Question about MSI K8N Neo4-F Motherboard
K8N Neo4 and Vista
Hey there.
After I had installed Vista Home Premium my computer´s complete shut down process had worsen. With XP pro it was about 30 secounds but now it is around 10 minutes.
When I press "Shut Down" Vista turn it self off in less than 30 secounds but the cpu fan stays turned on for the rest of the time. What is also new is that I bought a new processor, I had Amd 64 3500+ 2.2 GHz, but now I have Amd 64 Dual Core 4200+ 2.2 GHz and I also have 4 GB ram.
Does any one have idea what can be wrong or have a suggestion what I might be able to do to fix that.
Sincerely
Mr. Saemundsson
  • 32 Answers
It usually means that there is a piece of hardware or a program that it is having trouble closing. Try defragging the drive some times that can help things quite a bit. Also make sure you have the latest drivers fro all your hardware.
Posted on Feb 28, 2008
Are there windows 7 drivers for a MSI K8N Neo4-F Motherboard
There is neither Windows Vista or Windows 7 Drivers for the MSI K8N Neo4-F. It is not compatable, http://us.msi.com/support/mb/K8N_Neo4F_PCB_1.0.html#support-test
May 17, 2014 | MSI K8N Neo4-F Motherboard
Audio driver download
Download here at msi:
http://www.msi.com/product/mb/K8N-Neo4-FI--PCB-1-0-.html#/?div=Driver&os=XP%2032
Select your windows system
Download the sound driver and unzip the file
before you install.
Good luck
Feb 25, 2012 | MSI K8N Neo4/SLI Motherboard
Controller MSI K8N Neo4 does not work
SHUT DOWN COMPUTER AND CLEAR CMOS BY RESETTING JUMPER ON MOTHERBOARD AND THEN RETURN JUMPER TO NORMAL POSITION OR USE RESET BUTTON. UNPLUG ALL HDD SATA CONNECTORS FROM HDD. BOOT COMPUTER TO BIOS. MAKE SURE ENABLE ALL SATA IS ENABLED, PRESS F10 AND EXIT.YOU WANT TO SHUT DOWN AGAIN. NOW REATTACH SATA HDD AND CONNECTORS AND BOOT TO BIOS AGAIN. NOW HIT F10 AND LET COMPUTER RESTART AND LOAD INTO THE OS. LOGON AND CHECK DEVICE MANAGER..SHOULD BE THERE. IF NOT CHECK MOTHER BOARD WEB SITE FOR BIOS UPDATE. IF BIOS UPDATE DOESN'T DO THE TRICK, SHUT DOWN AND DISCONNECT THE IDE DRIVE, UNLESS IT CONTAINS YOUR OS. TRY BOOTING TO BIOS AND CHANGE ORDER OF 1ST BOOT OPTIONS, HIT F10 AND EXIT AND ALLOW COMPUTER TO BOOT TO OS, THEN LOGON, GO TO DEVICE MANAGER AND REMOVE IDE AND RESTART, ONLY IF THIS HDD DOES NOT CONTAIN OS. YOU SHOULD BE FINE AFTER THIS, OR INSTALL YOUR OS ON THE SATA HDD.
Apr 09, 2010 | MSI K8N Neo4 Platinum nForce4 ultra K8...
Pro tools m-powered problem
You may need to check to see which "service pack" you are currently on.
See below requirements:
System Software — Windows XP & Vista
  • Windows Vista Business or Ultimate Edition
    • 32-bit OS Installation Only
  • Windows XP Professional or Home Edition
    • With Windows XP Service Pack 2 or Service Pack 3
  • Not Supported:
    • Windows Vista 64-bit (any version)
    • Windows XP Professional x64 Edition
    • Windows XP Media Center Edition
    • Windows 98, Me, 2000, NT, 95, 3.1, DOS
  • Not Tested:
    • Windows Vista Home and Home Premium Edition
    • Although Windows Vista Home and Home Premium Edition have not been tested or qualified by Digidesign, there are currently no known issues with Vista Home and Home Premium 32-bit operating systems and Pro Tools M-Powered 7.4 compared to the supported Windows Vista Business or Ultimate Edition operating systems.
Windows Vista SP1
There are currently no known issues with Service Pack 1 for Windows Vista based on our initial limited testing and customer feedback. Although full qualification with all Digidesign products has not been completed, we do not recommend against updating to SP1, given the number of important overall system fixes in SP1. We do recommend that you backup your system and create a restore point before updating to SP1, should you encounter any problems after installing the update.
Sep 21, 2009 | Computers & Internet
I want to remove my Vista Home Premium (64 bit) os and replace with XP Pro
All you need to do is insert your Windows XP disk at start up and boot the disk by pressing any key when prompt to. Then run a clean install since a upgrade will not be available. You may want to backup your programs e.t.c.
Regards
Jan 05, 2009 | AMD Satellite L355D-S7829 Laptop
Vista Home Premium locks up on a load
How long do you wait before you determine it is locked up? Vista uses minimum graphics to facilitate a faster install. It may seem like nothing is going on when Vista is loading in the background. If it is locking up try a reinstall. Are you upgrading or going a new install?
Dec 30, 2008 | MSI K8N Neo3 Motherboard
MS-7125 ver1 K8N Neo4 motherboard problem
Do you have the K8N-Neo4 motherboard? MS-7125 is the intern p/n for the K8N
If so, try this address, these are the most recent drivers for the motherboard.
http://global.msi.com.tw/index.php?func=searchresult&keywords=MS-7125&table=download
Hope this is the answer you're looking for
Nov 19, 2008 | MSI K8N Neo4-F Motherboard
Cannot find drivers, especially integrated LAN support
Hello there.
Please click here to see the webpage with the drivers. Your ethernet uses NVIDIA nForce4 System Drivers so thats the one to click, make sure to choose 'Vista' instead of 'XP'
Notice there are other drivers on the website too. For example sound.
Hope this helps.
May 16, 2008 | MSI K8N Neo4-F Motherboard
MSI K8N Neo4-F Motherboard Logo
51 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
