Question about Pioneer CDJ-800 Turntable
I can't see the digital readout
Both of my CDJ-800 have stopped displaying any information regarding track, bpm, time etc, both up top and in the centre of the wheel. The audio function plays fine but ive no visual technical info.
It can't be just a coincidence that the exact same problem has happened out of the blue to both turntables within 2 weeks of each other.
I can barely make out the bpm at the top of both turntables, but nothing else.
Please Help
  • 515 Answers
There may have a been a slight power surge which fried either a resistor or IC inside the unit. This is NOT a self repair, and you will have to get it serviced by a professional service center.
Good Luck.
- DJ PRO AUDIO
www.DJPROLAB.com
Posted on Mar 21, 2008
There is a disk stuck in my pioneer cdj-800 on the track display it say 00 e-9101 and i cant eject from deck
hii there,
Please look bottom (turn ur CDJ 180 degree) there will be a pin
to eject the disc from ur CDJ. Also make sure when u do it ur CDJ must be turn off.
thx
djajay
Aug 06, 2010 | Pioneer CDJ-800 Turntable
CDJ800mk2
better take it to the dealer and get it changed since you have the warranty for it.
Jul 29, 2008 | Pioneer CDJ-800MK2 Turntable
A drunk guy throwed a little bit of beer on the cdj (it was REALY just a little bit) and it's having many problems now: FIRST: i can't eject or insert any cd's. I think it is Error 9101. Not sure because I...
If this was brought to me for repair the first thing I would do is completly strip the player to clean out any beer residue. This would involve washing all the plastic parts (top chassis, knobs, jog wheel parts etc etc) in warm soapy water. Any residue on the circuit boards is best cleaned off with a toothbrush and an alcohol based spray / liquid such as Isopropyl alcohol (if nothing else available metholated spirit will do but it tends to leave a purple residue itself).
Some spare parts may well be needed if, for instance the beer has got into the tack switches or pitch fader etc.
Error 9101 is stated as :-
Mechanical time out - Abnormality of disc loading mechanism
so the beer may well have got in the deck aswell but it could also be the electronics are confused causing the deck to do stange things thus generating the fault code - hard to say for sure without having the player on the workbence.
I hope this information helps.
Good source of spare parts :-
http://stores.ebay.co.uk/methleykev
email me on mail@technicsdjuk.com
Jul 04, 2010 | Pioneer CDJ-800 Turntable
My pioneer cdj-800 stops and skips with new CD's
Sounds like a problem with the laser pick-up assembly.
if you havent had your player repaired then you can contact me @ www.audiovisualservices.info
Hope this helps you.
Thank you.
Dec 18, 2009 | Pioneer CDJ-800 Turntable
Pioneer cdj 800 mk2 playing mp3s, jogwheel & screen dont work
More than likely the contact pad (aka Membrane pad) is probably damaged... or the flat cable which connects to the main processor, might be loose, or damaged.
You'll need to get this professionally checked out by a qualified technician. It's not an easy fix.
- OPTiC
Master Tech
Digital Analog Therapy
Pioneer Repair : Pioneer Parts
Aug 28, 2009 | Pioneer CDJ-800MK2 Turntable
Can you help me
Sounds like you have a broken Sheet Switch. Basically, there is a circular piece of plastic which goes underneath the jog wheel, so that when you press the wheel, it activates the switch and stops the track / slows it down, and also puts the indicator on in the middle of the wheel. The part is readily available from Pioneer, and is a bit of a tricky fit, however is not the hardest thing to fit on the unit. However, it is the most fragile part of the player, and most common to fail if the unit has had physical trauma, eg dropping, spillage etc.
Feb 28, 2009 | Pioneer CDJ-800 Turntable
Displays gone on CDJ800
It sounds like a power supply to the both display pcb's is missing, unfortuanetly i wouldnt recommend attempting to fix this yourself, if you havent had it repaired then you can send it to us.
Regards.
http://www.audiovisualservices.info/
Dec 11, 2008 | Pioneer CDJ-800 Turntable
Denon dn-s1000 bpm
Please use the the deck's TAP button to tap in the corect BPM, then it will lock and stay steady. (this is mentioned in the manual) ;)
Oct 15, 2008 | Denon Dns1000 Table Top CD Player CD...
My LCD Display
Well, one of 2 things may have gone bad...
1) Ribbon Cable
2) LCD PC Board
The first is easily fixed. The second, is not. As for service centers, I suggest you contact Pioneer - www.pioneerelectronics.com
- Davis
DJ Pro Audio
www.DJPROLAB.com
www.DJPROAUDIO.com
Aug 04, 2008 | Pioneer CDJ-800 Turntable
I'm having a problem with my CDJ 800. Loading ejecting
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Jan 28, 2008 | Pioneer CDJ-800 Turntable
Pioneer CDJ-800 Turntable Logo
222 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
