Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Whirlpool ThinTwin Won't spin makes a ratcheting noise
    Novelist:
    Champion:
  • 244 Answers
Have you checked the carbon brushes in the motor 1 on either side of the motor with a wire going to each brush carbon should be at least 1in in length and can go down to about 8ml b4 they need changing m8
Posted on Feb 28, 2008
I have a Whirlpool Gold washer (MOD# GSQ9669LW0). The washer makes a grinding noise below when in operation. Spins when agitating, but not in rinse mode. Water still pumps out in final spin.
This machine can get items stuck in the drum, the bearings can go bad etc. https://www.repairclinic.com/RepairHelp/How-To-Fix-A-Washing-Machine/38-5-620929-/Whirlpool-Washer-won-t-spin-GSQ9669LW0.
Oct 16, 2017 | Whirlpool Washing Machines
Whirlpool washer WTW5510VQO will fill, spin and drian but won't agitate, just makes a clicking noise.
If this is just clicking then the agitator bearings stuck or something is jamming it.
Jun 05, 2012 | Whirlpool Washing Machines
Final spin won't go through... makes a squiky noise and no high speed spin
first how old is your machine. second is it under warranty? third have you tried to spin in all selections to see if your timer is working?
Dec 12, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Noise during spin
You have something stuck in the drain pump.
Remove the pump and clear the debris.
Feb 17, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator on whirlpool washer makes lots of noise. No noise when it spins.
In the agitator itself and there are ratchets that are called dogs. If you reach into the drum it will present itself because you be able to turn the agitator both directions, normally the agitator only turns freely in one direction. You can replace the dogs/ratchet by disassembling. If you take rinse dispenser off of the agitator you will see an insulator that you pull off and then you can see the dogs and a bolt that will allow you to take the agitator out.
Jan 11, 2009 | Washing Machines
Whirlpool Ultimate Care II LSQ8543JQ0 WON'T SPIN
really sounds like a coupler issue. May look fine but if one of the teeth are busted it will do this. You can get a tutorial for fixing this here. http://www.shop.washermd.com/category.sc?categoryId=4
Jan 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool thintwin stackable unit
Dear friend,
ngfam at you service!
You can not fix this problem your self!!!
This sounds like it will only fixed by service then you will be happy again!!
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
PS. PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Aug 25, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool ThinTwin LTG6234DQ1
CHECK YOUR LID SWITCH IT HAS PROBABLY CAME LOOSE OR IS OUT. YOU CAN USE A OHM METER TO CHECK IT OR UOY CAN JUMP THE WIRES WITH A TEST LEAD
Feb 27, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
Dan Webster
Dan Webster
Sal De
