Question about Canon MP830 All-In-One Printer
Can't get the ink cartridge out of my Epsonstylus C40UX
Please help me!
I am having the same problem - I am unable to remove one of the ink cartridges - The smaller cartridge was put in the wrong slot and now I cannot remove it. Thank you!
  • 353 Answers
Refer to your printer manual, or the online manual at:
Select "How To", "Replacing Ink Cartridges","Replacing An Ink Cartridge", then "Using the Printer's control panel". Ignore the blurb about lights etc, and proceed from "To replace an ink cartridge using the can't get the ink cartridge out of my Epsonstylus  - fontb1.gif maintenance button ....".
There is also the "generic" approach. Turn the printer on, and as soon as the print head starts to move, pull the power lead out of the printer, or turn it off at the mains. The print head should now be free to move (gently!) by hand to the cartridge change position. The snag here is there is no inherent means of running an ink charge cycle - do a couple of head clean cycles instead.
Posted on Mar 13, 2009
How to change ink
Make sure the printer is on but not printing.
  1. lift the printer cover,
  2. Press the Maintenance button for about 6 secs - the print heads will now move to the center of the printer.
  3. Pull up the clamp all the way for the empty cartridge. The cartridge now lifts up from its holder, remove the cartridge.
  4. The New cartiridge ONLY remove the yellow tape seal from the the black and/or the colour cartridge. Note: If you accidently remove anything but the yellow seal you cannot use the cartridge or it will damage the printer.
  5. Install the new cartridge, tilt the ink cartridge forward slightly as you lower it into its holder. Hang the tabs at the back of the cartridge on the hooks on the holder clamps. Don't place the cartridge tabs under the hooks on the holder clamp; you may damage the clamp when you close it.
  6. Install the ink cartridge and press the Maintenance button this will purge the ink. This takes approx 1min and is complete when the power light stops flashing and the error light goes out.
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 31, 2010 | Epson Stylus C40UX InkJet Printer
I can't figure out how to get ink cartridges out
Simply lift up the cover and the print head should move to the middle and lift the cartridge slowly and carefully out of the holder.
Aug 14, 2009 | Epson Stylus C40UX InkJet Printer
Hi, please tell me how to install a new black ink cartridge into my epsonstylus D78 printer
Open the cover. Press the Ink/maint button (triangle shape on button) this moves the carriage to indicate empty cartridge. keep pressing until carriage moves to the ink replacement position. Open ink cartridge cover and remove the cart. Ensure you remove the yellow tape on new cart' before installing and be careful not to touch the chip on the cart'. Push new cart' in until it clicks. Close lid (ensure clicks down), close printer cover and press ink button again.
Please take a moment to rate this solution, thanks.
Mar 26, 2009 | Epson Stylus C86 InkJet Printer
Were can i down load a free manual on how to use a epsonstylus c40ux printer
Free documents and manuals for the Epson Stylus C40UX are available here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 21, 2008 | Epson Stylus C40UX InkJet Printer
My epsonstylus cx4200 wont print with black ink.
Please ensure that you have removed (Completely) all yellow tape on the top of the cartridge.If it is not completely removed a vacuum can form preventing the flow of ink.
Run a few cleaning cycles.
Try a local print test...
As for thr G4 sorry but I can help you except to power off all devices, power up and reboot.
Feb 09, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Normally hold the cartridge button for about 3 seconds the cartridge carriage will move and then open the door and remove the cartridges. If is does not work the other way is send a print job to the printer wait until the printer starts printing then remove the power cord. Once you have done this open the cover and you will be able to move the print cartridge manually.
Then you will be able to remove the cartridges. If the carriage cannot move and the carriage is stuck and this is the cause of you query then you will have to remove the complete top cove there should be four screws holding this down. Once removed remove the cartridge that is causing the blockage.
I hope this works for you
Thanks J
Jan 11, 2008 | Epson Stylus C40UX InkJet Printer
Epson Stylus C40UX
did you remove the ribbons from the new carts ?
did you go thro the epson utility to replace the ink ?
Nov 10, 2007 | Epson Stylus C40UX InkJet Printer
How do i take out the ink cartridge
Hi Kalola, Here is the link to the document files for your printer, the one labeled *Product Information Guide* is the users manual: Page 6 covers the removal and replacement of cartridges. Let us know if you have any other questions and please don?t forget to rate the posting.
Jan 18, 2007 | Epson Stylus C40UX InkJet Printer
55 people viewed this question
old marine
old marine
