I have purchased the Belkin Easy Transfer cable, and have been having problems transfering files, in the start up mode. Will not let me move forward to select the files I want to transfer. stays on the finish page.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 35 Answers
Have you set the computers up for sharing the drives?
Posted on Mar 15, 2008
I want to transfer files from a Windows XP Laptop to a Windows Vista PC. Can I use the Belkin (MicraDigital) Easy Transfer Cable for Windows 8 to do this?
You can go ahead and try this, but I think it would easier to send yourself emails of the files, or use an online cloud storage to transfer the files. Try Google Drive, or OneDrive.
http://www.drive.google.com/
Microsoft OneDrive
Feb 01, 2014 | Belkin Easy Transfer Cable for Windows 8
I just purchased a new laptop that has windows 7. How do I transfer my accounts and files from my old one that uses windows xp?
From the windows 7 computer, Start, Accessories,System Tools, Windows Easy Transfer. Follow the onscreen instruction. Note both system must be on the same network.
Aug 08, 2010 | Belkin Easy-Transfer Cable for Windows XP...
Purchased a belkin easy transfer cable. When
One of the most common problems is the computer's operating system not recognizing the cable's drivers. This is most common with non-English operating systems. The quickest solution is to download the most recent driver.
If the Easy Transfer Cable isn't working properly, you can try a few things to fix the problem. Make sure that you have installed the Easy Transfer Cable drivers on your old computer with the CD that is included in the cable package. If you did not do this, close Windows Easy Transfer, insert the CD that came with the Easy Transfer Cable into your old computer, and then follow the instructions on the screen. When this is complete, begin the transfer process again.
USB ports might be another cause of the problem. When Windows Easy Transfer asks you to connect your computers with the Easy Transfer Cable, try plugging the cable into other USB ports on your computers.
A more complex problem involves the F5U409 USB PDA Adapter (The USB/Serial Portable Adapter) not installing properly. If the driver is unzipping, but the unit is not working, you need to manually update the drivers. They should all unzip to a file called F5U109 in the C: drive of your computer. Point to this file through the Device Manager to update.
Hope it helps.
Mar 21, 2010 | Belkin Easy-Transfer Cable for Windows XP...
I recently purchased a Dell Inspiron 560S with Windows 7. Our present computer has Windows 2000. I bought a Belkin Easy Transfer Cable and note on the packaging it states for Vista and XP. Will it work for...
Unfortunately, Windows Easy Transfer is not supported on Windows 2000. So I would suggest you to return this cable back and use the manual method of transfer of data from one computer to another. Thanks. Abhishek
Mar 10, 2010 | Belkin Easy-Transfer Cable for Windows XP...
I have a belkin easy transfer cable. How do i transfer photo's
On the old computer, run Vista's "Files and Settings Transfer Wizard" to write one large file onto the old computer. The "export" file will contain your pictures.
Copy, via the transfer-cable, that one file to the new computer.
Run the "import" function of the Windows 7 Files and Settings Transfer Wizard to read the copied file.
Nov 17, 2009 | Dell Computers & Internet
Belkin esy transfer cable problem?
Check the easy transfer details on the link below:
http://techtake.net/2009/08/12/windows-easy-transfer-windows-7/
http://techtake.net/2009/08/12/can-i-upgrade-from-windows-xp-to-windows-7/
This may not be a direct solution, but will help you identify the problem.
I hope this helps.
Aug 26, 2009 | Belkin Easy-Transfer Cable for Windows XP...
Connectivity problem with Belkin Easy Transfer Cable with XP and Vista. Presumably, software is installed on both machines (installed F5U258 driver on the XP machine, and was pre-installed on the Vista...
Hi..Start the file transfer on your old pc.When you get the screen to choose the option of using the transfer cable,select it..On your new pc click Start>accessories>System tools and then windows easy transfer..Follow on screen prompts and away you go..Just transfered some hol pics to my new vista machine
Feb 18, 2009 | Belkin Easy-Transfer Cable for Windows XP...
I've purchased a belkin usb 2.0 file transfer cable for transferring old files from a pc with windows 98 to a new laptop with vista, the transfer cable is not picking up the two computers on the old screen...
Hi
Im not sure you can transfer over a USB cable with different OS and filesystems. easiast way is to buy a usb harddrive or usbstick copy data to that. or if the old computer have a networkcard to transfer over a crossover cable or true a network Hub/switch..
Aug 13, 2008 | Belkin Computers & Internet
I have purshased Belkin Easy transfer cable to tranfer data between my old Laptop and new one (old using windows xp new one vista home)I does not appear to work.I have loaded the CD as requested but idoes...
use the Files and Settings Transfer Wizard instead of the Belkin software. It's pretty straight forward in the steps for moving files to "new" computer.
Jun 09, 2008 | Computers & Internet
Computers & Internet Logo
37 people viewed this question
David Payne
David Payne
