Question about Konica Minolta magicolor 2400 Laser Printer
Two white spots on printouts
I had a bad paper jam, the paper was shredded in pieces. I had to use
a screwdriver to fish the shredded paper out of the roller. The printer
is working again but now there are two white spots size of of 3mm square
that would show on every printout. Is it possible to disassemble the
roller part to see if there are any paper stuck out there or did I possibly
scratch the lens?
Thanks
Ned Kamar
  • nkamar Feb 28, 2008
    I solved my own problem. It turned out that the film on the transfer belt unit got wrinkled which caused the white spots. I wonder if I can replace only the film short of replacing the whole transfer belt unit.
    Ned Kamar
  • skhub Apr 15, 2008
    We also have white spots. The transfer belt has bubbles in the same areas. Does anyone know how this happened? Is it hard to replace the transfer belt unit ?
    SK
    Champion:
  • 214 Answers
Its not hard to replace TBU, remove 2 skrews and open connector and reinstall a new one. but be careful with the new on. also you cant buy only TBU fil, you have to the whole TBU and even if you find new film, replacing that film is a 10 times harder. so its not worth the risk of damage the film.
Posted on Jun 19, 2008
Qualcast manuals
Unplug it and look inside the shredding blades, especially around the spot usually near the center, where there is a pressure button. When paper hits it, it starts shredding. Chances are some pieces of paper have jammed just over it stopping paper from hitting it and switching it on. I have had to use long tweezers to work the jammed bits out... Once clear it will work again. Also using shredder oil every 50 sheets through will help it cut easier , and jam less frequently. Do not put too many sheets through together in a bunch. No staples...
Aug 25, 2014 | Office Equipment & Supplies
Omnitech shredder ot-nxc10pa
You must first unplug it and look inside the shredding blades, especially around the spot usually near the center, where there is a pressure button. When paper hits it, it starts shredding. Chances are some pieces of paper have jammed just over it stopping paper from hitting it and switching it on. I have had to use long tweezers to work the jammed bits out... Once clear it will work again. Also using shredder oil every 50 sheets through will help it cut easier , and jam less frequently. Do not put too many sheets through together in a bunch. No staples...
Aug 23, 2014 | Office Equipment & Supplies
False paper jam
I had this problem with an HP Laserjet printer. An old, dry piece of paper got mangled as it fed through. I finally used a bright LED flashlight and examined the entire paper path. Found a tiny shred of paper lodged deep inside. Removing that tiny shred with tweezers solved the problem.
Sep 02, 2012 | HEWLETT-PACKARD Hewlett Packard OfficeJet...
I can't remove the basket to empty
Its probably jammed with shredded paper to the point where the paper is stopping you from removing the basket. You will just have to try to open it enough and "fish out" some of the paper so that the level goes down and the basket can be removed.
In extreme cases if you let the basket overfill then the "shredded" paper gets caught back up in the cutting blades and you can jam the machine and fry the pcb inside.
Sep 16, 2010 | Royal PX1000MX Shredder
Shredder screen reads door open even if the door is closed and wont let me do any shredding
Unplug it and then open i t up. You are looking for a piece of shredded paper that is stuck or jammed. Can even be a accumulation of paper dust. The piece won't be that big but most of the time that is all that is wrong. The paper either jams the door sensor or blocks it and gives the error. It can also be a bad door sensor or switch. Not very common but can happen.
Apr 25, 2010 | Universal Office UNV-38016 Shredder
Fellowes 3011001 shredder stopped shredding. tried to remove shredded pieces but could not.
First, try switching to reverse, alot of times, stuck paper will come back out in reverse. Then unplug the unit, turn the head upside down and with a small flathead screwdriver, knife, or tweezers, dig out pieces of paper. It takes alot of effort but by digging small pieces out, a little at a time, you can get most of the paper free.
Nov 15, 2009 | Fellowes 3011001 Shredder
Continues to report paper jam even though no paper; reset does nothing.
Try to look for the sensor as some tiny paper shreds might be blocking it which causes the system to detect a paper jam.
Also look for tiny pieces of shredded papers that might got stuck between the rollers.
Aug 01, 2009 | Lexmark X6570 InkJet Printer
4250tn print black spot
You either have a bad spot on the drum or a bad spot on the fuser rollers. Replace the cartridge first. If spot continues, take cartridge out and get inside with a flashlight. You'll probably find a piece of paper stuck to a roller.
Apr 04, 2009 | HP LaserJet 4250n Printer
Shredded paper is wrapped around blades
Try saturating paper jam with liquid vegetable based cooking oil from your kitchen this should soften the paper after sitting 6-7 hours
Oct 28, 2007 | Quartet gbc 1150X Shredder
Konica Minolta magicolor 2400 Laser Printer Logo
74 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
