I have just installed a new cartridge in my printer It states to do alighment which is fine then it states to put on scanner and press strart no problem after it scans its says alignment error remove tape from cartridge or check troubleshooting. There is no tape I am confused please help
Hello there
Not know your printer that much but I do know with printers with this fault it is the cover sensor or the switch that is at fault try to look where the cover closes there will be some sort of plastic there that comes between the sensor or switch this may be broken or not push in far enough, it broken you can stick some thing there to make it think it closed.
All the Best Pineworks
