Home Pride portable heater NDY-17 or HZ-2003
All switch lights on, fan operates, fake log "flames" but no heat. I assume there is an element in the bottom. Where can I find the element replacement around Baltimore, Md.?
SOURCE: Presto Quartz Heater element 1500 watts
We have a Presto quartz heater and have gotten replacement tubes from: National Presto Industries, Inc., P. O. Box 1172, Eau Claire, WI 54702-1172
In 2004 the cost was 26.00 for two (S&H included). We bought the heater in 1984 and it is still running great - we love it!
Posted on Sep 20, 2008
buzzwood
  • 65 Answers
SOURCE: Dimplex Compact Electric Flame Stove Heater
call Dimples !-800-663-6663 ext 358 They will be able to help you out.
Posted on Jan 21, 2009
SOURCE: Charmglow Electric Fireplace ***NO HEAT** just lights up, HELP :(
http://www.racelectricfireplace.com/docs/Insert_Instruction_Manual.pdf
This is manufactured by Home Depot The customer service number is on the back 800-890-4076.
Posted on Jan 24, 2009
SOURCE: electric fireplace does not heat
I have a cheap electric fireplace bought in SuperCentre store-heater no longer works. It says its a one piece system. Can these heaters be replaced or repaired(probably made in China) or am i better off scrapping it and buying a new one?
Posted on Oct 18, 2009
SOURCE: THE LIGHTS COME ON BUT NO HEAT COMES OUT
A wire has probably burnt off the heater element. Also check to make sure that the air inlet is clean. If the unit becomes dirty it will not work and goes off on limit.
Posted on Nov 08, 2009
Tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 | Heating & Cooling
The fake flame and fan are working but no heat. Is there a reset button somewhere in this unit?
There isn't a reset. It is an automatic reset. Give it a little while unplugged and it should reset 30 minutes then plug it back in and it should work. If not then the chances are you have a tstat problem or a element problem.
Jan 28, 2011 | Stoves Heating & Cooling
Honeywell HZ-709 oil filled radiator heater-all controlls work but no heat produced. Possible reason?? Thanks
There is a bottom element and a top element so the elements could be dead.
More likey, there could be no power coming from the wall - there are switches on the front that need to light up or the thermostat could be set to off.
Dec 07, 2009 | Honeywell HZ-709 Oil Filled Radiator...
Nov 06, 2009 | Dimplex DS5598 Mid-Size Heater
Don't know how to operate
The Dial is the thermostat setting. The rocker switches control the power. Turning on both switches activates the highest power setting. This will keep the heating operation as hot as possible. But it will use the most energy. Turning the switches only one at a time gives you the option of using less electricity at a lower amperage setting. Usually one is the lowest setting. The other is medium and both turned on is high.
Apr 22, 2009 | Soleus NDY-15 Oil Filled Radiator Heater
Take the fan power switch apart and clean the 2 point contacts. Also clean the 4 male studs that the wires plug into. That should solve the problem.
Dec 24, 2008 | Heating & Cooling
15 year old goodman heater is cycling. heating element glows red and the burners turn on for 20 seconds and then goes out. fan is in the on position . after the first light the element turns red but...
Sounds like the flame is either not traveling to the flame sensor or the flame sensor is dirty or bad. Look to the far left of the burner box for a probe near a burner. Lightly scrape and debris from the probe. The probe will have only one wire going to it. Do not touch the igniter or it will break.
Dec 09, 2008 | Goodman GMS90703BXA Heater
My Dayton garage heater model 2E636B does not heat up.
These heaters are the same as the marley heater, the element never gets red hot. the unit is set up so the fan kicks on after the element has heated to a certain temp and turns off after the element has cooled. It is common for these heater fans to cycle on and off quite often untill the air temp reaches about 55 degrees and then will operate normaly. If the fan still cycles too often you may have to replace the fan control and high limit switch. These are not very expensive and easy to replace yourself. they arte usualy attached to the back of the element with clips. The luke warm air is what these units put out. I have an equivelent to the dayton G73 and it heats a 24' X 30' garrage all winter in central Minnesota.
Nov 17, 2008 | Dayton G73 Utility Heater
Heating & Cooling Logo
101 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
