Question about Kyocera Mita KM-1815 All-In-One Laser Printer
Scan error C3200
I have a Kyocera Mita KM-1815 printer error when scanning-Error C3200. May scan one or two sheets then I get this error. We have to turn the printer off and on to clear the error message.
Remove the flat wire in the scanner, then remove the railings from the scanner, clean the railings with a soft cloth, if you encounter the c3200 error it only means that the railings of the scanner is dirty, the scanner cannot move. i hope this will fix your problem..... if you have anymore questions regarding kyocera copiers dont hesitate to txt me or call me to this number +639081953003 or +639079941995
Posted on Aug 17, 2009
    Problem Solver:
  • 10 Answers
C3200 indicates a problem with the exposure lamp. You can try to clean the optics and check the lamp. It may need parts if cleaning does not fix it.
Posted on Feb 27, 2008
    New Friend:
The Scanner ISU has a board on the back, Parts ISU must be replaced if the above fail. Technician#
Posted on Oct 08, 2015
  • Ames
    Ames Nov 06, 2017
    yes that good just now i fixed this error 3200
Kyocera 1815 la y sale error c6020
The error means - Abnormally high fixing unit thermistor temperature.
Can be caused by Shorted thermistor or Broken heater control circuit on the power supply board.
Jan 19, 2011 | Kyocera Mita KM-1815 All-In-One Laser...
Unable to copy with my Kyocera KM-1815. Error code is C3200.
Typicaly the scanner optics would need to be cleaned. Or it could be a scan lamp failure. A Kyocera dealer could help you with this.
May 27, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
Kyocera c3200 error Problem
A C3200 is as follows:
Exposure Lamp Problem.
• In indicator check before starting copying, the average value in scanning of the shading plate with the CCD is 128 or more.
Solution:
Defective scanner board (KP-5063).
Replace the scanner board (KP-5063) and check for correct operation
Defective exposure lamp or inverter board.
Replace the exposure lamp or inverter board.
Incorrect shading position.
Adjust the position of the contact glass (shading plate). If the problem still occurs, replace the scanner home position sensor.
Poor contact of the connector terminals.
Check the connection of connector YC7 on the scanner board (KP-5063), and the continuity across the connector terminals. Repair or replace if necessary.
These are direct from the Tech man.
More than likely it is the Exposure Lamp.
Hope this helps.
May 02, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
C6000 on Kyocera KM-3050
you can try to reset the error code by going into
simulation mode
at the machine punch in 10871087
once in simulation mode.. go to sim 163
that's a fuser reset
execute that..
if problem persists you need to replace fuser
Mar 10, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
How to fix Error code C6020
I have The Km C2520 with the same C6020 code. Is the solution the same?
Jan 26, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
Error c710
it means that toner cannot enter the developing section of the copier, all you have to do is remove the developing unit, then pour it with enough toner, the problem will be solve.
May 17, 2009 | Kyocera Mita KM-1815 All-In-One Laser...
SYSTEM ERROR
error 610 machine kyocera km-3035 ????
Nov 05, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
Kyocera Mita km-1820
Unplug the power cord for 10 seconds.
Oct 20, 2008 | Kyocera Mita KM-1815 All-In-One Laser...
Kyocera Mita KM-1815 All-In-One Laser Printer Logo
5,387 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Adorjani Laszlo
AAAA262430
Marvin
Marvin
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
