Monitor is blue-evrything has a blue tint-i can see colors,they just have a ble tint
My screen color needs fixing.i can see a good clear picture but everything is tinted blue.i can see the colors in everything and i can tell what color is what.they other colors are just so dull bacause everything is tinted there a way to reset the monitor,or do i buy a new one.
  • 4 more comments
  • dannygz Feb 27, 2008
    sorry,bout that. i have a samsung syncmaster cousin was trying to install a nvidea geforce fx 5200 two days ago.the next day all was good,(couldnt install the card,)and two days later when i powered on my computer,it was all blue tinted.
  • dannygz Mar 01, 2008
    thanks, i tried that,but unfortunately,that didnt work you know if there is a way to reset the color or reset the monitor itself.
  • nr6460 Jan 07, 2009
    i have the same problem. my computer and monitor were working fine.
    i connected the monitor to an old computer to check some files. i then plugged it back into my machine. when i turned it on, the screen was tinted blue.
    however, when the monitor comes on, the menu displays sample colors. these colors all appear (RGB).
    I then plugged the monitor, using the same cable, into a third computer. the monitor displayed everything fine.
    the monitor is a gateway lcd, and uses vga-vga cables (it's a bit old).
    the graphics card on my machine is an integrated nVidia one (128mb). i'm going to try another video card.... any ideas?
    i opsted my problem earlier - more details -
    the boot menu has a blue tint, which leads me to believe it's hardware. i also did a system recovery to factory settings, and the problem persists.
  • rajesh1805 Apr 29, 2009
    Even my comp has turned in to tinted blue, i have already checked the cable all appears to be ok, then i just hit the monitor, it first turned into a tint red and then back to normal, I think there seems to be some prob with the monitor itself.
  • Matt Jurach
    Matt Jurach May 11, 2010
    What is the make and model of your monitor?
  • 555 Answers
I've found that strange color tints are usually the result of a loose cable connection, either at the computer end of the monitor end.
Try unplugging both ends, and then replugging both nice and securely (might even try reversing the direction of the cable, if it is a simple VGA-VGA cable).
Posted on Feb 29, 2008
  • Matt Jurach
    Matt Jurach Mar 01, 2008
    I can't find a manual for that model, but usually there is a "menu" button on the front that will bring up an on-screen menu. Usually "reset" is an option, along with fine tuning of the three colors.
  • dalndus Dec 27, 2010
    Spent a couple of hours on this one! It was a loose cable on the back of my HP Monitor. Way to go! I was messing with settings and drivers and the cable on the laptop - it was the cable on the monitor.
I've tried mattozan's solution, it works!
Posted on Feb 01, 2010
I getting blue color in my pc monitor frequently what is the reason
Posted on Mar 25, 2013
I need to get rid of the blue tint on all my pictures
Have you checked your camera's white balance setting ? Try setting it to 'Auto' and see if that helps. If not, then there may be a fault in the camera's electronics, which would indicate repair or replacement.
May 30, 2016 | Cameras
Philips tv's have always had this problem. Between the picture tube and focus lens there is a layer of coolant fluid. The coolant fluid, over time, will break down and turn a brownish cloudy color and it usually starts with the blue. Something to do with the color frequency. Have a good repair shop check it out and if the fluid is the problem have them change all the fluid in all 3 picture tubes (there is a red, green and blue tube). Don't feel bad, like I said all the philips projo's had this problem. Thanks
Oct 29, 2009 | Televison & Video
Picture is clear but with a yellow tint .
Make sure, if your using component cables ,that they match up color for color and are plugged in.If it looks good try adjusting your colors on the TV.You can also try unplugging the TV for 5 min. and then plug it back in.This might be a TV issue.
Jul 07, 2009 | Hitachi 53UWX10B 53" Rear Projection...
see if there is a "default" option, if not set everything back to the middle, if the colors are still off you sure its not the convergence?
most big screens allow you to change "color temperature" it's like a default adjustment for 3 different brightness levels.... ie...COOL, WARM picture will show obvious changes in brightness
Apr 24, 2009 | Philips 50P8341 50" Rear Projection...
No blue just red and green tint
adjust the blue bias on the high voltage block .
it has focus and bias for all three colors
Dec 26, 2008 | Samsung PCL5415RB 54" Rear Projection...
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
White colors schemes seem off white color or brownish color and blue has green tint or baby blue color. .
Check the coolant in all three crt's as chances are it is contaminated (should be crystal clear). If brown (beer color), replace coolant in all three crt's and perform convergence adjust. Picture should be like new!!!
Good Luck!!!
Jul 20, 2008 | Akai PT5598HD 55" Rear Projection...
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
call sony customer service.They will accomadate a warranty fix for that particular problem at no charge.Tell them you say a bulletin on their website for that particular problem your having..
Nov 20, 2007 | Sony KDS-R60XBR1 60" Projection HDTV
Computers & Internet Logo
10,514 people viewed this question
David Payne
David Payne
