Question about GE Nautilus 24" Built-in Dishwasher
Motor not running?
I have a GE nautilus that was working fine then not used for several months- when I tried to use it again for the first time it filled up with water but then just made a humming noise and then there was no movement. Now the water won't drain and it only makes the humming noise when I turn it on. Is there anything I can do to fix it? Or is it broken beyond repair?
  • 1 more comment
  • aliYazdi May 15, 2008
    I have a GE dishwasher that stopped running. When I close the door turn the latch and put the knob in start position, nothing happens. It was working a few days ago.
  • aliYazdi May 11, 2010
    What is an impeller?
  • DWtired Jan 31, 2013
    I have same problem but cannot find which one is the impeller or blade. Is it inside the white plastic cover or where I pointing at?
If you remove the front panel at the bottom and look underneath, there is a motor staring at you. The motor has blades that look like wings of a fan. If you take a screw driver and try to rotate the blades, you will feel that they dont move freely. This is what someone said, the impeller (blades) are stuck. You need to keep rotating the blades until they get free rotational motion. I had the exact same problem and I was able to fix it this way. Hope it helps.
Posted on Jun 15, 2008
  • 52 Answers
There is a pump motor underneath with an impeller that is most likely stuck. You will need to turn the impeller until it breaks loose if it is stuck. This is a common problem with GE dishwashers and I recommend that you run it at least once or twice a week to avoid this problem in the future, even if you have to run it empty.
Posted on Mar 25, 2008
GE Nautilus dishwasher. Doesnt seem like motor is working
Dishwasher (Nautilus) not draining into sink but leaks onto floor.
Nov 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher won't drain properly
there are several possible causes for your trouble. begin by disconnecting the drain hose at both ends and checking to be sure it is not partially blocked. Then check the pump to be sure there is no chunk of glass or other debris partially blocking it.
Aug 30, 2009 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus Dishwasher.
the pump/motor is froze up because the water has evaporated out of it. turn the motor using the fins and you should feel it free up. unplug ac first
Nov 14, 2008 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus Built-In Dishwasher
This would be the motor that spins the dish washing unit in the bottom. The noise you hear might mean that the motor will need to be replaced.
Sep 17, 2008 | GE Nautilus 24" Built-in Dishwasher
Dishwasher not filling with water
My GE Nautilus, Serial # GSD363F00W, Model # LA774908 is about 3 or 4 years old. I use it at least once a day. It has been working fine. Today I turned it on, red light came on, and I heard activity of some sort inside machine but no water came. Turned washer off, looked inside, no water. Turned machine back on, again heard some sort of activity but again no water came. Tried twisting the dial through the washing cycles, detergent cup dispensed detergent and dry heat come on, but no water.
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
GE Nautilus dishwasher wont run
i am taking it to the dump... throw it in the gutter and go get another...
Nov 28, 2007 | GE Nautilus 24" Built-in Dishwasher
Won't wash, just sits there and electonic buzz noise
check around the element.if you have calcium build up on your element it will smell too
Nov 12, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
GE Nautilus 24" Built-in Dishwasher Logo
262 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
