I have a frigidaire double wall oven model# pleb27t8ccb. The lower broiler element does not work. I changed it and still does not work. Could it be the relay.
I need a 30" slide in dual fuel range. I currently have a jennair with downdraft in that spot,...
(More)
I need a 30" slide in dual fuel range. I currently have a jennair with downdraft in that spot, with no overhead hood. (also no overhead cupboards) i am looking at the frigidare PLCS389EC. Is this a good choice?
The gas oven in my La Cornue cooker will not light as there is an electrial fault with the ignition...
(More)
The gas oven in my La Cornue cooker will not light as there is an electrial fault with the ignition so the gas is not let out and cannot be lit with a match
Just installed a new Dual Fuel Kitchen Aid M-YKDSS907SS and we can't get any heat from the oven at...
(More)
Just installed a new Dual Fuel Kitchen Aid M-YKDSS907SS and we can't get any heat from the oven at any setting either convection or bake. Also the oven lights are on and will not turn off.
Two nights ago my wife tried to run the self cleaning cycle on our Kenmore range. Unknown to her...
(More)
Two nights ago my wife tried to run the self cleaning cycle on our Kenmore range. Unknown to her mice had nested under the burner plate. Dog food that they had deposited there began to burn, but no flames. we turned off the cleaning cycle and eventually the door unlocked. The next day I disassembled the floor of the range and thoroughly cleaned it. Today after reassembling it the oven and broiler will not light. I hadn't touched the broiler. The the igniter is not heating at all. I didn't disturb any wiring except to remove the igniter assembly from the oven burner. The wires were not strained or damaged. I'm hoping that someone can help. It is the day before Christmas eve and my wife is hoping to be able to cook a Christmas dinner. Thanks, G Andrus
