Accessing a windows application from my server
Problem :Accesing a windows application from my server
i need my pc to change to a server, so that i can continously run a windows application it.Even if i convert that to a server, how can i acess that windows application through internet.
  • 47 Answers
Get started using Remote Desktop with Windows XP Professional
http://www.microsoft.com/windowsxp/using/mobility/getstarted/remoteintro.mspx
Posted on Mar 01, 2008
When I try to connect to expat shield it will not go past 'starting the VPN' process
you have to edit your hosts file and add the ip of the servers of your organization and also the names (an admin of the domain can help you)
you can find this file in
windows/system32/drivers/etc
then you should have no problem connecting to the dektop applications, etc...
For more details go to the following link:-
http://www.techyv.com/questions/error-accessing-vpn-remote-pc
Nov 09, 2011 | AnchorFree Expat Shield
What is lotes notes.
Lotus Notes is the client side of a client-server, collaborative application developed and sold by IBM Software Group. IBM describes the software as an "integrated desktop client option for accessing business e-mail, calendars and applications on [an] IBM Lotus Domino server." Prior to release 4.5, the termLotus Notes referred to both the client and server applications.
More about here: http://en.wikipedia.org/wiki/IBM_Lotus_Notes http://www-01.ibm.com/software/lotus/products/notes/
Oct 25, 2010 | Computers & Internet
Problem signature: Problem Event Name: APPCRASH Application Name: explorer.exe Application Version: 6.0.6002.18005 Application Timestamp: 49e01da5 Fault Module Name: QuickTime.qts_unloaded Fault...
what is this? is it poping while booting the desktop, or while accesing windows explorer.....try to login to safe mode... does the problem appears there 2?
if not, make a new user, and try again in normal mode.
May 11, 2010 | Computers & Internet
I use frontpage 2003 to edit my site( http://www.riversoftime.com) I am getting an error message on my page called ''Miscellanous'' that reads: An error has occurred accessing windows share point server...
Hi..seems you are trying to edit SharePoint Portal sites using frontpage...open the same using sharepoint designer and with proper administrator credentials..(usually it prompts when you connect to server using a client machine)...All changes done to the application files are then committed on the server- end and will work absolutey fine../
warm regards.
May 06, 2009 | Computers & Internet
Http/1.1 internal server error
If you are running two versions of ASP.NET, you may get HTTP:/1.1 500 Internal Server Error when creating a new Web project or opening an existing Web project in Visual Studio.
This problem may occur when IIS is not sure what version of ASP.NET to use or where to locate ASP.NET files. One of the following solutions should fix the problem.
Solution 1.
  1. Remove web.config file from inetpub/wwwroot directory
  2. Go to IIS, Right click on Default web site / All tasks / Check server extensions and let it run
  3. Reset IIS by right click on IIS or call iisreset from Run command
Solution 2.
  1. Install ASP.NET again using the following command from your Run command: C:WINNTMicrosoft.NETFrameworkv1.1.4322aspnet_regiis.exe
    Make sure to change the windows folder and ASP.NET version folder with the version what you want to install
  2. Reset IIS
Solution 3. Applies to Windows Server 2003
Note: This is a Microsoft KB article:
When you try to create a new Microsoft ASP.NET 1.1 application after you change the script mapping of the existing ASP.NET 1.1 Web application to ASP.NET 1.0 on a Microsoft Windows Server 2003-based computer, you may receive the following error message:
The Web server reported the following error when attempting to create or open the Web project located at the following URL: 'http://localhost/822319ev1'. 'HTTP/1.1 500 Internal Server Error'.
CAUSE
This issue occurs because Windows Server 2003 does not allow two versions of ASP.NET to run in the same application pool.
WORKAROUND
To work around the problem, do one of the following:
Restart the IIS before you create a new ASP.NET 1.1 application. At the command prompt type the following command: iisreset
OR -
Create an ASP.NET application in a separate application pool. Create the script-mapped application (ASP.NET 1.0) in a separate application pool -- for example, in the ScriptMapappPool application pool. Then, create a new ASP.NET 1.1 application in an application pool other than ScriptMapappPool. For more information about how to create an application pool, visit the following Microsoft Web site: Configuring Application Pools http://msdn.microsoft.com/en-us/library/1kdfe21k(VS.80).aspx
Dec 10, 2008 | Acer Aspire 5610 Notebook
Step by step installing of windows server 2003 & its application features.
Windows Server 2003 installation is very much like the standard Windows installation, except you will be prompted with services options.
Depends on what you need - view guides here.
Dec 07, 2008 | Microsoft Windows Server Standard 2003 for...
Some else is accesing my e-mail
First thing that you need to do now is change the password of your email then after that use some anti spyware and anti malware to make sure your computer is clean with those spyware and malware that can capture your email password you can use this softwares Malwarebytes and Superantispyware...
Hope that helps...........
Oct 10, 2008 | Microsoft Windows XP Professional With...
Help
restart the computer and then try it. If that doesn't work install and reinstall the software.
Thanks,
Lee
Jun 17, 2008 | Philips HDD1630 MP3 Player
Computers & Internet Logo
73 people viewed this question
David Payne
David Payne
