Question about Onkyo TX-SV373 Receiver
Onkyo TX-SV373 blown fuses
Our Onkyo keeps blowing fuses. It went out several years ago and we put it away on a shelf. Recently pulled it downt o try to fix it. Replaced a blown fuse and turned it back on and it immediately blew the fuse again. Any help available that you know of?
  • 1 more comment
  • lespaul53 May 11, 2008
    I have an Onkyo TX-4500 (I know its about 28 years old). And it keeps blowing fuses as fast as I change them. Its the fuse on the back next to the power cord.
  • Anonymous May 25, 2008
    I have the onkyo TX-SV434. I had extended my speaker wire on one side so I could listen to my radio outside. Somehow the spliced wires (both sides) touched until the fuse was blown.I replaced the fuse & it instantly was blown. I need to know what I fried & is it worth repairing.
  • kgm1965 Apr 12, 2009
    I have an Onkyo TX-SV373 Receiver that worked fine for several years.  I moved a few months ago and when I set it up at the new house, it blew the fuse as soon as I turned it on.  I replaced the fuse and the same thing happened.  Being the glutton for punishment, I tried a third time with the same result.  Can someone tell me what to do or if it would be worth repairing???
techman
  • 3130 Answers
SOURCE: amp keeps switching off
There is a problem with one or both of the audio amp circuits. The amp is going into a protect mode as to protect and save your speakers. Sorry but there is no simple fix. this will need to go to the shop to be diagnoised. Good Luck
Posted on Apr 29, 2007
SOURCE: Blown Fuse, needs fix'n
Regarding the last answe, how do you know if it is slow blow or fast blow?
Posted on Jan 21, 2008
tech48
  • 624 Answers
SOURCE: ht-r500 onkyo
When a receiver does this, it is know as the "protect mode". This keeps the receiver from causing more damage to the components in it, by shutting it off when it detects an abnormal amount of voltage or current.
If you had to replace the fuses, it is most likely that you have a blown channel in the receiver.
You put 8 amp fuses in, so I hope that the fuses that blew were 8 amps as well. If you put fuses in that are higher rated in amps than the ones that blew, you will most likely cause more damage to the unit than need be. If the fuses keep blowing, please stop putting new fuses in again until the unit is repaired. Every time a fuse blows, it is because of too much current is going thru the unit. Having too much current is a very bad thing for electronics, it causes components to short out and sometimes even catch fire if the fuse is higher rated than it is supposed to be.
To find out just what parts will need to be replaced, you need a multimeter and then you will need soldering tools to remove the bad parts and put the new ones in.
When an amplifier channel gets blown, there are normally around 5 to 10 parts that will need to be replaced. If you do not replace every single bad part in the channel that has blown, you will most times blow up all the new parts that you just put in.
If you have no experience with electronics, you really should take it in to a service center for repair. If you are willing to try it yourself, let me know and I will guide you thru the troubleshooting steps to help you identify all the faulty components.
Onkyo is very well made equipment and is worth getting fixed.
A blown channel can normally be repaired for around $100 to $150, just depending on the shops rates and the extent of the damage.
Let me know if you need more help.
Dave
Posted on Jul 27, 2008
tech48
  • 624 Answers
SOURCE: yes i have an ONKYO
Yes it is fixable, the parts are available. The cost can vary, depending on the rates of the shop you take it to and the actual amount of damage that it has.
On average, a blown channel in a receiver will cost anywhere between $120 and $200, most of which are around the middle of that amount. I would expect to pay about $150. This is a very good receiver and is well worth the repair cost in most cases. Almost all service centers will give you an estimate before you commit to paying for a repair. If it is a free estimate, it is usually just a free guess. A paid estimate is always more accurate and will normally save you money in the long run. The reason for that is, if a shop owner gives a free estimate he is not going to have one of his technicians look at it and troubleshoot it. If you refuse the estimate he still must pay his technician if the technician has looked at it. A paid estimate will ensure the lowest cost because it will be more accurate. Free estimates are almost always a higher estimate to make sure they can cover the cost no matter what is wrong. Even if they find something small, they will usually charge you the full estimate that you have approved already. With a paid estimate they do not want to loose the job after committing the technicians time to find out what is wrong. Figuring out what is wrong is more than half the battle. Sometimes a technician must actually fix the problem completely just to be sure there is nothing else wrong and that the estimate will be good. Nobody likes to get an estimate and approve it, then a day or two later get a new estimate because they found something else wrong that they could not detect until the other part of the problem was fixed. It happens all the time, I have been a technician for over 18 years and have seen just about everything. The bottom line is, a paid estimate is better than a free estimate. Plus, when you pay for an estimate the shop will apply that payment towards the total repair cost, so in the end it is a free estimate if you get the unit fixed.
Dave
Posted on Nov 11, 2008
petraman7
  • 1175 Answers
SOURCE: i have a onkyo HT-R500
A receiver that recent usually has a detect circuit that keeps the outputs off until speakers are connected . So, if it bows fuses right away , it's really a power supply issue.
Probably the AC rectifier bridge.
Tech service only.
Posted on Jan 01, 2009
Keep blowing fuses.
Possible that there is a short and is much related to the power section or the output driver. You can isolate the outputs , remove the speakers and check to see the power drain current using a series clamp meter. If the current drain is high then the power section must be checked.
Dec 12, 2011 | Onkyo TX-SV373 Receiver
Onkyo just shuts off...
check whether any loose connection in the board of the unit.
Aug 15, 2008 | Onkyo TX-SR605 Receiver
Hi, I have a TX-8511 Onkyo. The left channel is silent. It's not the speakers or the wiring - checked and swapped. Using 8 ohm speakers and switch is set to 8 ohms. Does the same thing on both A & B -...
hello 1 of the transistor could be dry jointed if joint ok then you may a leak on the transistor also check the capacitor around the transistor for bulging all the best
regards
shaun
Sep 13, 2010 | Onkyo TX-SV373 Receiver
Onkyo TX-Sr603 goes back to standby when press On button - help!
does not sound like the fuse.
its easy to check. unplug unit and remove the cowling / shroud of the unit. the internal fuse will look like a car fuse. the old round style about 1" long and 1/4" round.
sounds like a bigger problem. hope this helps.
Feb 19, 2010 | Onkyo TX-SR603X Receiver
My Onkyo HT-R510 will shut down after several
Might be over heating. Make sure you don't have anything sitting directly on top of it. I even put a little fan blowing outward at the back of my system to keep it cool.
Dec 04, 2009 | Onkyo TX-SR501 Receiver
Onkyo tx-sr606b no power - blown fuse?
it either a bad fuse or your transformer that is blown
Jan 06, 2009 | Onkyo TX-SR606 Receiver
ONKYO TX-DS575X - Speaker B not working
You may have blown one of the speakers. Put a different set on them to test this theory.
Dec 16, 2007 | Onkyo TX-DS575 Receiver
Onkyo tx-ds676 dead no power up
power down the amp totally to reset processor, then try again. If still no go, may have blown internal fuses- replace and try again
.... or failed thermal fuse in mains transformer. this is a workshop repair as it involves mains voltage that can kill :)
Nov 24, 2007 | Onkyo TX-DS676 Receiver
Sound cutting in and out
Same problem here....took it to authorized onkyo repair and cost was $700+ for new board. Got the 707 from crutchfield instead.
Nov 09, 2007 | Onkyo TX-DS838 Receiver
Amp keeps switching off
Apr 29, 2007 | Onkyo TX-SV373 Receiver
Onkyo TX-SV373 Receiver Logo
424 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
