Question about Cell Phones
Motokrzr K1 i can not format the memory card
My motokrzr k1 is saying the storage device unreadable and i press ok, formatting wiil erase all data. continue, i said yes. format failed. try again? and failed. i put my memory card to another phone and it work.
what can i do to fix this problem.
thanks
Robero D.
My e-mail address is dominguez@telus.net
  • Anonymous Apr 13, 2008
    I have this problem with my Motorola V365. I bought a SanDisk 2GB Micro SD card and plug it in. I go to load pictures on it and I get the message:
    "Storage Device Unreadable. Format Now?"
    Cancel / ( Ok )
    "Formatting will erase all data. Continue?"
    ( Yes ) / No
    "Formatting: Memory Card" (This message displays briefly.)
    "Format Failed. Try Again?"
    Yes / No
    It doesn't matter what path I use to get to the memory card, the same sequence is activated. The disk works on two cameras of diffrent brands and also my laptop. I can format the disk with my laptop to NTFS, FAT, and FAT32 file systems, but none cange the way my phone sees the disk.
    If I "View Free Space" from the "Pictures Menu", I am shown:
    Lable: Memory Card
    Free 0.00 Kb
    Used: 0.00 Kb
    Total 0.00Kb
    Lable: Phone
    Free 1096 Kb
    Used: 5176 Kb
    Total 6272 Kb
    Is there any solution to this? I want that extra storage space! I want to be able to conviniently move my mp3 ring tones to my phone and my pictures and video to my computer!
  • suzy8186 Jan 03, 2009
    I have a similar problem with my K1 Motrola Krzr. It says the same thing but my memory card WILL work in another cell phone, no matter what card I put in there (any size), it says the same thing about formatting. It has to be a problem with the phone bc my 1mb memory card works fine in other phones. Any help?
I've gotten it to recognize a 1GB card. It seems like there has to be some way to get a 2GB to work, what could be the difference between them? I tried partitioning the card on my computer to 512MB, but it still wont work.
Posted on Jul 27, 2008
  • 3 Answers
Salamz brothers! it is simple many people face this problem so, kindly check your mobiles' those pins which touch the memory card on back side of your mobile. There you will must see one or two pins would have gone punched due to sometime wrong inserting of memory card. just correct those pins and INSHA ALLAH your mobile will must detect your card. Hope it will solve you problem.
Posted on Sep 10, 2010
512MB is the largest M2 chip that the phone will recognize. I have the same phone and the same problem.
Posted on Jun 28, 2008
Unreadable memory card!!!!motorola krzr k1
you may have to buy a memory card reader, plug it into your computer and format the memory card before it will work in your phone, or your phone may require a different format of the same card, for instance some camera's take SD cards, and some take the HD/SD card, and they are not interchangeable, the SD will not work in the HD/SD device and vice versa..........hope this helps........
Aug 22, 2009 | Motorola Mobility Car Charger For KRZR...
UNREADABL MEMORY CARD
Hello, first of all have you formatted the memory card? If not some memory cards have to be formatted in order to work with cell phones, to do this you must have a memory card reader and your computer, plug the reader into the usb, and then insert the card, you should be able too format the card if it is not already factory formatted, if it is not then format it and it should work in your phone.........hope this helps........
Aug 22, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola k1 cannot format unformatted memory card
sometimes there are sd card errors make you format failed. you may get messages like
"Unsupported media card inserted, format now?" error in your smart phone,
"Media is not formatted would you like to format now?" error,
you need to fix sd memory card errors first and them format you sd card.
Jun 04, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola k1 not formatting memory card
hi,
This may be because your phone does not support that ype of memory card. get another one and see if it
May 09, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola k1 is nt reading memory card
try 2 format in some other motorola set and then put it in ur handset. its ur hardware problem that says remove card when u close ur cover try take it out ur memory card and then u watch it says same?
May 08, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola k1 not reading memory card
Motorola phones often require memory cards to be formatted in order to be used. Go into your Setting and Tools menu. From there it depends on which carrier you have and which version of their software, but you're looking for an option for Memory or Storage Devices. It may be under Device Info, Phone Info, or another similar header. Again, the exact menus will vary between carriers and software versions.
Once you locate the menu for Memory/Storage Devices you should see an option for the Memory card. Select it, then choose Options (right soft key) and you'll see the Format option.
May 07, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
To solve motorola v360 storage device
Take a pink pencil eraser and clean (by rubbing the eraser on the contacts on the storage device and see if that doesn't cure your issue?
Good luck.
Feb 15, 2008 | Motorola Mobility V360 Cellular Phone
Memory card problem with motorola v360
Try to format it via a memory card reader by your computer. Good luck!
Sep 13, 2007 | Canon PowerShot A95 Digital Camera
SD Mini card
The best way is to do it through your computer
Sep 10, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
MotoKrzr K1m keeps freezing
you can reformat the memory card from the phone.
It will erase all content on the card and should help. Be sure to back up any important info from the memory card before reformat. All lst data cannot be retrieved.
Jun 15, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Cell Phones Logo
511 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
