot know if this issue is related with Vista or an update/bios I must install.
Comment by makonde3, posted on Jan 14, 2009
i have same problem i have try to remove battery while pc is on wait while and fit it back doesnt work and unnstall microsoft ACPI compl control method battery and scan for hardware change still does work what must i do now stil show 0% plugged in,not chaging my pc is compaq presario f500 is 9month old
Comment by congestoa, posted on Jan 11, 2009
I have an Hp Pavilion DV6000 notebook, bought it nearly a year ago, and the battery SUCKS! it was fine to begin with, but now it dies out in 10-15 minutes max.. or suddenly,itll go blank,i;ll have to reboot,and the remaining battery dies out during reboot and the laptop shuts down! what gives? HP warranty wont cover it because the HP battery check says the battery is "good".
Comment by Suzy K, posted on Dec 22, 2008
when i plug in my laptop it will charge for a few minutes and then it says plugged in not charging
Comment by FrankPa, posted on Dec 19, 2008
My DV6000 will not change the battery. It was fixed for the recall eight months ago, but now it's out of the additional warranty, and the battery won't charge.
Comment by asfaltboy, posted on Dec 17, 2008
the battery is stuck on 42% no matter how many times i unplug and replug and try to recharge .. it sometimes goes up and then goes down and stuck again ... also doesn't hold at all without power.. like for 30 minutes max
Comment by Guest, posted on Dec 15, 2008
My computer just says it is at 0%, stuck there even though it says charging and its plugged in. Just started to happen these past few days. The battery is only 4 months old too and was working fine until about a week ago.
Comment by Guest, posted on Dec 13, 2008
I have a similar problem. My HP laptop is at 0% and it says plugged in, not charging. I did the whole battery-removal thing and after that it would say plugged in, charging but have 0% battery life and stay like that...How dumb is that?
Comment by aim tcb, posted on Dec 08, 2008
my hp dv6000 warranty just ran out and i have the same exactissue with my battery and or battery charger i will never ever againown another hp craptop and none of them people talk goodEnglish what is America coming to. I spent 1600$ on a juiced up customcraptop and now exactly a year later I have madd problems if someonereads this before going with HP save your money an go else where its acheap design for a high price face it HP SUX maddly
Comment by Guest, posted on Dec 07, 2008
when the charger is plugged in you have to wiggle it to get it to charge.... PLEASE HELP!
Comment by camera2, posted on Nov 29, 2008
My HP pavilion dv1000 battery doesn't work,should I have to get a new hp pavilion battery?
Comment by Guest, posted on Nov 22, 2008
My friend has the same problem. My friend or myself plug in the mains charger, it says it's charging then you get a icon of the battery and a little red "x" beside it.
Morgan xx
Comment by Guest, posted on Nov 18, 2008
Samething
Comment by juandavila_1, posted on Nov 17, 2008
Mine says charging but it's stuck at 0% Hp Pavilion dv9000 17''
Comment by zealtred, posted on Nov 14, 2008
Mine says "plugged in, charging" but after 3 days, it's still stuck at 89 percent...
Comment by Ella14, posted on Nov 11, 2008
my computer stays at 0% charge and its been pluged in for over 2 hours!
Comment by Blingpus, posted on Nov 01, 2008
Battery not charging when AC is plugged in. Removing the battery solves problem but re-occur again when AC adapter is removed and put back in...
Comment by signhere08, posted on Oct 29, 2008
My laptop battery stays at zero percent charge, at all times.
The computer will only work if plugged in
Comment by Guest, posted on Aug 13, 2008
my dv6000 battery remained on 52% when my laptop is plugged in...then i used my lap on the battery...it decreased to 12 % ....now it reached 0 % when it is plugged in ...its not charging!!!
Comment by 2sweet808, posted on Jul 25, 2008
glad i found other people with the same problems...got my laptop last year...not powering up...thought it was the adapter...went through 3 already...now it wont power up at all but the adapter works just fine...battery maybe...or port...help...was there a recall on junk batteries
Comment by Guest, posted on Jun 23, 2008
i have had the laptop for under a year and it says that it is plugged in and not charging, even though the charging thing on the side said it was.
i have noticed that alot of people have been having this same problem with this computer and think that this product sucks!
Comment by skulls77, posted on Jun 11, 2008
I had bought a second battery for my HP dv6000 after it had got to 0% not charging and a new battery did the same thing in a couple months.
Yesterday, I noticed I had got up to 1% not charging and found that it was shutting down PC with AC cord in and battery in, take out battery, put it back in. Did it 2 times and second time charge light came on steady and it charged. Seems like when powered down, the charger has a chance of working when putting a battery back in with the power connected as it takes a number of seconds to react with the charger light. Taking battery in and out when powered on doesn't seem to help.
Wonder if it letting it get down to 0% that causes the trouble? Also as a precaution, I remove the baterry after I power it down.
But I see some of you have gotten stuck at other power levels, so trying powering it down with AC adapater and battery in, remove battery and then put in back in, see if charge light will come on steady.
The Hp battery check is junk always recommending to "calibrate" the battery. Also tried re-installing ACPI Compliant Control Method Battery, no change.
3 Cheers for trial and error! HP laptops have problems with their charger systems!
Comment by Guest, posted on Jun 09, 2008
HP has the power card in and has been saying not charging and is stuck on 55%.
Comment by Guest, posted on Jun 07, 2008
I have the same problem !?!?!? I was not use my laptop during 12 days. And when I turn on my HP PAVILLION DV6500 battery icon indicate "plugget in, not charging". Reinstall "control metod battery" not resolve :-(
Comment by moviesong, posted on May 22, 2008
I've only had my dc6000 for 4 months and it already says "plugged in, not charging"... 4 months? really?
- shut down, unplugged, restarted (nope)
- tried a new outlet, shut down, unplugged, restarted (nope)
- called HP (haha. no.)
Comment by 4ran, posted on May 06, 2008
i have the same problem and do not know how to fix it !!
Comment by Guest, posted on Mar 26, 2008
i realised that my laptop was not charging over 1 hour. I checked and noticed this...plugged in, not charging and the battrey meter was red. pls help
Comment by Jamad, posted on Mar 11, 2008
My hp pavilion dv6000 indicates not charging problem even when on power.
Please what can i do, to make it charged.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP HP Pavilion dv6000z 15.4"...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
