-   i turn tv on manually and the green light in the on/off switch comes on and goes off 3 times---then will not come back on again-   ralphapugh
Dec 26, 2008
-   my t.v powers up ,then down 3 times then it wont do anything for at least a min. wanted to know is there anything i could do to fix this problem.
-   Guest
Dec 26, 2008
-   my t.v powers up, then it powers down 3 times, then i have to wait around 60 sec tell i can try again. Nothing changes does the same thing all the time.
-   Guest
Oct 13, 2008
-   The set will only stay on for about 5 seconds then loses power-   sluggojr38
Sep 18, 2008
-   Same problem here. TV is only 2yrs old. When it first started, I was able to turn the power off using the directv remote power button. This would turn off the system, but leave the TV on., (no picture, just black screen) (green light still lite). Then just had to push the power button on remote and TV would be on. But had a power outage and it kicked off the TV. Cannot get it to turn on. Same thing, makes 3 attempts, then u have to wait about 60 seconds to try again. Been doing this for 3 days, no avail!!!! Reviews on this system are horrible!!!! Was told that it sounded like a "high voltage problem"-   Guest
When I push the master power switch the red light comes on followed by flashing blue but the set...
(More)
When I push the master power switch the red light comes on followed by flashing blue but the set turns off when I release the master power button
I have the 51" Sony KP-51WS510. I have thin red lines going accross it. I read that there were...
(More)
I have the 51" Sony KP-51WS510. I have thin red lines going accross it. I read that there were six adj nobs behind the speaker panels and that if adjusted right, it may solve the problem. Well i adjusted it and it did fix the problem, but for about 20 minutes or so. The thin red lines came back. I did it 3 times and the same problem happends.. Any more suggestions on what it could possibly be? thank you
TV stays on for 20 seconds, then a blue screen appears and it shuts off. A red blinking light blinks...
(More)
TV stays on for 20 seconds, then a blue screen appears and it shuts off. A red blinking light blinks 8 times after it does this.
TV goes off intermittenlty, goes green then completely shuts down. I do see the flashing light,...
(More)
TV goes off intermittenlty, goes green then completely shuts down. I do see the flashing light, about 8 flashes. I put the power completely off and leave the unit off for 10 minutes or so, then the tv appears to be fine when i power back up. The unit started the problem yesterday, but I simply just went to bed. Today I powered the tv back up about 3:30 PM and the TV appeared to be okay untill about 8:30 PM when the problem re-occured. I read some of the fixes about removing the front panel and making an adjustment but am not sure that this is my solution since my TV is working fine right now.
