Question about Miele Washing Machines
Miele transit rods stuck
I have just got my new Miele W3740 washing machine but i can only get 1 of the transit rods out the other seems to be stuck, any ideas ?
Thanks Jackie
  • jacric Feb 27, 2008
    Thank you for your assistance
My husband was able to pull it out .
Posted on Feb 28, 2008
How do I fix a F53 fault on a Miele W3740 Washing Machine
First, unplug the washer for minutes then plug in and see if it solve the problem, if not then check the carbon brushes on the motor. These are a part which is expected to wear and when they do the motor cannot rotate the drum, which means the speed sensor thinks something is wrong and throws the error.good luck. Fixing an F53 on Miele washing machine
Nov 02, 2017 | Miele Washing Machines
How to fix Miele WT2670. No issue in doing the wash, but when it comes to drying, it seems to be stuck in the last 12 minutes . Then eventually the machine stops, but the clothes are still not dry
perhaps the timer has gone bad many times the washer does not spin out as fast as they should thereby making the dryer work even harder to dry the clothe completely .
Apr 06, 2015 | Miele Washing Machines
Novotronic washer w1918 jumps violently when transitioning from main wash to rinse 1-2 with 21 minutes to go to end of wash cycle
If the problem is consistent, FIRST check to make your machine is level. Also try cleaning the machine out with no clothes in it using white vinegar on a hot wash. If you're having a problem with high speed spin with NO load in it, it could be shaft/bearing related which would probably be too expensive to fix. Otherwise you could simply just be adding loads incorrectly or overloading it.
May 19, 2014 | Miele Novotronic W1918A Front Load Washer
There's no delay start on our new Miele W3740 washing machine. Can we use an electronic timer in the plug socket to delay the program start (cheap night-time use of electricity)? Thank you. Gerald
yes you could use a delay plug if it dont over rate the plug,,,check how many watts your washer pulls and how many watts the delay plug can handel first,,,if its more than the delay plug can take dont try it or you may just have a fire on your hands,,
even with cheap electricity is it worth that?
Nov 20, 2009 | Washing Machines
My front load washing machine shakes violently in the final spin cycle. It is brand new and sits level.
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Also - be sure the drum locking (transit) pins were removed by the installer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 03, 2009 | Kenmore Washing Machines
I have opened the drain filter on my miele W3740, but the inside doesn't look like the picture in the handbook. there is supposed to be a bit that goes round. is there another piece to take out before i...
If you are not the original owner - perhaps it was removed.
Jun 17, 2009 | Washing Machines
Transit struts need taking off a miele w3748
The struts are just turned about 90 degrees and pulled from the rear - make sure you keep these in case the machine is to be moved - they need to be reinstalled
Nov 27, 2008 | Washing Machines
Washing Machines Logo
205 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
