Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Whirlpool ThinTwin LTG6234DQ1
Won't spin washes and drains ok but won't spin makes a ratcgeting noise seems to be comming from the large motor housing . I have washer disassembled covers top and bottom but no sure of next step.
Thanks
    Novelist:
    Champion:
  • 244 Answers
Have you checked the carbon brushes in the motor 1 on either side of the motor with a wire going to each brush carbon should be at least 1in in length and can go down to about 8ml b4 they need changing m8
Posted on Feb 28, 2008
CHECK YOUR LID SWITCH IT HAS PROBABLY CAME LOOSE OR IS OUT. YOU CAN USE A OHM METER TO CHECK IT OR UOY CAN JUMP THE WIRES WITH A TEST LEAD
Whirlpool cabrio (4yr.old) making loud motor straining noise on final spin cycle.
Hi valued Consumer, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Valued Consumer), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 24, 2017 | Whirlpool WTW6400SW Cabrio Washer
After washing it makes loud noise & won't spin or drain
You shoul inspekt water outlet on the bottom of the drum. There is mabye something inthere.
Dec 02, 2017 | Washing Machines
What should i look for on my whirlpool washer if it hums but won't spin, agitate, or drain?
The motor may be shot if it is getting current and won't operate the washer.
Nov 04, 2011 | Washing Machines
My Kenmore washer (22712) won't spin. It washes and drains.
The number one thing wrong when that type top load washer makes noise and does not spin, is a broken coulper between the motor and the gearcase. This tip i wrote will show how to replace the coupler...follow it to take apart the washer to see if the coupler is broken,if it is my tip will also be helpful to replace the coupler. http://www1.fixya.com/support/r10293994-whirlpool_made_washer_not_agatating
GENE
Oct 08, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
The washer filled up with water but not won't drain spin and is making a funny noise . It's an older magic chef.
The most common issue would be the coupler for the motor transmission. It is a rubber coupling and when it goes bad it makes a grinding, or whirring noise and the machine won't spin or wash. You need to remove the cabinet and look directly under the tub where the motor and tranny connect. This is a reletivly easy and cheap fix. Just google how to replace motor coupling on a top load washer and you may also include your make and model for more direct instructions.
Jun 23, 2011 | Washing Machines
The spinning thing won't spin all of a sudden. The washer is making a lot of noise and will drain but won't spin. How do you take the back off?
The motor has a double pole on it. The pump is driven on one side of the motor. The basket is driven on the other end of the motor. So if the water is pumped out then the lid switch is fine. What you have is a broken drive coupler. Usually breaks on a heavy load like rugs or quilts. Low water on a heavy load can break it too. Or simply old age.
Video:
Repair manual and more photos HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 07, 2011 | Whirlpool LSN2000LW Washer
Whirlpool washing machine won`t spin or pump out
if youre handy with tools , check out the DRAIN MOTOR PUMP , usually located at the bottom on a side of the washer , it could be clogged with lint or debris , need to open washer , remove the DRAIN MOTOR , inspect inside to remove and clean it , be ready with rags , theres a lot of water that will come out once you remove it . good luck AJ
Jun 08, 2009 | Washing Machines
Whirlpool ThinTwin
have you checked the carbon brushes in the motor 1 on either side of the motor with a wire going to each brush carbon should be at least 1in in length and can go down to about 8ml b4 they need changing m8
Feb 27, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
529 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
