Question about InFocus LP 600 Multimedia Projector
InFocus LP600 No power response even with new lamp in InFocus LP600
  • 3 more comments
  • Sourdoe Feb 28, 2008
    I obtain NO power response to even get a LCD display.
    Is there a jumper or such to reset the counter manually?
    IF manual reset brings NO response then will a ballast replacement be likely needed?
    Then it is so, for I don't even have a status light.
    Thanks for your patience & advice.
    Yes, I did try it to no avail.
    Thank you for your help.
  • sheridan1952 May 11, 2010
    Did you let the lamp counter expire? If so, the projector will not do anything until that is reset.
  • 26 Answers
If the counter expired, then the reset is holding both volume keys down for 10+ seconds.
Posted on Feb 28, 2008
  • sheridan1952 Feb 28, 2008
    No. Even with a bad ballast, the projector attempt a power-up.
    You're saying there is absolutely no response, so that rules that
    out. Either it is the counter reset or the main power supply is
    dead. But if it were the main power supply, you wouldn't even
    have a status light on the case.
    Try the reset anyway. You have nothing to lose at this point.
How do I reset the lamp timer on my lp600 projector
You can't. You'll just have to make note of it's current reading just like an odometer of a car when you replace a new bulb.
Dec 06, 2010 | InFocus S/A DOOR LAMP, LP600 Projector...
HI I WANT SERVICE CODE OF INFOCUS LP600 ASKC175
I am not exactly sure what service code you are searching for, what is happening with the projector? You turn it on and immediately it's looking for a code? Please let me know and I can help
Tim
Sep 13, 2010 | IBM Office Equipment & Supplies
The infocus LP600 won't power up
make sure the lamp door is engaging the safety switch. manually reset the lamp hours and reflash the software, if that don't work it's most likely the power supply.
May 11, 2010 | InFocus LP 600 Multimedia Projector
InFocus LP600 - A vertical shadow on the Left-side covering about 20% of screen.
The light tunnel inside the "engine" is either out of alignment or the glue holding the tunnel together is coming unglued and 1 of the 4 sides has fallen in. There are 2 screws to adjust this if the tunnel is still intact. One or both screws can be accessed by opening the lamp door and then you have to remove a thin sticky cover. You will see 2 small screws that will have to be adjusted with a small torx (3) or allen. You will have to have the safety switch pushed in with something and adjust while the projector is on, using the most easily accessible screw, turn it towards the direction of the "banding". It should decrease. If not, turn the screw the other way. The screw that is not so easy to get to is for adjusting the banding the can appear across the top or bottom of the screen. If the banding gets worse or even starts to show diagonally across the screen, it is a good bet that the tunnel has collasped.
May 03, 2010 | InFocus SP-LAMP-019 Projector Lamp for...
LP600 - Lamp Did Not Strike
Check for shorted flat pack diode in power supply.
Feb 04, 2009 | InFocus LP 600 Multimedia Projector
Self Shutdown of my Infocus LP600
power supply problem. if it was overheating, it would go into cooldown mode then standby. there is an issue with the power supply, and it needs replacing. it's about $100 from infocus.
Jun 16, 2008 | InFocus LP 600 Multimedia Projector
Yo
I believe that does mean the lamp is dead. If your model is the LP600, you need the SP-LAMP-019. A quick search on eBay found one for $320 new. From the InFocus website it is $499 so that is not a bad deal. InFocus offers a 6 month warranty, so that is something you will want to keep in mind.
Sep 16, 2007 | InFocus LP 600 Multimedia Projector
Please help
Lp600 went dead
i had the same problem with my 2 years old infocus lp600. on the mains section of the power supply board you have 4 100uF/16v and 1 4,7uF/35V electrolyt condenser of a 85 degree type. that means it will work 2000 hours at 85 degree (celsius). since the power supply only switch off the lamp in standby with no fan the power supply get hot- i think about 70 degree. so after two years in stanby it is evident that this condensers loose halve of their capacity - after switch off no new start. changing this condensers with new ones of 105 degree type will solve tis problem. and for the future - no more stanby.
Aug 14, 2007 | InFocus LP 600 Multimedia Projector
InFocus LP 600 Multimedia Projector Logo
774 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
