Question about Canon PowerShot A530 Digital Camera
Won't take picture when flash is turned on
When I have the flash set to be on automatic or as on, the camera won't take a picture. When I press the button, the green boxes will never come up, and I just wait forever. The flash symbol (the lightning bolt) will blink on and off.
I have found that it works fine when I turn off the flash, but it's pretty impractical to never be able to use the flash, so I'd like to get it to work with flash as well.
Note that I checked this one: http://www.fixya.com/support/t192776-canon_a530_powershot_snap_picture, which was similar. However, I do get the orange light. I checked on the recall and my camera is not one of the ones that has been recalled.
  • FlickaMawa Mar 02, 2008
    Thanks. That might be it. I was using alkaline batteries, because my NiMH ones don't seem to be charging properly in my recharger. I'll get my hands on some that work correctly and see if that fixes it. But I did discover that the alkaline ones work for a very brief period after I put new ones in, so maybe it is more than they can handle to keep charging the flash.
  • Canon Master
  • 4,738 Answers
Charging of the flash may be overpowering the batteries that you're using. Are you using alkaline batteries? If so, recommend instead trying rechargeable NiMH batteries rated at least 2500mah to see if the problem still exists.
Posted on Feb 28, 2008
Canon pc1251 won't take picture with flash on. it will if i turn off flash
Check if your camera is on automatic. Then f there is too much light it won't work. To use a flash for fill in, you have to be on a scene mode. Check the manual. If the camera has a flashing light, indicating the flash won't work, you have a serious problem.
Dec 10, 2014 | Canon Cameras
Samsung mhx-w300 won`t turn on
you must press the reset button inside the SD card door. Remove the flash card first. this should allow you to power the camera on.
Feb 04, 2014 | Samsung HMX-W300
Canyon eos auto mode= won't take a pictuRE
Push your shutter 1/2 way down. See whats the readings in view finder.
Jul 04, 2013 | Cannon EOS 50D Digital Camera
My Sony Steady Shot DSC-S950 won't flash. I have pressed the flash setting several times as suggested in blogs to no avail.
Sep 15, 2011 | Sony Cybershot DSC-S950 Digital Camera
How do i get the flashed turned on
First, check to make sure you're not in the macro mode. There's a slide switch on the end of the camera, near the SD card slot. Slide the switch away from the flower toward the mountain to take it out of macro mode. The flash won't fire in macro mode.
Then, if the flash still doesn't fire, take a look at the flash mode. Press the up-arrow button to bring up the flash menu. If it's currently set in the lightning-bolt-in-a-circle-with-a-slash-through-it symbol, you've got the flash turned off. Set it to the lightning-bolt-and-"A" for automatic flash or the lightning-bolt for forced flash.
If the flash still doesn't fire, then it's broken.
Sep 10, 2011 | Vivitar ViviCam 5024 Digital Camera
My camera is several years old. The flash stopped working. I replaced the batteries. Any ideas?
Here are some simple things to try first for a camera that won't take a picture when the shutter button is pressed, or with an inoperative flash. They won't work for every case, but they're worth a try:
Aug 30, 2011 | Canon PowerShot A630 Digital Camera
My Nikon Coolpix s230 flash won't work. It just blinks red in the lower right hand corner. I've tried all the settings and they all won't flash.
If there is a problem with the flash itself or the mainboard connection to the flash it will not charge. If the flash won't charge then it won't go off when you take a picture. The only way to fix the problem is to replace the flash with a good used one and see if that fixes it. If not, then you need to replace the mainboard. Good used parts can usually be found online for cheap; that auction website doesn't pay me to type their name, so I don't, sorry. Hope this helps!
Thomas Drayton
Owner, www.darntoothysam.com
Affordable Digital Camera Repair
Jul 24, 2011 | Nikon COOLPIX S230 Digital Camera
HI-- I have just purchased an old Olympus Trip MD 35mm automatic camera, with in built flash. I think have correctly loaded the fillm and batteries, but it won't turn on...It won't take pictures...
Make sure that the batteries are good. If it does not work with known good batteries then you certainly have an issue with the camera electronics. Test to see if the on/off switch is any good.
Aug 22, 2017 | Hi-Capacity Cameras
Ixus 430 will take photos when flash is turned off, but will not take photos when flash or redeye is selected
Here are some simple things to try first for a camera that won't take a picture when the shutter button is pressed, or with an inoperative flash. They won't work for every case, but they're worth a try. (Hint, make sure that all the screws around the perimeter of the case are present and firmly seated.)
Jun 01, 2011 | Canon PowerShot S410 / IXUS 430 Digital...
Camera won,t save picture even though there is flash & shutter sound
Sony Ericsson phones do not have a a specific "Save" button as such.When you click a photo , it automatically gets saved. They do have a specific "Delete" option though, be careful not to press that. Click a photo, n then exit the camera function.Check to see if the photo has been saved .
Jan 09, 2010 | Sony Ericsson K810i Blue Smartphone
Canon PowerShot A530 Digital Camera Logo
202 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
