Question about Dryers
Dryer de600e dryer will not shut off it's either running or the buzzer is.i think its the switch on the motor but dont know how to test it.
  • 17 Answers
Most likely this is a defective start button stuck inthe on mode. If you know how to check it with an OHM meter, there should be no continuity in the on switch when it is not being held down. do not bypass the buzzer as the on switch needs to be replaced
Posted on Mar 15, 2009
I was told it was probably the timer
Posted on Feb 29, 2008
Why won't the buzzer alarm go off at the end of a drying cycle
Search Results
    Why does my Kenmore dryer model 417.94802/94862 end ...
    www.shopyourway.com > Manage My Life > Questions
    Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
    Why won't the buzzer shut off on my Kenmore 80 Series ...
    The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
    FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
    www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
    Dec 11, 2010 - 10 posts - ‎2 authors
    My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ... VERY annoying dryer End of Cycle Signal
    Jun 29, 2012
    Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
    Mar 27, 2011
    Kenmore 80 series, buzzer won't shut off
    Sep 10, 2005
    More results from www.applianceblog.com
Feb 08, 2016 | Whirlpool Dryers
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ...
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ...
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
Maytag dryer problem
most likely you need a new door switch which is located under the top front if you open the door you will see the switch recepticle replace that switch its cheap https://www.google.com/search?q=maytag+dryer+switch&num=100&source=lnms&tbm=isch&sa=X&ved=0ahUKEwju8qXBp9nZAhXLo1kKHVoICLUQ_AUIDCgD&biw=1536&bih=772
Mar 07, 2018 | Dryers
Maytag dryer LDE512, 20 years old. Buzzer is stuck and won't turn off when door is shut....
Motor centrifugal switch may be stuck. End of motor where switch is may be full of lint
Oct 16, 2010 | Maytag Dryers
Dryer will shut off after load. Then you can hear
Centrifugal switch on motor is sticking, Eric
Aug 10, 2009 | Kenmore Dryers
Buzzer always on, drum won't start spinning
yes you lneed a motor 150.00 to 200.00
May 28, 2009 | Dryers
Buzzer won't shut off. only when door is left open
could be a number of things, but you may want to test with an ohmmeter if you have one.
It sounds like your timer needs to be replaced. If the buzzer is not shutting off, the timer may not be turning to the off position. It may be really slow our out of wack, not letting the dryer completely dry. It also could be an error with the dryer's control module (kind of like a computer for the dryer)
I also recommend playing around with door switch, it to may be faulty. If the dryer does work with door closed, it is unlikely to be the door switch. You will have to test timer and door switch with ohmmeter or voltmeter to determine that the voltage current is constant and not speratic or shorting out.
May 18, 2009 | Kenmore Dryers
Turning the beep off?
1Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down. Step2Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device. Step3Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels. Step4Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz. jQuery('.Article .Steps .Image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Jan 11, 2009 | GE Profile DPXH46EA Electric Dryer
Error E1
dear customer,
most of the time the timers of dryers aren't faulty even though the dryer doesn't run properly in timmed mode. dryer timers have small motors on the back. The motor rotates gears and cams that open and close switch contacts that control the loads in your dryer. A load is something that does work like a motor, heater, light bulb or end of the cycle buzzer. When the timer is manufactured the amount of time each set of contacts will be closed is built in by the timer cams and gears.so i recommend yu to check the follwoing
  • Test the moisture sensor
  • Test the thermostats
  • Test the heating element
  • and finally the timer device.
hope you find this useful. thank you.
Jul 09, 2008 | Dryers
Kenmore heavy duty 80 series
The buzzer is wired through a switch on your dryer motor. The switch is NOT a normal switch... it's a centrifugal switch meaning that it is mounted on the motor shaft and rotates along with it. When it "spins up" centrifugal force flings it outward to make contact with the terminals on the outer edge of the inner motor housing (This tells the timer that the motor is functioning properly and it can now begin to heat the clothes. This is also the switch that keeps you from having to hold in the "Start" button 'til the clothes are dry) When the timer kills power to the motor, the buzzer sounds off because of this switch. As the motor slows, springs retract the switch from the contacts and shut off the buzzer. Make sense so far? Sounds like your centrifugal switch is getting stuck. Unplug the dryer and gain access to the motor. Then use Contact Cleaner in a spray can to spray and clean every inch (inside and out) of the motor. This should get you going again.
Jul 29, 2007 | Kenmore 659 Electric Dryer
Dryers Logo
54 people viewed this question
Top Dryers Experts
Marvin
Marvin
