Maytag washer wont drain
I have a maytag neptune tl top loader washer it does not drain when on spin and I get code uC on the control panel.
  • 4 Answers
You most likely have a bad drain pump.
Posted on Feb 27, 2008
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
We just moved and the house came with a Maytag Neptune TL which won't spin if there are clothes in the cylinder. It will spin empty. Please help! Thanks.
Washer bangs around in spin cycle and throws a DC or UC unballance code with cloths in the wash basket is that correct?
If so it's a Clutch issue.
If you want read more about what I feel is your issue read this post Maytag Neptune load unbalance
Sep 08, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Washer want pump out all the water and it will not go in the spin cycle, and it cut off display UC Code
Google this Neptune TL Washer FAV6800AWW
5th post down in the sticky you will find my service notes to get you back in service.
Mar 10, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My washer has a uC fault. I replaced the tub sensor but it still alarms after spinning. The water drains, the tub spins slow, then alarms uC. Thank you for your help.
Dave,
Sorry you replaced the TDS.
Google Neptune TL Washer FAV6800AWW that's the Sticky for your machine type. The 5th post down you will find notes to repair.
Post a new thread in that DIY forum not the Stick if you need additional help.
Feb 03, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Continue to receive a "DC" code on the Maytap
I no longer post on this site no way to post a Sticky.
If you want to DIY the repair Google this phrase ""Sticky: Neptune TL Washer FAV6800AWW""" Read the post Part 1; DC or UC unbalance error codes in Spin Cycle what is causing this issue? Part 2 for the fix action.
Post your issue in the repair forum not in the Sticky. Please include your Model Number i.e. FAV6800A or FAV9800A and I will help you.
Jan 22, 2011 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune tl fav6800aw top loader sounds bad and wont spin or drain half the time any ideas were to start. It is about 4 years old
Sorry I missed your post I feel I can help you if you want DIY the fix. From your description it sounds like you have a Clutch malfunction see this post Clutch Fix for support.
Let me know if I can help you thru the issue………Rich
Jun 10, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Neptune Washer Spin Cycle
If your FAV6800A or FAV9800A wash tub is banging around in Spin Cycle of the Wash Cycle and your Control Board signals a dC or uC error code to the console I feel you have a Clutch malfunction. I feel the TDS is working as designed with the unblance error code shut down.
See my Clutch Fix post for more info related to dC and uC unbalance errors with the FAV6800A and FAV9800A TL’s and the repair action…….Rich
May 10, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Wont Finish Spinning stops and Flashed DC
If the machine type is a FAV6800A/FAV9800A see this Clutch repair post if you want to DIY. You will find links to the Service Manual and parts info if needed.
You can check out the TDS but I would go right to the Clutch repair post if the machine shuts down in with a error code dC or uC.
That means the TDS is producing analog voltage swings +3.5VDC to 0VDC to the input of the Control Board Conn_P3 pins 10 and 11. Those DC voltage swings are at the design limit of max Wash Tub movement and the Control Board shuts the Spin Cycle down……..so thebTDS is working as designed.
The machine will make several attempts to redistribute the load before error code generation failing with dC or uC error codes.
Post back if you have questions any DIY'er with basic skill sets can do the Cluch maintenance/repair.....Rich
Jan 04, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Wont spin with clothes
Common problem with this model I own it. Sounds like the roller clutch bearings in your machine are seized/rusted up. Do you want to try to DIY the repair? Read thru this post for the details of what is involved. Post back with any questions. Rich
May 03, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Neptune won't advance from Rinse to SPIN
If the clutch fails the first thing noticed is a UC or DC error displayed and there is no drain or spin.
If you are seeing the above error and having a problem with spin and drain then the most likely cause of this is the clutch. The clutch fails to lock down the spinners and the basket is unable to go into spin and without a 90 RPM there is no drain.
Replace the clutch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question(@#$^
Aug 01, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
224 people viewed this question
Top Washing Machines Experts
