How can I open up the scanner? It seems like there are no screws and I've tried wedging with a flathead with no luck. I got the control panel off, but cannot get to the inside. I see screws in there, but cannot access them. Is there a way to remove the glass? I do not want to accidentally break it. I already move the switch on the bottom to the unlock position.
Thanks,
Bill
Remove top cover then 4 screws from bottom.
Then start by prying along middle of rear edge. There is a catch in the middle so the top needs to be pried away from the bottom as the bottom is pushed in slightly.
The front has 2 double catches about an inch from the corners. First open the sides and rear, then push sideways (not up) to open them.
Use your flathead screwdriver to pry off the plate on the left side of the elliptical trainer.
Step 2
Look for the magnet and reed
switch. These elements will be roughly the same size, and the reed
switch should have a series of wires connected to it.
Step 3
Loosen the screw in the reed
switch using your screwdriver. Move the reed switch by hand until it
sits 1/8 inch from the magnet, then re-tighten the screw.
Step 4
Test the unit to see if the
display and heart rate monitor are working properly. If not, move the
reed switch slightly so it is closer or farther from the magnet, then
try the machine again. Once you've found the correct location for the
switch, tighten the screw to hold the reed switch in place.
Step 5
Replace the cover plate by snapping it into position by hand
God bless you
My scanner died on a power up. The power supply shows no output voltage when pluged in..so is it bad or does it need a load to have an output. Also...I do not see any screws on the bottom to get this thing opened. What am I missing?
