Question about MTX TC2002 Car Audio Amplifier
Short Curcit? My buddies got an MTX TC2002 and try'd hooking it up, the amp is on but the sub cuts out, could that be power from the amp cutting out? the sub works with another amp. if its the amp what should do to fix it?
Call up MTX at 1-800-CALLMTX and one of the customer service guys will help you out, even if the amp's out of warranty they still support the product over the phone for as long as you've got it.
Posted on Mar 27, 2008
    Genius:
  • 1,066 Answers
The amp have an input harness? those can go bad, or maybe line level inputs are loose. If its not just a loose connection on one of the amps inputs (speaker, line, or power) leading to the circuit board( which could easily be soldered back to the corcuit board), than your looking at an integrated circuit problem- not easy to fix.
Posted on Mar 01, 2008
I have a lanzar rack 2000w amp hooked up to 3 mtx thunder competition 12's. just recently my subs have started to cut out and that was when i noticed that the preotection mode light was on and it would...
Try checking your wiring for bare spots or for possible grounds, Also check your subs to make sure the terminals are not shorting out or that the subs themselves may be going bad or shorting out.
Jun 01, 2011 | Lanzar MXA282 Car Audio Amplifier
MTX 8302 sound just quit on front speakers
hi Dan....Have you had any other service or installs shortly prior to the onset of clipping? In any case, the 8302 has Onboard Thermal Protection which is kicking in due to excessive heat. If you've had this running fine for a period of time, by that I mean at least a month, then we need to focus on why you're suddenly overheating......please update your post with any further information and progress.....good luck my friend
Aug 04, 2007 | MTX Thunder 8302 Car Audio Amplifier
I got a mtx ta7801 amp every time I hook it up it says short even when no rca our speaker wires are attached any one have any clue as to whath is wrong
Im sure you have but check all the fuses and be sure ground/power is in the right spot, and check remote wire for cuts
Dec 17, 2010 | MTX Thunder TA7801 Car Audio Amplifier
Mtx 1000xd led light is flashing and the subs will not work
The light flashing usually means there is a short somewhere. Check your wires to make sure there are no slices and are touching. Also check to make sure you have your remote wire hooked up.
Sep 19, 2009 | MTX X Thunder 1000XD Car Amp
When I bridge the BAMF 2200/2 Power Acoustik amp it cuts off
Hello munchisfun,
I'd suspect that the amp is operating into too low of an impedance and going into protection.
The 2200/2 is not rated to drive a 2ohm load when bridged (most 2-channel amps aren't) and when you connect 2 4ohm subs in parallel, the load is 2ohms. I'd run one sub from each channel.
Hope this helps.
Jul 26, 2009 | Power Acoustik BAMF2200/2 Car Amp
Not working
disconnect the subs from the amp and check to see if the amp will turn on and stay on-check the subs to see if they are blown with a different source try a pair or a single sub that you know works fine on the amp and see if it plays-this should tell you whether your amp is fried or your subs are roasted
May 19, 2009 | MTX 4002 Car Audio Amplifier
Car amplifiers
connectors on the rca's are bad. need to be changed out
Jul 11, 2008 | MTX Car Audio & Video
MTX TC2002 amplifier has a noisy gain control
Not really, other than sending it to MTX or an authorized repair shop.
Jul 11, 2008 | MTX TC2002 Car Audio Amplifier
MTX TC2002 Car Audio Amplifier Logo
93 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
