Question about Tappan Kitchen Ranges
I have a Tappan Signature 2000 Electric freestanding range and oven model #KTM4853-87A. I am looking for a Thermostate knob
Agent Matt
  • 8 Answers
SOURCE: Unlocking Oven controls
According to the manufacturer's website you should only need to Press and hold the "Lock" key for 5 seconds. A single tone will sound and the "Loc" will disappear off the display.
This is the link to Whilpool's website and to the manual.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209761079.pdf
Thank you
Agent Matt
Go Ahead. Use Us.
Posted on Apr 07, 2008
MNTECH
  • 1543 Answers
SOURCE: installing a double oven where a freestanding range is now
That should not be a problem, as long as there is room. If you do not leave some room below the OTR (Over the Range) microwave you may not be able to remove it in the future. Most OTR microwaves attach to a wall plate and swing up to the cabinet. Then several bolts drop in from the shelf above. If there is no room to swing the micro back down, you will not be able to take the microwave back down when you want to change it or service some components.
Don't bother rating solution. Anything but a FixYa drops my rating. Thanks anyway.
Posted on Oct 12, 2008
duby1990
  • 370 Answers
SOURCE: Older Tappan range oven not lighting.
There is no way to light the oven manually. The gas valve will not open until the oven ignitor draws enough current. But replacing the ignitor will fix ya up.
Posted on Nov 19, 2008
SOURCE: Inglis electric freestanding range model #IRE3230- Oven no longer working
If the oven and the electric panel no longer work, this is an electronic problem. The burners and the oven light will not be effected, nor will the fuses. The electronics card will need to be replaced by an appliance technician.
Posted on Nov 25, 2008
  • 74 Answers
SOURCE: Oven wont heat
Repairing the Oven Setting Control
When the oven setting control malfunctions, the oven won't heat. Here's how to repair an oven setting control:
Step 1: Remove the control knob.
Step 2:
Remove the back service panel or the front panel, if necessary. Remove other control knobs as needed to remove the panel. The oven setting control is located directly in back of the control knob and is usually held to the control panel by two screws.
Step 3: Testing the control with a volt-ohm-milliammeter (VOM) is not recommended, because the results will not always be conclusive. If you suspect that the setting control is faulty, the best procedure is to substitute a control that you know is working, or you could simply replace the faulty control with a new one made for the oven.
Step 4: Disconnect the electrical lead wires from the control terminal and lift out the control. Connect the new control the same way the old one was connected.
Posted on Jun 05, 2009
Need Instructions on Self-cleaning for my Tappan Electric Range
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 28, 2010 | Tappan TEF242 Electric Kitchen Range
No gas going to oven
Hi blocked oven pilot , ffd not working oven burner blocked injector blocked
Feb 02, 2010 | Tappan 24 in. Freestanding Gas Range...
Oven use blows fuse
One of the oven elements is probably grounded (shorted). Pull back off oven and inspect.
Jul 09, 2009 | Ovens
Need owners manual for Tappan TGF334BCWb oven
Looking for Owner manual for a Tappan Gas Self Cleaning Oven Range - Model No. TGF 365BEWB
Nov 14, 2008 | Tappan TEF242 Electric Kitchen Range
Tappan TGF336ASD stove Calibration of the oven
does it have a knob in front or is it a panel to operate bake broil ? if it has a oven knob take it off and look in the back of the knob you adjust it there if it is electric if it is gas you need to use a small screw driver in the stem where the knob goes on and turn a little screw in there to ajust temperture turn clockwize to adjust temp up
Aug 13, 2007 | Tappan TGFS_63 Gas Kitchen Range
Kitchen Ranges Logo
388 people viewed this question
Top Tappan Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Sal De
Are you a Tappan Kitchen Range Expert? Answer questions, earn points and help others
