Wireless Microphone popping and crackling
Hi. I am having a problem with my Audio-technica ATW-R700 wireless microphone system that I use to mic my trumpet. I sometimes (but not always) get these occasional to frequent 'pops' and 'crackles' similar to that associated with a bad cable. It can happen when I'm completely still. Then I'll jump around to try and make it happen again and it won't. I always have the receiver within a few feet of where I'm standing. It is an intruding signal from somewhere and how do I solve this problem?
  • Alfredo Chiquito
    Alfredo Chiquito Jan 13, 2014
    Hi, did you ever get your situation figured out? I am having the same problem with my microphone... unfortunately it only seems to do it when I have my speakers at high levels. I host karaoke nights at a bar so loud is expected. When I try it out at home at lower volumes, it doesn't clip. I'm wondering if the mic is picking up the low frequencies and reproducing them at louder levels leading to a point where it will clip. I hope you were able to fix your problem, it would help me out with mine.
  • 4234 Answers
SOURCE: How do I change frequencies
These units are not changeable in the field. These are set at the factory.
Dan
Posted on Mar 27, 2008
  • 4234 Answers
SOURCE: Shure wireless headset microphone
The most likely problem is a bad connection between the jack and the internal PC board. If you can solder, you may be able to resolve this yourself. Be careful NOT to alter any of the internal coils. Try resoldering the connector and update this if that fails to resolve the problem.
Dan
Posted on Jul 29, 2008
  • 153 Answers
SOURCE: Dropped the mic.
I would imagine the mic element broke. To test, remove from the case and without touching anything else, touch (using a small screwdriver if need be) the solder connections on the wires for the mic element (while system is up). Hum? Yes? bad mic element. No? Problem with electronics. Look for broken wires also.
The receiver shows signal so RF is ok. You have a problem with the audio section.
Posted on Apr 28, 2009
tvservice306
  • 458 Answers
SOURCE: no sound crackles when switched on volume crackles
TRY CLEANING AND LUBE SWITCH AND VOLUME...........OR REPLACED.....
Posted on Nov 16, 2009
  • 5603 Answers
SOURCE: intermittent crackling sounds DPR 1005
This is an obvious thermal problem. Use circuit cooler to isolate the bad part. It could also be a crack in a circuit board.
Alternate warming with hair dryer and cooling one component at a time while listening for the noise.
Posted on Feb 16, 2010
Testimonial: "I had a CD player sitting on top of the vents... I took it off, blew out some dust and it seems to be working fine now. Thanks for the solution!"
My mic wireless mic sounds like it has a ground loop hum when it is in standy mode and when it is all the way on. I've switched cables and batteries what could be causing this hum?
You could try another power adapter on the receiver, maybe this one blew the filter capacitor. I doubt your problem being the mic, rather check the receiver. Luck !
Nov 10, 2014 | Audio Technica Audio-Technica ATW-T202...
Microphone cutting out during use
reduce distance between receiver and transceiver (microphone)
Adjust antennas not parallel.
Apr 09, 2014 | Audio Technica Audio-Technica ATW-T701...
Change battery on ATW-T210a
Here's the owner's manual for that series. You'll find the battery replacement instructions on page 6: http://eu.audio-technica.com/en/resources/2000a%20Series%20Owners%20Manual.pdf
Nov 12, 2013 | Audio Technica Audio-Technica ATW-T210...
I have a atw-t52 audio techina wireless mic. And when i turn it on thr crackling begins to come through the speakers and i have to play with the input and output cable and move the base unit around and...
I have the same problem in my ATW T52, in st by its ok (the rf leds show perfect signal) but when i set in on the af level start punch and i hear in the monitor a noise like a heartbeat (pum-pum-pum....) Please any answer for this problem
German
Radio del Sol 96.3 Mhz
Villa de Merlo - San Luis
Argentina
May 20, 2010 | Audio Technica ATW-T52 Professional...
I have problem with channel on Audio Technica wireless microfon How can I change the channel because the same things wireless channel digital television and she considers the work of the microphone. Type...
I don't think is possible. But its entirely my point of view,as i feel technically its not possible.
Try checking your user manual provided for microphone. That may offer you better guidance.
Oct 10, 2017 | Audio Technica ATW-R14 DIVERSITY RECEIVER...
ATW-T52, hissing/crackling.
A common problem that SOME have is due to the foam windscreen inside the metal screen rubbing the diaphram of the mic.
Unscfew the dome screen and make sure the foam is out agaist the scree everywhere.
If the dome has become dented, this is my cure: Temporarily remove the foam sheet inside the dome. Put the dome over the handle of a Crescent wrench (has about the right contour). Pound on the screen with a RUBBER mallet, rotating the screen as it reforms! Good as new! Replace the foam sheet and reassemble!
Dec 20, 2009 | Audio Technica ATW-T52 Professional...
Disasimbel freeway atw-t202 for repair
might just be the mic wires came loose...I have oner and the mic is held in by a small rubber O-Ring and as people drop it it falls out and can short out
Jan 11, 2009 | Audio Technica Audio-Technica 200 Series...
HELP
Audio Technica Part number 235401550, call 330-686-2600. The cost is $21.93, plus shipping
Jul 29, 2008 | Audio Technica ATW-T52 Professional...
745 people viewed this question
 Grubhead
Grubhead
