Question about Baumatic Dishwashers
Dishwasher not draining, Baumatic BKD60SS
BKD60SS Hi, the beast is screeching and flashing at me and will not drain. I have scooped out all of the water with a veiw to finding the pump and possibly something stuck in it but to no avail. Help! How do I get to the pump if this is the problem? Thanks.
  • 1462 Answers
SOURCE: Dishwasher stuck on "drain"
not easy to fix - it has a leak. the tray at the base is full of water which ooperates a float which switches drain pump on. remove front panel at bottom front and mop out water or tilt backwards 45deg and water will run out. leak is usually main pump
Posted on Mar 20, 2007
  • 641 Answers
SOURCE: Water Will not Drain
It could be cause the water level switch. The level switch is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine,but if you will open the rear panel you will find it easily. Clear tube from any obstruction. Good luck !
Posted on Jul 27, 2007
  • 90 Answers
SOURCE: help with dishwasher
What Brand is it?
Posted on Jan 05, 2008
SOURCE: Miele G841 Built in. Intake/Drain light on/flashing and the dishwasher just shuts down.
I have the same dishwasher and it will not INTAKE water. This unit does ****. So much for a "smart dishwasher".
Posted on Apr 07, 2008
SOURCE: dishwasher won't drain
Can you kindly help me?
Posted on May 17, 2008
Baumatic b15 drain pump will not stop.
Sounds like a dicky or jammed water level sensor. Get a qualified and licensed technician to check it out. The sensor and labour to replace it should only be around AU$50 or AU$60 dollars (excluding callout or pickup / delivery fees).
Nov 10, 2013 | Baumatic 23 in. BDW5 Built-in Dishwasher
Dishwasher will not drain. Water has to be scooped out with a cup. Where are the filters and how do I get to them?
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Waterwill not drain out
heatman101
Aug 29, 2011 | Dishwashers
Inlet/drain light flashes on miele dishwasher and water will not completely drain away. Model G638l plus help please
the pump is blocked, need to remove the trays, drain plg, the gauze, scoop the water out as much as possible, thge thers a plastic hosing with a spring clip on top, remove this to unblock the pump. assemble & should be good to go.
May 23, 2011 | Miele 24 in. G638 Plus Free-standing...
Intake/drain light is flashing
When this happens with my dishwasher it usually means that the drain is clogged with food/debris.  To fix 1) remove bottom dish rack from machine 2) using a small cup, scoop out as much water as possible 3) remove inlet drain cover and unsnap the plastic insert and remove 4) rinse the plastic part and reinstall 5) start machine 6) if light still flashes, repeat steps 3 4 and 5 and restart
Jul 18, 2009 | Miele G892SC SS Dishwasher
Hotpoint DWT10 Dishwasher error codes/lights
food stuck in drain pump remove and clean out or scoop out - soak up all water then fill with 3 or 4 hot litres of water . cancel programme , start new one ( first thing unit does is switch to drain cycle ).
Then rock machine back and forth - this sometimes frees jammed debris thus pumping out of machine.
This works for me i have done it several times and it works
Jan 26, 2008 | Dishwashers
Lights flashing and beeping on drain stage
When this has happened to us, it has meant a new control panel being fitted. It has been nothing to do with the draining process, just the electronics. The control panel isn't too expensive, but if you call a Baumatic engineer he will come out, do nothing and come out again and it will prob take about a month. I suggest you find a fixed price engineer who will perhaps be able to mend it on his first visit if you suggest the control panel. We have so many problems, we tend to buy in spares in advance so that they are in the house for the engineer and he can't fob us off with a return visit two weeks later. The parts that go are doorstraps, the control panel, the thermostat and the element. We haven't mended the control panel ourselves, but all other problems are pretty easy to do yourself.
Oct 07, 2007 | Baumatic 23 in. BDW5 Built-in Dishwasher
Does this when it can't drain properly - check there's no debris in the collecting basket.
Jun 28, 2007 | Baumatic 23 in. BDW5 Built-in Dishwasher
Dishwashers Logo
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
